Label | Description |
MAC Address Filter | Select Enable to activate the MAC filter function. |
MAC Restrict Mode | Select Allow to only permit the listed MAC addresses access to the Zyxel Device. Select Deny to permit anyone access to the Zyxel Device except the listed MAC addresses. |
Add New Rule | Click the Add button to create a new entry. |
Set | This is the index number of the MAC address. |
Active | Select Active to enable the MAC filter rule per entry. The rule will not be applied if the Active check box is not selected. |
Host Name | Enter the host name of a wired LAN client that you want to allow access to the Zyxel Device. You can use up to 17 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. |
MAC Address | Enter the MAC address of a wired LAN client that you want to allow access to the Zyxel Device. Enter the MAC addresses in a valid MAC address format, that is, six hexadecimal character pairs, for example, 12:34:56:78:9a:bc. |
Delete | Click the Delete icon to delete an existing rule. |
Cancel | Click Cancel to restore your previously saved settings. |
Apply | Click Apply to save your changes. |
MAC Address | Enter the MAC addresses of a wired LAN client that you want to allow access to the Zyxel Device in these address fields. Enter the MAC addresses in a valid MAC address format, that is, six hexadecimal character pairs, for example, 12:34:56:78:9a:bc. |
