Routing Table
Routing Table Overview
Routing is based on the destination address only and the Zyxel Device takes the shortest path to forward a packet.
Routing Table
The table below shows IPv4 and IPv6 routing information. The IPv4 subnet mask is ‘255.255.255.255’ for a host destination and ‘0.0.0.0’ for the default route. The gateway address is written as ‘*’(IPv4)/‘::’(IPv6) if none is set.
Click System Monitor > Routing Table to open the following screen.
label
Description
Destination
This indicates the destination IPv4 address or IPv6 address and prefix of this route.
Gateway
This indicates the IPv4 address or IPv6 address of the gateway that helps forward this route’s traffic.
Subnet Mask
This indicates the destination subnet mask of the IPv4 route.
Interface
This indicates the name of the interface through which the route is forwarded.
• brx indicates a LAN interface where x can be 0 – 3 to represent LAN1 to LAN4 respectively.
• ethx indicates an Ethernet WAN interface using IPoE or in bridge mode.
• ppp0 indicates a WAN interface using PPPoE.
• wlx indicates a wireless interface where x can be 0 – 1.
