Reboot
Overview
Use this screen to restart the Zyxel Device.
If you made changes in the Web Configurator, they were saved when you click Apply. They do not change when you reboot the Zyxel Device.
If you made changes in the CLI, you have to use the write command to save the configuration. They do not change when you reboot the Zyxel Device.
Reboot is different from reset; reset returns the Zyxel Device to its default configuration.
This screen allows remote users to restart the Zyxel Device.
You can reboot your Zyxel Device when the Internet connection is slow or intermittent.
Each field is described in the following table.
Label
Description
Maintenance
Enable the schedule
Select this checkbox to have your Zyxel Device restart at a specific time on selected days of the week.
By scheduling a reboot, you can have the Zyxel Device refresh the network connections at a specified time, allowing automatic reconnection with WiFi clients in case of a connection failure.
Start time
Specify the time of the day (in 24-hour format) to have the Zyxel Device automatically restart. For example, 23:00 is 11:00 PM.
Week Days
Select each day of the week to have the automatically restart.
Apply
Click Apply to save your changes to the Zyxel Device.
Reboot Now
Click Reboot Now to restart the Zyxel Device immediately.
After the Zyxel Device reboots, wait a few minutes until the login screen appears. If the login screen does not appear, type the IP address of the Zyxel Device in your Web browser.
You can also use the CLI command reboot to restart the Zyxel Device.
