maximum number | type | Description |
2 | Manual | A backup created using Organization-wide > Organization-wide manage > Backup & restore > Site: Actions: Create backup. |
2 | Scheduled | A backup created using Organization-wide > Organization-wide manage > Backup & restore > Site: Actions: Set backup schedule. |
Label | Description |
Actions | Click the Create backup button to open the window to create a new backup of the current configuration of the site / Nebula Switch / Nebula Firewall / Nebula Mobile Router to the NCC. Enter 1 to 64 characters including special characters inside the square quotes [~!@#$%^&*()_+{}|:”<>–=[]\;’,/ ] in the Backup description field and then click Backup. Otherwise, click Cancel. The backup time will depend on how many sites / Nebula Switches / Nebula Firewalls / Nebula Mobile Routers are selected and the number of Nebula Devices in the selected sites during the backup. Click the Set backup schedule button to open the window to select a Monthly, Weekly, or Daily backup of the current configuration of the site / Nebula Switch / Nebula Firewall / Nebula Mobile Router to the NCC. Then select the day of the month/week. To activate the schedule, click the Backup schedule switch to the right and then click Update to save the settings and close the window. Otherwise, click Cancel. Click the Restore button to restore a previously saved site / Nebula Switch / Nebula Firewall / Nebula Mobile Router configuration from NCC to the site. |
Search | Select the filter criteria (Any or site name) to filter the list of sites. |
N sites/devices | This shows how many sites / Nebula Switches / Nebula Firewalls / Nebula Mobile Routers (N) match the filter criteria and how many sites / Nebula Switches / Nebula Firewalls / Nebula Mobile Routers are created in total in the organization / site. |
Select an entry’s checkbox to select a specific entry. Otherwise, select the checkbox in the table heading row to select all entries. | |
Device name | This shows the descriptive name of the Nebula Device. |
Model | This shows the model name of the Nebula Device. |
Site | This shows the descriptive name of the site. |
Organization | This shows the descriptive name of the organization. |
Backup status | This indicates the default or last backup is successful (green), a backup is in progress (orange), a previous backup failed (red), or the Nebula Switch / Nebula Firewall / Nebula Mobile Router does not belong to a site or the Nebula Switch is a stacking member (white). |
Backup schedule | This shows the backup schedule when activated. Otherwise, it shows Disable. |
Last backup time (UTC) | This shows the UTC date and time the backup was saved on the NCC server. |
Number of backups | This shows the total number of backups of the site configurations. A maximum of 4 backups (2 manual and 2 scheduled) are allowed per site. Click the hyperlink to open a window to change the Backup description. You can use alphanumeric and ()+/:=?!*#@$_%- characters, up to 512 characters. Or click the delete icon to remove the backup. Then click Update. |
