Nebula Device | site clone | move Nebula Device to cloned site – enabled | keep management/wan interface – enabled |
Access Point (AP) | When enabled: • AP site-wide configuration is cloned • Individual AP configuration is NOT cloned (for example, radio settings) | When enabled: AP site-wide configuration and individual AP configuration are cloned (for example, radio settings) | When enabled: AP site-wide configuration and individual AP configuration are cloned (for example, radio settings) |
Switch | When enabled: • Switch site-wide configuration is cloned • Individual Switch configuration is NOT cloned (for example, IGMP) • Switch port configuration is NOT cloned | When enabled: • Switch site-wide configuration is cloned • Individual Switch configuration is cloned (for example, IGMP) • Switch port configuration is cloned | When enabled: • Switch site-wide configuration is cloned • Individual Switch configuration is cloned (for example, IGMP) • Switch port configuration is cloned |
Security Firewall | When enabled, the site-to-site VPN settings are reset. | When enabled, the site-to-site VPN settings are reset. | When enabled, the site-to-site VPN settings are reset. |
Label | Description |
Synchronize org-wide settings | |
From source organization | Select the organization to copy settings from. |
Org. setting | Select the settings that you want to copy from the source to the destination organization. Select All org-wide settings to copy everything. |
To dest. organization | Select the organization to copy settings to. |
Sync | Click this to copy the selected settings from the source to the destination organization. |
Replicate/move sites | |
Site replicate | Select this to allow the site settings to be copied to the destination organization and any future changes applied to the source organization. The following site-wide settings will be replicated and cannot be reversed: • All site-wide settings, including the site settings and alert settings • Device-related settings, for example, AP & port settings, SSID settings, Switch settings, Port profiles, Security Appliance settings including the VPN-related settings. |
From source organization | Select the organization to copy settings from. Then select one or more sites. Select All sites to copy all sites from the source to the destination organization. Select Move site devices to cloned site in destination organization to include the Nebula Devices. Enable Keep Management/WAN interface to copy the WAN connection settings for the Nebula Devices to the destination organization. |
To dest. organization | Select the organization to copy the selected sites to. |
Site move with devices | Select this to include the Nebula Devices to the destination organization. You may need to configure the WAN interface, management VLAN, and IPv4 settings when your networking environment is different. |
From source organization | Select the organization to copy settings from. Then select one or more sites. Select All sites to copy all sites from the source to the destination organization. Select Copies settings for summary and IPTV reports, such as email recipients, custom logos, and more. to sync these information with the source site email recipients. |
Process | Click this to copy the selected sites including the Nebula Devices from the source to the destination organization. |
