Label | Description |
Add New e-mail | Click this button to create a new entry (up to 32 can be created). |
Mail Server Address | This displays the server name or the IP address of the mail server. |
Username | This displays the user name of the sender’s mail account. |
Port | This field displays the port number of the mail server. |
Security | This field displays the protocol used for encryption. |
E-mail Address | This field displays the email address that you want to be in the from or sender line of the email that the Zyxel Device sends. |
Modify | Click the Edit icon to configure the entry. Click the Delete icon to remove the entry. |
Remove | Click this button to delete the selected entries. |
Test | Click this to send a test email to the configured email address. |
Mail Server Address | Enter the server name or the IP address of the mail server for the email address specified in the Account e-mail Address field. If this field is left blank, reports, logs or notifications will not be sent through email. |
Port | Enter the same port number here as is on the mail server for mail traffic. |
Authentication Username | Enter the user name. You can use up to 32 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. This is usually the user name of a mail account you specified in the Account email Address field. |
Authentication Password | Enter the password associated with the user name above. |
Account e-mail Address | Enter the email address that you want to be in the from or sender line of the email notification that the Zyxel Device sends. If you activate SSL/TLS authentication, the email address must be able to be authenticated by the mail server as well. |
Connection Security | Select SSL to use Secure Sockets Layer (SSL) or Transport Layer Security (TLS) if you want encrypted communications between the mail server and the Zyxel Device. Select STARTTLS to upgrade a plain text connection to a secure connection using SSL/TLS. Select NONE to disable the connection security. |
Cancel | Click this button to begin configuring this screen afresh. |
OK | Click this button to save your changes and return to the previous screen. |
