Label | Description |
CWMP Active | CPE WAN Management Protocol (CWMP) enables the Zyxel Device to be remotely configured through a WAN link. Communication between the Zyxel Device and the management server is conducted through SOAP/HTTP(S) in the form of remote procedure calls (RPC). Click to enable (switch turns blue) to allow the Zyxel Device to be managed by a management server. Otherwise, click to disable (switch turns gray) to disallow the Zyxel Device to be managed by a management server. |
Inform | Click to enable (switch turns blue) the Zyxel Device to send periodic inform through TR-069 on the WAN. Otherwise, click to disable (switch turns gray). |
Inform Interval | Enter the time interval (in seconds) at which the Zyxel Device sends information to the auto-configuration server. |
IP Protocol | Select the type of IP protocol to allow TR-069 to operate on. |
ACS URL | Enter the URL or IP address of the auto-configuration server. |
ACS User Name | Enter the TR-069 user name for authentication with the auto-configuration server. |
ACS Password | Enter the TR-069 password for authentication with the auto-configuration server. |
WAN Interface Used by TR-069 Client | Select a WAN interface through which the TR-069 traffic passes. If you select Any_WAN, the Zyxel Device automatically passes the TR-069 traffic when any WAN connection is up. If you select Multi_WAN, you also need to select two or more pre-configured WAN interfaces. The Zyxel Device automatically passes the TR-069 traffic when one of the selected WAN connections is up. |
Cellular WAN / WWAN / ETHWAN | The Zyxel Device automatically passes the TR-069 traffic when cellular / 4G/5G/6G mobile / Ethernet WAN connection is up. |
Display SOAP Messages on Serial Console | Click to enable (switch turns blue) the dumping of all SOAP messages during the ACS server communication with the CPE. |
Connection Request User Name | Enter the connection request user name. When the ACS makes a connection request to the Zyxel Device, this user name is used to authenticate the ACS. |
Connection Request Password | Enter the connection request password. When the ACS makes a connection request to the Zyxel Device, this password is used to authenticate the ACS. |
Connection Request URL | This shows the connection request URL. The ACS can use this URL to make a connection request to the Zyxel Device. |
Supplementary ACS URL | Enter the URL or IP address of an additional TR-069 auto-configuration server. |
Supplementary ACS User Name | Enter the user name of an additional TR-069 auto-configuration server for authentication. |
Supplementary ACS Password | Enter the password of an additional TR-069 auto-configuration server for authentication. |
Validate ACS Certificate | Click to enable (switch turns blue) the validation of a local certificate used by TR-069 client. |
Local Certificate Used by TR-069 Client | You can choose a local certificate used by TR-069 client. The local certificate should be imported in the Security > Certificates > Local Certificates screen. |
XMPP Server Address | Enter the IP address of the XMPP server. The Zyxel Device will use the address to connect to the XMPP server. |
XMPP Server Port | Enter the TCP port reserved for the XMPP server. The default is 5222. (1 – 65535) |
Apply | Click Apply to save your changes. |
Cancel | Click Cancel to restore the screen’s last saved settings. |
