) to see the side bar and navigation panel.Icon | Description |
![]() | Wizard: Click this icon to open screens where you can configure the Zyxel Device’s time zone and Wi-Fi settings. |
![]() | Theme: Click this icon to select a color that you prefer and apply it to the Web Configurator. ![]() |
![]() | Restart: Click this icon to reboot the Zyxel Device without turning the power off. |
![]() | Language: Select the language you prefer. |
![]() | Logout: Click this icon to log out of the Web Configurator. |
) to display the navigation panel that contains configuration menus and icons (quick links). Click X to close the navigation panel.
Link | Tab | Function |
Home | Use this screen to configure basic Internet access and wireless settings. This screen also shows the network status of the Zyxel Device and computers/devices connected to it. | |
Network Setting | Tab | Function |
Broadband | Broadband | Use this screen to view and configure ISP parameters, WAN IP address assignment, and other advanced properties. You can also add new WAN connections. |
Broadband | Ethernet WAN | Use this screen to convert the LAN port as WAN port, or restore the WAN port to LAN port. |
Broadband | Cellular WAN | Use this screen to configure a cellular WAN connection. |
Broadband | Cellular APN | Use this screen to configure the Access Point Name (APN) provided by your service provider. |
Broadband | Cellular SIM | Use this screen to enter a PIN for your SIM card to prevent others from using it. |
Broadband | Cellular Band | Use this screen to configure the cellular frequency bands that can be used for Internet access as provided by your service provider. |
Broadband | Cellular PLMN | Use this screen to view available PLMNs and select your preferred network. |
Broadband | Cellular IP Passthrough | Use this screen to enable IP Passthrough on the Zyxel Device. |
Broadband | Cellular SMS | Use this screen to enable SMS Inbox and receive SMS messages. |
Broadband | Cellular Lock (LTE) | Use this screen to enable or disable PCI Lock for 4G LTE connections. |
Broadband | Cellular Lock (5G) | Use this screen to enable or disable PCI Lock for 5G NR connections. |
Wireless | General | Use this screen to configure the Wi-Fi settings and Wi-Fi authentication or security settings. |
Wireless | More AP | Use this screen to configure multiple BSSs on the Zyxel Device. |
Wireless | MAC Authentication | Use this screen to block or allow wireless traffic from wireless devices of certain SSIDs and MAC addresses to the Zyxel Device. |
Wireless | WPS | Use this screen to configure and view your WPS (Wi-Fi Protected Setup) settings. |
Wireless | WMM | Use this screen to enable or disable Wi-Fi MultiMedia (WMM). |
Wireless | Others | Use this screen to configure advanced Wi-Fi settings. |
Wireless | WLAN Scheduler | Use this screen to create rules to schedule the times to permit Internet traffic from each wireless network interfaces. |
Wireless | Channel Status | Use this screen to scan Wi-Fi channel noises and view the results. |
Home Networking | LAN Setup | Use this screen to configure LAN TCP or IP settings, and other advanced properties. |
Home Networking | Static DHCP | Use this screen to assign specific IP addresses to individual MAC addresses. |
Home Networking | UPnP | Use this screen to turn UPnP and UPnP NAT-T on or off. |
Home Networking | Custom DHCP | Use this screen to configure additional DHCP options. |
Routing | Static Route | Use this screen to view and set up static routes on the Zyxel Device. |
Routing | DNS Route | Use this screen to forward DNS queries for certain domain names through a specific WAN interface to its DNS servers. |
Routing | Policy Route | Use this screen to configure policy routing on the Zyxel Device. |
Routing | RIP | Use this screen to configure Routing Information Protocol to exchange routing information with other routers. |
NAT | Port Forwarding | Use this screen to make your local servers visible to the outside world. |
NAT | Port Triggering | Use this screen to change your Zyxel Device’s port triggering settings. |
NAT | DMZ | Use this screen to configure a default server which receives packets from ports that are not specified in the Port Forwarding screen. |
NAT | ALG | Use this screen to enable the ALGs (Application Layer Gateways) in the Zyxel Device to allow applications to operate through NAT. |
DNS | DNS Entry | Use this screen to view and configure DNS routes. |
DNS | Dynamic DNS | Use this screen to allow a static hostname alias for a dynamic IP address. |
USB Service | USB Service | Use this screen to enable file sharing through the Zyxel Device. |
VLAN Group | VLAN Group | Use this screen to group and tag VLAN IDs to outgoing traffic from the specified interface. |
Interface Grouping | Interface Grouping | Use this screen to map a port to create multiple networks on the Zyxel Device. |
Nebula | Nebula | Use this screen to enable Nebula Discovery and configure proxy server settings. |
Security | Tab | Function |
Firewall | General | Use this screen to configure the security level of your firewall. |
Firewall | Protocol | Use this screen to add Internet services and configure firewall rules. |
Firewall | Access Control | Use this screen to enable specific traffic directions for network services. |
Firewall | DoS | Use this screen to activate protection against Denial of Service (DoS) attacks. |
MAC Filter | MAC Filter | Use this screen to block or allow traffic from devices of certain MAC addresses to the Zyxel Device. |
Parental Control | Parental Control | Use this screen to define time periods and days during which the Zyxel Device performs parental control and/or block web sites with the specific URL. |
Certificates | Local Certificates | Use this screen to view a summary list of certificates and manage certificates and certification requests. |
Certificates | Trusted CA | Use this screen to view and manage the list of the trusted CAs. |
System Monitor | Tab | Function |
Log | System Log | Use this screen to view the status of events that occurred to the Zyxel Device. You can export or email the logs. |
Log | Security Log | Use this screen to view all security related events. You can select the level and category of the security events in their proper drop-down list window. Levels include: • Emergency • Alert • Critical • Error • Warning • Notice • Informational • Debugging Categories include: • Account • Attack • Firewall • MAC Filter |
Traffic Status | WAN | Use this screen to view the status of all network traffic going through the WAN port of the Zyxel Device. |
Traffic Status | LAN | Use this screen to view the status of all network traffic going through the LAN ports of the Zyxel Device. |
ARP Table | ARP Table | Use this screen to view the ARP table. It displays the IP and MAC address of each DHCP connection. |
Routing Table | Routing Table | Use this screen to view the routing table on the Zyxel Device. |
WLAN Station Status | WLAN Station Status | Use this screen to view the wireless stations that are currently associated to the Zyxel Device’s Wi-Fi. |
Cellular WAN Status | Cellular WAN Status | Use this screen to look at the cellular Internet connection status. |
Maintenance | Tab | Function |
System | System | Use this screen to set the Zyxel Device name and Domain name. |
User Account | User Account | Use this screen to change the user password on the Zyxel Device. |
Remote Management | MGMT Services | Use this screen to enable specific traffic directions for network services. |
Remote Management | Trust Domain | Use this screen to view a list of public IP addresses which are allowed to access the Zyxel Device through the services configured in the Maintenance > Remote Management screen. |
Remote Management | MGMT Services for IP Passthrough | Use this screen to enable various approaches to access this Zyxel Device remotely from a WAN and/or LAN connection. |
Remote Management | Trust Domain for IP Passthrough | Use this screen to enable public IP addresses to access this Zyxel Device remotely from a WAN and/or LAN connection. |
TR-069 Client | TR-069 Client | Use this screen to configure your Zyxel Device to be managed remotely by an Auto Configuration Server (ACS) using TR-069. |
TR-369 Local Agent | General | Use this screen to enable TR-369 and set the Zyxel Device as an agent. Select a cellular WAN, and configure the Message Transfer Protocol (MTP) to receive USP messages from USP (User Services Platform) controllers. |
TR-369 Local Agent | Controller | Use this screen to configure controller settings for topics the Zyxel Device agent should publish to this controller. |
TR-369 Local Agent | MQTT | Use this screen to manage the profile settings that the Zyxel Device will use to register with an MQTT broker. |
Time | Time | Use this screen to change your Zyxel Device’s time and date. |
E-mail Notification | E-mail Notification | Use this screen to configure up to two mail servers and sender addresses on the Zyxel Device. |
Log Setting | Log Setting | Use this screen to change your Zyxel Device’s log settings. |
Firmware Upgrade | Firmware Upgrade | Use this screen to upload firmware to your Zyxel Device. |
Firmware Upgrade | Module Upgrade | Use this screen to upload the module firmware to your Zyxel Device. |
Backup/Restore | Backup/Restore | Use this screen to backup and restore your Zyxel Device’s configuration (settings) or reset the factory default settings. |
Reboot | Reboot | Use this screen to reboot the Zyxel Device or Zyxel Mesh system without turning the power off. |
Diagnostic | Diagnostic | Use this screen to identify problems with the Zyxel Device. You can use Ping, TraceRoute, or Nslookup to help you identify problems. |
) in the lower left corner to arrange the screen order.
) in the lower left corner to save the changes.
