Firmware Upgrade
Firmware Upgrade Overview
This chapter explains how to upload new firmware to your Zyxel Device if you get new firmware releases from your service provider.
Firmware Upgrade
This screen lets you upload new firmware to your Zyxel Device.
Get the latest firmware from your service provider. Then upload the firmware file to your Zyxel Device. The upload process uses HTTP (Hypertext Transfer Protocol). The upload may take up to 3 minutes. After a successful upload, the Zyxel Device will reboot.
Click Maintenance > Firmware Upgrade to open the following screen.
Do NOT turn off the Zyxel Device while firmware upload is in progress!
LABEL
DESCRIPTION
Upgrade Firmware
Current Firmware Version
The firmware on each Zyxel Device is identified by the firmware trunk version, followed by a unique code which identifies the model, and then the release number after the period. For example, V1.00 (ACKP.0) is a firmware for the 1.00 version trunk, the ACKP code identifies the NR5309 model, and .0 is the first firmware release for the model.
File Path
Enter the location of the file you want to upload in this field or click Choose File/Browse to find it.
Choose File/Browse
Click this to find the .bin file you want to upload. Remember that you must decompress compressed (.zip) files before you can upload them.
Upload
Click this to begin the upload process. This process may take up to 3 minutes.
*Only use firmware for your Zyxel Device’s specific model. Refer to the label on the bottom of your Zyxel Device. For example, if the Zyxel Device’s current firmware version is V5.70(ACDZ.0)B4, you must upload the firmware file containing "ACDZ".
After you see the firmware updating screen, wait a few minutes before logging into the Zyxel Device again.
Firmware Uploading
The Zyxel Device automatically restarts in this time, causing a temporary network disconnect. In some operating systems, you may see the following icon on your desktop.
Network Temporarily Disconnected
After 2 minutes, log in again and check your new firmware version in the Connection Status screen.
If the upload was not successful, an error screen will appear. Click OK to go back to the Firmware Upgrade screen.
Error Message
Module Upgrade
This screen lets you upload new firmware specific to the built-in LTE module in order to improve the LTE module’s reliability and performance. The upload process uses HTTP (Hypertext Transfer Protocol) and may take more than 3 minutes. After a successful upload, the Zyxel Device will reboot.
Click Maintenance > Firmware Upgrade > Module Upgrade to open the following screen.
LABEL
DESCRIPTION
Upgrade Cellular Module Firmware
Current Module Version
This is the current module firmware version.
Choose file...
Choose File/Browse
Upload
Click this to begin the upload process. This process may take more than 3 minutes.
After you see the module updating screen, wait about 20 minutes before logging into the Zyxel Device again.
The Zyxel Device automatically restarts in this time causing a temporary network disconnect. In some operating systems, you may see the following icon on your desktop.
After two minutes, log in again and check your new firmware version in the Status screen.
If the upload was not successful, an error screen will appear. Click OK to go back to the Module Upgrade screen.
