Label | Description |
Active Device Status | This section displays information on the active Zyxel Device with an activated Device HA Pro license. |
Health Status | This displays Off or On depending on whether Device HA Pro is disabled or enabled on the active Zyxel Device. |
S/N | This displays the serial number of the active Zyxel Device. |
Virtual MAC | This displays the hardware MAC address of the active Zyxel Device with an activated Device HA Pro license. |
Sync Status | For the active Zyxel Device with an activated Device HA Pro license, this field always displays n/a. For the passive Zyxel Device, this displays the synchronization progress between the active Zyxel Device with an activated Device HA Pro license and the passive Zyxel Device. The possible values are No Progress, Fail, Abort, Success or In Progress. |
Passive Device Status | This section displays information on the passive Zyxel Device with an activated Device HA Pro license. |
Health Status | This displays Off or On depending on whether Device HA Pro is disabled or enabled on the passive Zyxel Device. |
S/N | This displays the serial number of the passive Zyxel Device. |
Virtual MAC | This displays the hardware MAC address of the passive Zyxel Device. |
Device HA Pro License | These are the steps to activate a Device HA Pro license on your active and passive Zyxel Devices. 1. See your Device HA Pro iCard. The card contains two keys. 2. Register your active and passive Zyxel Devices at myZyxel. 3. Activate the license by entering one key on the active Zyxel Device and the other key on the passive Zyxel Device. It doesn’t matter which Zyxel Device is actually active or passive as this is dynamic in Device HA Pro. |
Service Status | This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service. If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license. Then, click Activate to connect with the myZyxel server to activate the new license. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Enable Device HA | Select this to turn the Zyxel Device’s Device HA Pro feature on. |
Enable Configuration Provisioning From Active Device. | Select this to have a passive Zyxel Device copy the active Zyxel Device’s configuration, signatures (anti-malware, IPS, application patrol, URL Threat filter, and IP reputation), and certificates. Disconnect all cables and turn off the passive Zyxel Device when you disable Device HA. |
Serial Number of Licensed Device for License Synchronization | Type the serial number of the Zyxel Device (active or passive) with the Device HA Pro subscribed license. |
Active Device Management IP | Type the IPv4 address of the highest-numbered copper Ethernet port on the active Zyxel Device (the heartbeat dedicated link port). |
Passive Device Management IP | Type the IPv4 address of the highest-numbered copper Ethernet port on the passive Zyxel Device (the heartbeat dedicated link port). |
Subnet Mask | Type the subnet mask for the management IP addresses. |
Password | Type a synchronization password of between 1 and 32 single-byte printable characters. You will be prompted for the password before synchronization takes place. |
Retype to Confirm | Type the exact same synchronization password as typed above. |
Heartbeat Interval | Type the number of seconds (1-10) allowed for absence of a heartbeat signal before a failure of the active Zyxel Device is recorded. |
Heartbeat Lost Tolerance | Type the number of heartbeat failures allowed before failover is activated on the passive Zyxel Device. |
Monitor Interface | Select an interface in Available Interfaces and click the right-arrow button to move it to Monitor Interface to become a Device HA pro monitored interface. To remove a Device HA pro monitored interface, select it in Monitor Interface and click the left-arrow button to move it to Available Interfaces. |
Failover Detection | |
Enable Failover When Interface Failure (Option) | Select this to have the passive Zyxel Device take over when a monitored interface fails. |
Enable Failover When Device Service Fails (Option) | Select this to have the passive Zyxel Device take over when a monitored service daemon on the active Zyxel Device fails. |
Apply | Click Apply to save your Device HA Pro configurations back to the Zyxel Device but keep the Zyxel Device using Device HA (general). |
Logs | |
Active Device | This displays Device HA Pro logs on the active Zyxel Device. |
Passive Device | This displays Device HA Pro logs on the passive Zyxel Device. |
Refresh | Click Refresh to update information in this screen. |
