label | Description |
Enable Walled Garden | Select this to turn on the walled garden feature. |
Hotspot Service Status | |
Service Status | This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service. If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license. Then, click Activate to connect with the myZyxel server to activate the new license. |
Service Type | This shows whether you have a trial or standard license or none (Trial, Standard, None). |
Expiration Date | This shows when your hotspot license will expire. |
Register Now | Click the link to go to myZyxel where you can register your Zyxel Device and activate the service. This link is available only when the service is not activated yet. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Walled Garden URL List | Use this table to manage the list of walled garden web site links. |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Move | To move an entry to a different number in the list, click the Move icon. In the field that appears, specify the number to which you want to move the interface. |
# | This field is a sequential value, and it is not associated with any entry. |
Status | This icon is lit when the entry is active and dimmed when the entry is inactive. |
Display | This icon is lit when the web site link is set to display in the user login screen. |
Name | This field displays the descriptive name of the web site. |
URL | This field displays the URL of the web site. |
Enable | Select this to activate the entry. |
Hide in login page | Select this to not display the web site link in the user login screen. This is helpful if a user’s access to a specific web site is required to stay connected but he or she doesn’t need to visit that web site. |
Name | Enter a descriptive name for the walled garden link to be displayed in the login screen. You can use up to 31 alphanumeric characters (A-Z, a-z, 0-9) and underscores (_). Spaces are also allowed. The first character must be a letter. |
URL | Enter the URL of the web site. Use “http://” or “https://” followed by up to 262 characters (0-9a-zA-Z;/?:@&=+$\.-_!~*'()%). For example, http://www.example.com or http://172.16.1.35. |
Preview | Click this button to open the specified web site in a new frame. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
Walled Garden Domain/IP List | Use this table to manage the list of walled garden web site links. |
Domain Name/IP Address | This field displays the domain name or IP address and subnet mask of the web site. |
Name | Enter a descriptive name for the walled garden link. You can use up to 31 alphanumeric characters (A-Z, a-z, 0-9) and underscores (_). Spaces are also allowed. The first character must be a letter. |
Type | Select whether you want to create the link by entering a domain name or an IP address. |
Domain Name / IP Address | If you select Domain, type a Fully-Qualified Domain Name (FQDN) of a web site. An FQDN starts with a host name and continues all the way up to the top-level domain name. For example, www.zyxel.com.tw is a fully qualified domain name, where “www” is the host, “zyxel” is the third-level domain, “com” is the second-level domain, and “tw” is the top level domain. Underscores are not allowed. Use "*." as a prefix in the FQDN for a wildcard domain name (for example, *.example.com). If you select IP, enter the IP address and subnet mask of the web site. |
