Web Configurator
Overview
The Web Configurator is an HTML-based management interface that allows easy system setup and management through Internet browser. Use a browser that supports HTML5, such as Microsoft Edge, Mozilla Firefox, or Google Chrome.
In order to use the Web Configurator you need to allow:
Web browser pop-up windows from your device.
JavaScript (enabled by default).
Java permissions (enabled by default).
The recommended minimum screen resolution is 1024 x 768 pixels.
*Screenshots and graphics in this book may differ slightly from your product due to differences in product features or Web Configurator brand style.
Web Configurator Access
This section shows how to access the Web Configurator.
1 Make sure your Zyxel Device hardware is properly connected. See the Quick Start Guide.
2 In your browser go to https://192.168.1.1 or https://myrouter.local. By default, the Zyxel Device automatically routes this request to its HTTPS server, and it is recommended to keep this setting. The Login screen appears.
If you want to change the display language for the Zyxel Device’s Web Configurator screens, select from the drop-down list box. You can also change the display language in Configuration > System > Language.
3 Enter the user name (default: “admin”) and password (default: “1234”). Click Login.
4 If this is your first login, change the default admin password on the Update Admin Info screen. Enter a new password, then click Apply. Log in again using the user name (default: admin) and your new password. Click Login.
*In Configuration > Object > User/Group > Setting, you can enable Password Complexity to require a new password to consist of at least 8 characters and at most 64, where at least 1 character must be a number, at least 1 a lower case letter, at least 1 an upper case letter and at least 1 a special character from the keyboard, such as !@#$%^&*()_+. You can also require periodic changing of the password in that screen by configuring Password must changed every (days).
Security Best Practices
For a secure network, we recommend configuring the Zyxel Device with two-factor authentication, regularly changing your password, and completing the security settings.
The Security Best Practices screen appears after each login to remind you of the recommended security settings. Click Begin to start the setup. A checkmark indicates a completed setup.
Two-Factor Authentication
Enhance security with two-factor authentication by using Google Authenticator to access the Zyxel Device. Follow the instructions on the screen to set up the two-factor authentication. See Google Authentication for more information.
Password Change
Regularly changing passwords can enhance security by reducing the risk of unauthorized access. Depending on the password change interval under Login Security in Configuration > Object > User/Group > Setting, the password must be changed every set number of days.
Security Policy Control
Use this screen to activate the security configuration. Select Yes from the drop-down list, then click Next to activate the security policy configured in Configuration > Security Policy > Policy Control > Policy.
Security Check for Web Interface
When the Zyxel Device detects a rule that allows unrestricted Internet access to the Web Configurator and SSL VPN, restrict the access by using the source IP address for the Web Configurator and the GeoIP for SSL VPN.
Use this screen to configure settings to secure your Zyxel Device. You can configure:
Secure SSL access from the Internet to the Zyxel Device.
Secure SSL access from the Internet to the network behind the Zyxel Device.
Security Risk Warning
Keep the licenses up to date to receive critical security enhancements, avoid malware risks, and ensure optimal performance. Click Renew to extend the license. See Service Screen for more information.
Other Security Measures
New firmware contains patches to enhance security. Make sure to check for new firmware regularly and update firmware in Maintenance > Firmware Management.
Web Configurator Screens Overview
The Web Configurator screen is divided into these parts:
Title Bar
The title bar icons in the upper right corner provide the following functions.
Title Bar: Web Configurator Icons
Label
Description
SecuReporter
This icon shows when SecuReporter is enabled and the Zyxel Device is added to an organization.
Click this to open the SecuReporter portal page.
Web Console
Click this to open one or multiple console windows from which you can run command line interface (CLI) commands. You will be prompted to enter your user name and password. See the Command Reference Guide for information about the commands.
Logging in to the Zyxel Device with HTTPS, so you can open one or multiple console windows.
CLI
Click this to open a popup window that displays the CLI commands sent by the Web Configurator to the Zyxel Device.
Reference
Click this to check which configuration items reference an object.
Site Map
Click this to see an overview of links to the Web Configurator screens.
Community
Go to https://community.zyxel.com for product discussions.
Help
Click this to open the help page for the current screen.
Notification
Only Admin or Limited Admin can see notifications. Notifications display what’s new in the Zyxel Device firmware (ZLD), information on security services about to expire.
Slide the switch to Off if you don’t want notifications. Click an item to see more details on it. Click the Refresh icon or refresh the browser page to update notifications. The latest notification appears at the top. An item is removed once it has been read.
Up to five notifications can be shown here. If there are more than five notifications, then click All Notifications to see them.
About
Click this to display basic information about the Zyxel Device.
Logout
Click this to log out of the Web Configurator.
About
Click About to display basic information about the Zyxel Device.
This table describes the fields in this screen.
About
Label
Description
Current Version
This shows the firmware version of the Zyxel Device.
Released Date
This shows the date (yyyy-mm-dd) and time (hh:mm:ss) when the firmware is released.
System Protection Signature
This shows the system protection signature version of the Zyxel Device. These signatures do not require a license. The Zyxel Device will synch with the Cloud Helper Server every day to update these signatures automatically.
System protection signatures protect your Zyxel Device and local networks from web attacks, such as command injection, cross-site scripting and path traversal.
Command injection: This is an attack in which an attacker uses the Zyxel Device vulnerabilities to execute commands to control your Zyxel Device.
Cross-site scripting: This is an attack in which an attacker implants malicious scripts in a website. When you visit this website, the malicious scripts are sent and executed on your web browser.
Path traversal: This is an attack that allows an attacker to access files you store in the web root folder.
OK
Click this to close the screen.
Site Map
Click Site MAP to see an overview of links to the Web Configurator screens.
Web Console
Click Web Console to open one or multiple console windows from which you can run CLI commands. You will be prompted to enter your user name and password. See the Command Reference Guide for information about the commands. Logging in to the Zyxel Device with HTTPS, so you can open one or multiple console windows.
Reference
Select the type of object and the individual object and click Refresh to show which configuration settings reference the object.
The fields vary with the type of object. This table describes labels that can appear in this screen.
Reference
Label
Description
Type
Select an object type to see the services.
Name
This identifies the object for which the configuration settings that use it are displayed. Click the object’s name to display the object’s configuration screen in the main window.
This field is a sequential value, and it is not associated with any entry.
Service
This is the type of setting that references the selected object. Click a service’s name to display the service’s configuration screen in the main window.
Priority
If it is applicable, this field lists the referencing configuration item’s position in its list, otherwise N/A displays.
Name
This field identifies the configuration item that references the object.
Description
If the referencing configuration item has a description configured, it displays here.
Refresh
Click this to update the information in this screen.
Cancel
Click Cancel to close the screen.
CLI Messages
Click CLI to look at the CLI commands sent by the Web Configurator. Open the pop-up window and then click some menus in the Web Configurator to display the corresponding commands.
Navigation Panel
Use the navigation panel menu items to open status and configuration screens. Click the arrow in the middle of the right edge of the navigation panel to hide the panel or drag to resize it. The following sections introduce the Zyxel Device’s navigation panel menus and their screens.
Dashboard
The dashboard displays general device information, system status, system resource usage, licensed service status, and interface status in widgets that you can re-arrange to suit your needs.
Monitor Menu
The monitor menu screens display status and statistics information.
Monitor Menu Screens Summary
Folder or Link
Tab
Function
Traffic Statistics
Port Statistics
Port Statistics
Displays packet statistics for each physical port.
Interface Status
Interface Summary
Displays general interface information and packet statistics.
Traffic Statistics
Traffic Statistics
Collect and display traffic statistics.
Session Monitor
Session Monitor
Displays the status of all current sessions.
Network Status
DHCP Table
DHCP Table
Displays a list of interfaces and their DHCP-assigned IP addresses.
Device Insight
Device Insight
Displays a list of WiFi and wireless clients connected to the Zyxel Device networks.
Login Users
Login Users
Lists the users currently logged into the Zyxel Device.
Dynamic Guest
Dynamic Guest
List the dynamic guest accounts in the Zyxel Device’s local database. These are accounts that are created automatically and allowed to access the Zyxel Device’s services for a certain period of time.
IGMP Statistics
IGMP Statistics
Collect and display IGMP statistics.
DDNS Status
DDNS Status
Displays the status of the Zyxel Device’s DDNS domain names.
IP/MAC Binding
IP/MAC Binding
Lists the devices that have received an IP address from Zyxel Device interfaces using IP/MAC binding.
Cellular Status
Cellular Status
Displays details about the Zyxel Device’s mobile broadband connection status.
UPnP Port Status
Port Statistics
Displays details about UPnP connections going through the Zyxel Device.
USB Storage
Storage Information
Displays details about USB device connected to the Zyxel Device.
Ethernet Neighbor
Ethernet Neighbor
View and manage the Zyxel Device’s neighboring devices through Smart Connect (Layer Link Discovery Protocol (LLDP)). Use the Zyxel One Network (ZON) utility to view and manage the Zyxel Device’s neighboring devices through the Zyxel Discovery Protocol (ZDP).
FQDN Object
FQDN Object
Displays FQDN (Fully Qualified Domain Name) object cache lists used in DNS queries.
Virtual Server LB
Virtual Server Load Balancer Status
Displays traffic statistics between a client and a real server.
Wireless
AP Information
AP List
Lists APs managed by the Zyxel Device.
Radio List
Lists wireless details of APs managed by the Zyxel Device.
Built-in AP
Displays associated wireless client usage and number. (For Zyxel Device model names containing ‘W’.)
Top N APs
Lists managed APs with the most wireless traffic usage and most associated wireless stations.
Single AP
Lists APs wireless traffic usage and associated wireless stations for a managed AP.
ZyMesh
ZyMesh Link Info
Display statistics about ZyMesh wireless connections between managed APs.
SSID Info
SSID Info
Display information about the AP’s wireless clients.
Station Info
Station List
Lists wireless clients associated with the APs managed by the Zyxel Device.
Top N Stations
Lists wireless stations with the most wireless traffic usage.
Single Station
Lists wireless traffic usage for an associated wireless station.
Detected Device
Detected Device
Display information about suspected rogue APs.
Wireless Health
Wireless Health
Displays information about health or wireless networks for your APs and connected wireless clients.
Printer Status
Printer Status
Display information about the connected statement printers.
VPN Monitor
IPSec
IPSec
Displays and manages the active IPSec SAs.
SSL
SSL
Lists users currently logged into the VPN SSL client portal. You can also log out individual users and delete related session information.
L2TP over IPSec
L2TP over IPSec
Displays details about current L2TP sessions.
Remote AP VPN
Remote AP VPN
Displays and manages the active remote APs.
Security Statistics
App Patrol
Summary
Displays application patrol statistics.
Content Filter
Web Content Filter
Collect and display web content filter statistics.
DNS Content Filter
Collect and display DNS content filter statistics.
Anti-Malware
Summary
Collect and display statistics on the malware that the Zyxel Device has detected.
Reputation Filter
Summary
Displays counts, IP addresses and URLs that are blocked by the Zyxel Device.
IPS
Summary
Collect and display statistics on the intrusions that the Zyxel Device has detected.
Sandboxing
Summary
Displays the sandboxing statistics.
Email Security
Summary
Collect and display spam statistics.
Status
Displays how many mail sessions the ZyWALL is currently checking and DNSBL (Domain Name Service-based spam Black List) statistics.
CDR
Containment List
Displays what clients are currently contained by Collaborative Detection & Response (CDR).
History
Displays what clients were and are contained by Collaborative Detection & Response (CDR).
SSL Inspection
Summary
Collect and display SSL Inspection statistics.
Certificate Cache List
Displays traffic to destination servers using certificates.
Log
View Log
Lists log entries.
View AP Log
Lists AP log entries.
Dynamic Users Log
Lists the Zyxel Device’s dynamic guest account log messages.
Configuration Menu
Use the configuration menu screens to configure the Zyxel Device’s features.
Configuration Menu Screens Summary
Folder or Link
Tab
Function
Quick Setup
Quickly configure WAN interfaces or VPN connections.
Licensing
Registration
Registration
Register the device and activate trial services.
Service
View the licensed service status and upgrade licensed services.
Signature Update
Signature
Update signatures immediately or by a schedule.
Wireless
Built-in AP
General
Allow WiFi clients to access your Zyxel Device wirelessly to connect to the network.
Controller
Configuration
Configure manual or automatic controller registration.
AP Management
Mgnt AP List
Edit or remove entries in the lists of APs managed by the Zyxel Device.
AP Policy
Configure the AP controller’s IP address on the managed APs and determine the action the managed APs take if the current AP controller fails.
AP Group
Create groups of APs, define their radio, VLAN, port and load balancing settings.
Firmware
Update the firmware on APs connected to your Zyxel Device.
Rogue AP
Rogue/Friendly AP List
Configure how the Zyxel Device monitors rogue APs.
Wireless Health
Wireless Health
Enable wireless health to improve the APs wireless network performance in Zyxel Device networks.
Auto Healing
Auto Healing
Enable auto healing to extend the wireless service coverage area of the managed APs when one of the APs fails.
RTLS
Real Time Location System
Use the managed APs as part of an Ekahau RTLS to track the location of Ekahau WiFi tags.
Network
Interface
Port
Port Role/Port Group/ Port Configuration
Use this screen to set the Zyxel Device’s flexible ports such as LAN, OPT, WLAN, or DMZ.
Ethernet
Manage Ethernet interfaces and virtual Ethernet interfaces.
PPP
Create and manage PPPoE and PPTP interfaces.
Cellular
Configure a cellular Internet connection for an installed mobile broadband card.
Tunnel
Configure tunneling between IPv4 and IPv6 networks.
VLAN
Create and manage VLAN interfaces and virtual VLAN interfaces.
Bridge
Create and manage bridges and virtual bridge interfaces.
LAG
Configure interface and LAG parameters for each LAG interface.
VTI
Configure IP address assignment and interface parameters for VTI (Virtual Tunnel Interface).
Trunk
Create and manage trunks (groups of interfaces) for load balancing.
Routing
Policy Route
Create and manage routing policies.
Static Route
Create and manage IP static routing information.
RIP
Configure device-level RIP settings.
OSPF
Configure device-level OSPF settings, including areas and virtual links.
BGP
Configure exchange of Border Gateway Protocol (BGP) information over an IPSec tunnel.
DDNS
DDNS
Define and manage the Zyxel Device’s DDNS domain names.
NAT
NAT
Set up and manage port forwarding rules.
Configure virtual server load balancer rules that distribute incoming connection requests to a virtual server between multiple real (physical) servers
Redirect Service
Redirect Service
Set up and manage HTTP and SMTP redirection rules.
ALG
ALG
Configure SIP, H.323, and FTP pass-through settings.
UPnP
UPnP
Configure interfaces that allow UPnP and NAT-PMP connections.
IP/MAC Binding
Summary
Configure IP to MAC address bindings for devices connected to each supported interface.
Exempt List
Configure ranges of IP addresses to which the Zyxel Device does not apply IP/MAC binding.
Layer 2 Isolation
General
Enable layer-2 isolation on the Zyxel Device and the internal interfaces.
Allow List
Enable and configure the allow list.
DNS Inbound LB
DNS Load Balancing
Configure DNS Load Balancing.
VPN
IPSec VPN
VPN Connection
Configure IPSec tunnels.
VPN Gateway
Configure IKE tunnels.
Concentrator
Combine IPSec VPN connections into a single secure network
Configuration Provisioning
Set who can retrieve VPN rule settings from the Zyxel Device using the Zyxel Device IPSec VPN Client.
SSL VPN
Access Privilege
Configure SSL VPN access rights for users and groups.
Global Setting
Configure the Zyxel Device’s SSL VPN settings that apply to all connections.
L2TP VPN
L2TP VPN
Configure L2TP over IPSec tunnels.
Remote AP VPN
Remote AP VPN
Configure the IP address pool for the Zyxel Device to assign an IP address to the outgoing interface of each RAP IPSec tunnel.
BWM
BWM
Enable and configure bandwidth management rules.
Web Authentication
Web Authentication
General/Authentication Type/Custom Web Portal File/Custom User Agreement File
Define a web portal and exempt services from authentication.
SSO
Configure the Zyxel Device to work with a Single Sign On agent.
Hotspot
Billing
General
Configure the general billing settings, such as the accounting method.
Billing Profile
Configure the billing profiles for the web-based account generator and each button on the connected statement printer.
Discount
Configure discount price plans.
Payment Service
Enable online payment service and configure the service pages.
Printer Manager
General
Configure the printer list, enable printer management and customize the account printout.
Printout Configuration
Detect the connected statement printers, change their IP addresses and/or add them to the managed printer list.
Free Time
Free Time
Allow users to get a free account for Internet surfing during the specified time period.
IPnP
IPnP
Enable IPnP on the Zyxel Device and the internal interfaces.
Walled Garden
Walled Garden
General/URL Base/Domain/IP Base
Create walled garden links that display in the login screen.
Advertisement
Advertisement
Enable and set advertisement links.
Security Policy
Policy Control
Policy
Create and manage level-3 traffic rules and apply Security Service profiles.
ADP
General
Display and manage ADP bindings.
Profile
Create and manage ADP profiles.
Allow List
Create an allow list for certain IP or services to let them pass the ADP flood detection.
Session Control
Session Control
Limit the number of concurrent client NAT/security policy sessions.
Security Service
AppPatrol
Profile
Manage different types of traffic in this screen. Create App Patrol template(s) of settings to apply to a traffic flow using a security policy.
Content Filter
Web Content Filter: General
Create and manage the detailed filtering rules for content filtering profiles and then apply to a traffic flow using a security policy.
Web Content Filter: Trusted Web Sites
Create a list of allowed web sites that bypass content filtering policies.
Web Content Filter: Forbidden Web Sites
Create a list of web sites to block regardless of content filtering policies.
DNS Content Filter: General
Create and manage the detailed filtering rules for DNS content filtering profiles and then apply to a traffic flow using a security policy.
DNS Content Filter: Allow List
Create a list of allowed web sites that bypass DNS content filtering policies.
DNS Content Filter: Block List
Anti-Malware
Anti-Malware
Enable, specify actions to take when encountering malware or compressed files, and set up a black list to identify files with malware file patterns and a white list to identify files that should not be checked for malware.
Block/Allow List
Set up a block list to identify spam and an allow list to identify legitimate email.
Signature
Search for particular signatures to get more information about them.
Reputation Filter
IP Reputation
General/Allow List/Block List/ External Block List
Enable IP reputation and specify what action the Zyxel Device takes when any IP address with bad reputation is detected.
You can also set up an allow list to identify which IPv4 addresses should be allowed, and a block list to identify which IPv4 addresses should be blocked.
Set up an external block list which uses block list entries stored in a file on a web server that supports HTTP or HTTPS and is reachable from the Zyxel Device. The Zyxel Device will block incoming and outgoing packets from the black list entries in this file.
DNS Threat Filter
General/Profile/Allow List/ Block List
Enable DNS threat filtering and specify what action the Zyxel Device takes when a access attempt to a blocked Fully Qualified Domain Name (FQDN) is detected.
You can also set up an allow list to identify which FQDNs should be allowed, and a block list to identify which FQDNs should be blocked.
Enable URL filtering and specify what action the Zyxel Device takes when a access attempt to a blocked website is detected.
You can also set up an allow list to identify which IPv4 addresses and/or URLs should be allowed, and a block list to identify which IPv4 addresses and/or URLs should be blocked.
IPS
IPS
Enable and configure IPS settings. Create, import, or export custom signatures.
Allow List
Configure signatures that will be exempted from IPS inspection.
Sandboxing
Sandboxing
Enable sandboxing, and specify the actions the Zyxel Device takes when malicious or suspicious files are detected.
Email Security
Email Security
Turn email security on or off and manage email security policies. Create email security templates of settings to apply to a traffic flow using a security policy.
Block/Allow List
CDR
Turn CDR on or off and manage CDR policies. Create CDR templates of settings to apply to a traffic flow using a security policy.
Exempt List
Configure IPv4 and/or MAC addresses of devices that are exempt from CDR checking.
SSL Inspection
Profile
Decrypt HTTPS traffic for Security Service inspection. Create SSL Inspection templates of settings to apply to a traffic flow using a security policy.
Exclude List
Configure services to be excluded from SSL Inspection.
Certificate Update
Use this screen to update the latest certificates of servers using SSL connections to the Zyxel Device network.
IP Exception
IP Exception
Use this screen to view the IP exception list for the anti-malware and IPS (Intrusion Prevention System) features.
The Zyxel Device will not intercept nor inspect the incoming packets that match the rules in the IP exception list for the anti-malware and/or IPS (Intrusion Prevention System) features.
Object
Device Insight
Device Insight
Configure profiles to block specified clients from accessing the Internet or the Zyxel Device.
Zone
Zone
Configure zone templates used to define various policies.
User/Group
User
Create and manage users.
Group
Create and manage groups of users.
Setting
Manage default settings for all users, general settings for user sessions, and rules to force user authentication.
MAC Address
Configure the MAC addresses of wireless clients for MAC authentication using the local user database.
AP Profile
Radio
Create templates of radio settings to apply to policies as an object.
SSID
Create templates of wireless settings to apply to radio profiles or policies as an object.
MON Profile
MON Profile
Create and manage rogue AP monitoring files that can be associated with different APs.
ZyMesh Profile
ZyMesh Profile
Create and manage ZyMesh files that can be associated with different APs.
Address/Geo IP
Address
Create and manage host, range, and network (subnet) addresses.
Address Group
Create and manage groups of addresses to apply to policies as a single objects.
Geo IP
Update the database of country-to-IP address mappings and manually configure country-to-IP address mappings for geographic address objects that can be used in security policies.
Service
Service
Create and manage TCP and UDP services.
Service Group
Create and manage groups of services to apply to policies as a single object.
Schedule
Schedule
Create one-time and recurring schedules.
Schedule Group
Create and manage groups of schedules to apply to policies as a single object.
AAA Server
Active Directory
Configure the Active Directory settings.
LDAP
Configure the LDAP settings.
RADIUS
Configure the RADIUS settings.
Auth. Method
Authentication Method
Create and manage ways of authenticating users.
Two-factor Authentication
Configure SMS or email authentication to access the Zyxel Device through a VPN tunnel.
Certificate
My Certificates
Create and manage the Zyxel Device’s certificates.
Trusted Certificates
Import and manage certificates from trusted sources.
ISP Account
ISP Account
Create and manage ISP account information for PPPoE/PPTP interfaces.
DHCPv6
Request
Configure IPv6 DHCP request type and interface information.
Lease
Configure IPv6 DHCP lease type and interface information.
Device HA
Device HA Status
See the license status for Device HA Pro, and see the status of the active and passive devices.
Device HA Pro
Configure Device HA Pro global settings, monitored interfaces and synchronization settings.
View Log
See logs of the active and passive devices
Mgmt. & Analytics
SecuManager
Enable and configure management of the Zyxel Device by a Central Network Management system.
SecuReporter
Enable SecuReporter logging and access the SecuReporter security analytics portal that collects and analyzes logs from your Zyxel Device in order to identify anomalies, alert on potential internal or external threats, and report on network usage.
Nebula
Use this screen to let Nebula manage your Zyxel Device.
System
Host Name
Host Name
Configure the system and domain name for the Zyxel Device.
USB Storage
Settings
Configure the settings for the connected USB devices.
Date/Time
Date/Time
Configure the current date, time, and time zone in the Zyxel Device.
Console Speed
Console Speed
Set the console speed.
DNS
DNS
Configure the DNS server and address records for the Zyxel Device.
WWW
Service Control
Configure HTTP, HTTPS, and general authentication.
Login Page
Configure how the login and access user screens look.
SSH
SSH
Configure SSH server and SSH service settings.
TELNET
TELNET
Configure telnet server settings for the Zyxel Device.
FTP
FTP
Configure FTP server settings.
SNMP
SNMP
Configure SNMP communities and services.
Auth. Server
Auth. Server
Configure the Zyxel Device to act as a RADIUS server.
Notification
Mail Server
Configure a mail server with authentication to send reports and password expiration notification emails.
SMS
Enable the SMS service to send dynamic guest account information in text messages and authorization for VPN tunnel access to a secured network.
Response Message
Create a web page when access to a website is restricted due to a security service.
Language
Language
Select the Web Configurator language.
IPv6
IPv6
Enable IPv6 globally on the Zyxel Device here.
ZON
ZON
Log & Report
Email Daily Report
Email Daily Report
Configure where and how to send daily reports and what reports to send.
Log Settings
Log Settings
Configure the system log, email logs, and remote syslog servers.
Maintenance Menu
Use the maintenance menu screens to manage configuration and firmware files, run diagnostics, and reboot or shut down the Zyxel Device.
Maintenance Menu Screens Summary
Folder or Link
Tab
Function
File Manager
Configuration File
Manage and upload configuration files for the Zyxel Device.
Firmware Management
View the current firmware version and upload firmware. Reboot with your choice of firmware.
Shell Script
Manage and run shell script files for the Zyxel Device.
Diagnostics
Diagnostics
Collect diagnostic information.
This screen includes the sub-tabs below:
Controller
AP
Filer
Packet Capture
Capture packets for analysis.
Capture
Capture on AP
Remote Capture
Files
CPU/Memory Status
View CPU and memory usage statistics.
System Log
Connect a USB device to the Zyxel Device and archive the Zyxel Device system logs to it here.
Network Tool
Identify problems with the connections. You can use Ping or Traceroute to help you identify problems.
Routing Traces
Configure traceroute to identify where packets are dropped for troubleshooting.
Wireless Frame Capture
Capture wireless frames from APs for analysis.
Packet Flow Explore
Routing Status
Check how the Zyxel Device determines where to route a packet.
SNAT Status
View a clear picture on how the Zyxel Device converts a packet’s source IP address and check the related settings.
Shutdown/ Reboot
Shutdown/ Reboot
Turn off or restart the Zyxel Device.
Tables and Lists
Web Configurator tables and lists are flexible with several options for how to display their entries.
Click a column heading to sort the table’s entries according to that column’s criteria.
Click the down arrow next to a column heading for more options about how to display the entries. The options available vary depending on the type of fields in the column. Here are some examples of what you can do:
Sort in ascending or descending (reverse) alphabetical order
Select which columns to display
Group entries by field
Show entries in groups
Filter by mathematical operators (<, >, or =) or searching for text
Select a column heading cell’s right border and drag to re-size the column.
Select a column heading and drag and drop it to change the column order. A green check mark displays next to the column’s title when you drag the column to a valid new location.
Use the icons and fields at the bottom of the table to navigate to different pages of entries and control how many entries display at a time.
The tables have icons for working with table entries. You can often use the [Shift] or [Ctrl] key to select multiple entries to remove, activate, or deactivate.
Here are descriptions for the most common table icons.
Common Table Icons
Label
Description
Add
Click this to create a new entry. For features where the entry’s position in the numbered list is important (features where the Zyxel Device applies the table’s entries in order like the security policy for example), you can select an entry and click Add to create a new entry after the selected entry.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied.
Remove
To remove an entry, select it and click Remove. The Zyxel Device confirms you want to remove it before doing so.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Connect
To connect an entry, select it and click Connect.
Disconnect
To disconnect an entry, select it and click Disconnect.
References
Select an entry and click References to check which settings use the entry.
Move
To change an entry’s position in a numbered list, select it and click Move to display a field to enter a number for where you want to put that entry and press [ENTER] to move the entry to the number that you entered. For example, if you enter 6, the entry you are moving becomes number 6 and the previous entry 6 (if there is one) gets pushed up (or down) one.
Working with Lists
When a list of available entries displays next to a list of selected entries, you can often just double-click an entry to move it from one list to the other. In some lists you can also use the [Shift] or [Ctrl] key to select multiple entries, and then use the arrow button to move them to the other list.
