LED | Color | status | description |
PWR | Off | The Zyxel Device is turned off. | |
Green | On | The Zyxel Device is turned on. | |
Red | On | There is a hardware component failure. Shut down the device, wait for a few minutes and then restart the device. If the LED turns red again, then please contact your vendor. | |
SYS | Green | Off | The Zyxel Device is not ready or has failed. |
On | The Zyxel Device is ready and running. | ||
Blinking | The Zyxel Device is booting. | ||
Red | On | The Zyxel Device has an error or has failed. | |
USB | Green | Off | No device is connected to the Zyxel Device’s USB port or the connected device is not supported by the Zyxel Device. |
On | A mobile broadband USB card or USB storage device is connected to the USB port. | ||
Orange | On | Connected to a mobile broadband network through the connected mobile broadband USB card. | |
P1, P2... | Green | Off | There is no traffic on this port. |
On | This port has a successful 10/100 Mbps link. | ||
Blinking | The Zyxel Device is sending or receiving packets on this port at 10/100 Mbps. | ||
Yellow | Off | There is no connection on this port. | |
On | This port has a successful 1000 Mbps link. | ||
Blinking | The Zyxel Device is sending or receiving packets on this port at 1000 Mbps. |
Label | Description |
RESET | Press the button in for about 5 seconds (or until the SYS LED starts to blink), then release it to return the Zyxel Device to the factory defaults (password is 1234, LAN IP address 192.168.1.1 etc.) |
CONSOLE | You can use the console port to manage the Zyxel Device using CLI commands. You will be prompted to enter your user name and password. See the Command Reference Guide for more information about the CLI. When configuring using the console port, you need a computer equipped with communications software configured to the following parameters: • Speed 115200 bps • Data Bits 8 • Parity None • Stop Bit 1 • Flow Control Off |
USB | Connect a storage device for system logs (see Maintenance > Diagnostics > System Log) and storage (see Configuration > System > USB Storage). |
P1 ~ P6 | These are 1G RJ-45 Ethernet ports. |
Console | You can use the console port to manage the Zyxel Device using CLI commands. You will be prompted to enter your user name and password. See the Command Reference Guide for more information about the CLI. When configuring using the console port, you need a computer equipped with communications software configured to the following parameters: • Speed 115200 bps • Data Bits 8 • Parity None • Stop Bit 1 • Flow Control Off |
Power | Use the included power cord to connect the power socket to a power outlet. Turn the power switch on if your Zyxel Device has a power switch. |
Lock | Attach a lock-and-cable from the Kensington lock (the small, metal-reinforced, oval hole) to a permanent object, such as a pole, to secure the Zyxel Device in place. |
Fan | The fans are for cooling the Zyxel Device. Make sure they are not obstructed to allow maximum ventilation. |
CONSOLE PORT / RJ-45 PIN | SIGNAL | DB-9 PIN |
1 | DTR | 6 |
2 | DSR | 4 |
3 | RxD | 3 |
4 | CTS | 7 |
5 | GND | 5 |
6 | TxD | 2 |
7 | RTS | 8 |
8 | NC | 1, 9 |
Signal | Signal Name |
RxD | Receive Data |
TxD | Transmit Data |
DTR | Data Terminal Ready |
GND | Ground |
DSR | Data Set Ready |
RTS | Request to Send |
CTS | Clear to Send |
RI | Ring Indicator |
NC | Not Connected |
model name | Distance “X” |
USG FLEX 50 (USG20-VPN) | 174 mm (6.85”) |
USG FLEX 50W (USG20W-VPN) | 174 mm (6.85”) |
port / interface | p1 | p2 | p3 | p4 | p5 | p6 | p7 | p8 |
USG FLEX 50 (USG20-VPN) | sfp | wan | lan1 | lan1 | lan1 | lan1 | ||
USG FLEX 50AX | wan | lan1 | lan1 | lan1 | opt | |||
USG20W-VPN | sfp | wan | lan1 | lan1 | lan1 | lan1 |
Zone / interface | wan | lan1 | lan2 | dmz | opt | no default zone |
USG FLEX 50 (USG20-VPN)/ USG FLEX 50AX/ USG20W-VPN | WAN WAN_PPP | LAN1 | LAN2 | DMZ | OPT OPT_PPP |
