Label | Description |
Enable Free Time | Select the checkbox to turn on the free time feature. |
Free Time Period | Select the duration of time period for which the free time account is allowed to access the Internet. |
Reset Time | Select Daily to have the Zyxel Device allow free account access every day at the specified time. Select Weekly to have the Zyxel Device allow free account access once a week on the day you select. Select Monthly to have the Zyxel Device allow free account access once a month on a set date. When your free period ends, you will see a message telling you when you can use free time again. This depends on the Reset Time period chosen. |
Time | If you select Daily, select the time in 24-hour format at which the new free time account is allowed to access the Internet. |
Day | If you select Weekly, select the day on which the new free time account is allowed to access the Internet. If you select Monthly, enter the date on which the new free time account is allowed to access the Internet. If the date you selected is not available in a month, such as 30th or 31th, the Zyxel Device allows the free account access on the last day of the month. |
Maximum Registration Number Before Reset Time | Enter the maximum number of users that are allowed to log in for Internet access with a free guest account before the time specified in the Reset Time field. This also sets how many free guest accounts a user can get. For example, if you set the Maximum Registration Number Before Reset Time to 1, the Reset Time to Daily and the Reset Time to 13:00, even the first free guest account has expired at 11:30, the user cannot get a second account and/or access the Internet until 13:00. |
Delivery Method | Specify how the Zyxel Device provides dynamic guest account information. Select On-Screen to display the user account information in the web screen. Select SMS to use Short Message Service (SMS) to send account information in a text message to the user’s mobile device. Select On-Screen and SMS to provide the account information both in the web screen and through SMS text messages. |
Auto Login | Select this to allow users to log into their free account directly without having to enter their user name and password. Clearing this requires users to enter their user name and password, and click login to access their free account. |
Hotspot Service Status | |
Service Status | This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service. If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license. Then, click Activate to connect with the myZyxel server to activate the new license. |
Service Type | This shows whether you have a trial or standard license or none (Trial, Standard, None). |
Expiration Date | This shows when your hotspot license will expire. |
Apply | Click this button to save your changes to the Zyxel Device. |
Reset | Click this button to return the screen to its last-saved settings. |
Enable IPnP | Select this option to turn on the IPnP feature on the Zyxel Device. |
Member List | The Available list displays the name(s) of the internal interface(s) on which you can enable IPnP. To enable IPnP on an interface, you can double-click a single entry to move it or use the [Shift] or [Ctrl] key to select multiple entries and click the right arrow button to add to the Member list. To remove an interface, select the name(s) in the Member list and click the left arrow button. |
Register Now | Click the link to go to myZyxel where you can register your Zyxel Device and activate the service. This link is available only when the service is not activated yet. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
