Monitor
Overview
Use the Monitor screens to check status and statistics information.
Rogue AP
Rogue APs are wireless access points operating in a network’s coverage area that are not under the control of the network’s administrators, and can open up holes in a network’s security.
Friendly AP
Friendly APs are other wireless access points that are detected in your network, as well as any others that you know are not a threat (those from neighboring networks, for example).
Network Status
Use this screen to look at general Ethernet interface information and packet statistics.
Monitor > Network Status
Label
Description
Interface Summary/IPv6 Interface Summary
Use the Interface Summary section for IPv4 network settings. Use the IPv6 Interface Summary section for IPv6 network settings if you connect your Zyxel Device to an IPv6 network. Both sections have similar fields as described below.
Name
This field displays the name of the physical Ethernet port on the Zyxel Device.
Status
This field displays the current status of each physical port on the Zyxel Device.
Down - The port is not connected.
Speed / Duplex - The port is connected. This field displays the port speed and duplex setting (Full or Half).
VID
This field displays the VLAN ID to which the port belongs.
IP Addr/Netmask
IP Address
This field displays the current IP address (and subnet mask) of the interface. If the IP address is 0.0.0.0 (in the IPv4 network) or :: (in the IPv6 network), the interface does not have an IP address yet.
IP Assignment
This field displays how the interface gets its IPv4 address.
Static - This interface has a static IPv4 address.
DHCP Client - This interface gets its IPv4 address from a DHCP server.
Action
Use this field to get or to update the IP address for the interface. Click Renew to send a new DHCP request to a DHCP server. If the interface cannot use one of these ways to get or to update its IP address, this field displays n/a.
Port Statistics Table
Poll Interval
Enter how often you want this window to be updated automatically, and click Set Interval.
Set Interval
Click this to set the Poll Interval the screen uses.
Stop
Click this to stop the window from updating automatically. You can start it again by setting the Poll Interval and clicking Set Interval.
Switch to Graphic View
Click this to display the port statistics as a line graph.
Name
This field displays the name of the interface.
Status
This field displays the current status of the physical port.
Down - The physical port is not connected.
Speed / Duplex - The physical port is connected. This field displays the port speed and duplex setting (Full or Half).
TxPkts
This field displays the number of packets transmitted from the Zyxel Device on the physical port since it was last connected.
RxPkts
This field displays the number of packets received by the Zyxel Device on the physical port since it was last connected.
Tx Bcast
This field displays the number of broadcast packets transmitted from the Zyxel Device on the physical port since it was last connected.
Rx Bcast
This field displays the number of broadcast packets received by the Zyxel Device on the physical port since it was last connected.
Collisions
This field displays the number of collisions on the physical port since it was last connected.
Tx
This field displays the transmission speed, in bytes per second, on the physical port in the one-second interval before the screen updated.
Rx
This field displays the reception speed, in bytes per second, on the physical port in the one-second interval before the screen updated.
Up Time
This field displays how long the physical port has been connected.
System Up Time
This field displays how long the Zyxel Device has been running since it last restarted or was turned on.
Port Statistics Graph
Use the port statistics graph to look at a line graph of packet statistics for the Ethernet port.
Monitor > Network Status > Switch to Graphic View
Label
Description
General Settings
Refresh Interval
Enter how often you want this window to be automatically updated.
Refresh Now
Click this to update the information in the window right away.
Port Usage
Port Selection
Select the Ethernet port for which you want to view the packet statistics.
This is only available for Zyxel Device models that support more than one Ethernet port.
Switch to Grid View
Click this to display the port statistics as a table.
Kbps/Mbps
The y-axis represents the speed of transmission or reception.
Time
The x-axis shows the time period over which the transmission or reception occurred.
TX
This line represents traffic transmitted from the Zyxel Device on the physical port since it was last connected.
RX
This line represents the traffic received by the Zyxel Device on the physical port since it was last connected.
Last Update
This field displays the date and time the information in the window was last updated.
Radio List
Use this screen to view statistics for the Zyxel Device’s WiFi radio transmitters.
Monitor > Wireless > AP Information > Radio List
Label
Description
More Information
Click this to view additional information about the selected radio’s wireless traffic and station count. Information spans a 24 hour period.
Status
This displays whether or not the radio is enabled.
Loading
This indicates the AP’s load balance status (UnderLoad or OverLoad) when load balancing is enabled on the Zyxel Device. Otherwise, it shows - when load balancing is disabled.
This is only available if your Zyxel Device supports Load Balancing. See Zyxel Device Product Feature Comparison for the supported models list.
Frequency Band
This indicates the wireless frequency band currently being used by the radio.
Channel
This indicates the radio’s channel ID.
Transmit Power
This displays the output power of the radio.
Station
This displays the number of WiFi clients connected to this radio on the Zyxel Device.
Upload
This displays the total number of packets received by the radio.
Download
This displays the total number of packets transmitted by the radio.
MAC Address
This displays the MAC address of the radio.
Radio
This indicates the radio number on the Zyxel Device to which it belongs.
OP Mode
This indicates the radio’s operating mode. Operating modes are AP (MBSSID), Root AP or Repeater.
AP/WDS Profile
This indicates the AP profile name and WDS profile name to which the radio belongs.
Channel Utilization
This indicates how much IEEE 802.11 traffic the radio can receive on the channel. It displays what percentage of the radio’s channel is currently being used.
AP Mode Radio Information
This screen allows you to view a selected radio’s SSID details, wireless traffic statistics and station count for the preceding 24 hours.
Monitor > Wireless > AP Information > Radio List > More Information
Label
Description
SSID Detail
This list shows information about all the WiFi clients that have connected to the specified radio over the preceding 24 hours.
This is the items sequential number in the list. It has no bearing on the actual data in this list.
SSID Name
This displays an SSID associated with this radio. There can be up to eight maximum.
BSSID
This displays a BSSID associated with this radio. The BSSID is tied to the SSID.
Security Mode
This displays the security mode in which the SSID is operating.
VLAN
This displays the VLAN ID associated with the SSID.
Traffic Statistics
This graph displays the overall traffic information of the radio over the preceding 24 hours.
bps/Kbps/Mbps
This y-axis represents the amount of data moved across this radio in megabytes per second.
Time
This x-axis represents the amount of time over which the data moved across this radio.
TX
This line represents traffic transmitted from the Zyxel Device on this radio.
RX
This line represents the traffic received by the Zyxel Device on this radio.
Station Count
This graph displays the connected station information of the radio over the preceding 24 hours
Stations
The y-axis represents the number of connected stations.
Time
The x-axis shows the time period over which a station was connected.
Last Update
OK
Click this to save the changes.
Cancel
Click this to close this window.
Station List
Use this screen to view statistics pertaining to the associated stations (or “WiFi clients”). Click Monitor > Wireless > Station Info > Station List to access this screen.
Label
Description
This is the station’s index number in this list.
IP Address
This is the station’s IP address.
Band
This is the frequency band to which the station is connected.
MAC Address
This is the station’s MAC address.
Radio
This is the radio number on the Zyxel Device to which the station is connected.
802.11 Features
This displays whether the station supports IEEE802.11r, IEEE 802.11k, IEEE 802.11v or none of the above (N/A).
Capability
This displays the supported standard currently being used by the station or the standards supported by the station.
SSID Name
This indicates the name of the WiFi network to which the station is connected. A single AP can have multiple SSIDs or networks.
Security Mode
This indicates which secure encryption methods is being used by the station to connect to the network.
Signal Strength
This is the RSSI (Received Signal Strength Indicator) of the station’s WiFi connection.
Rx Rate
This is the maximum reception rate of the station.
Tx Rate
This is the maximum transmission rate of the station.
Association Time
This displays the time the station first associated with the Zyxel Device’s WiFi network.
Refresh
Click this to refresh the items displayed on this page.
WDS Link Info
Use this screen to view the WDS traffic statistics between the Zyxel Device and a root AP or repeaters. See Zyxel Device Roles to know more about WDS.
Monitor > Wireless > WDS Link Info
Label
Description
WDS Uplink/Downlink Info
Uplink refers to the WDS link from the repeaters to the root AP.
Downlink refers to the WDS link from the root AP to the repeaters.
When the Zyxel Device is in root AP mode and connected to a repeater, only the downlink information is displayed.
When the Zyxel Device is in repeater mode and connected to a root AP directly or through another repeater, the uplink information is displayed.
When the Zyxel Device is in repeater mode and connected to a root AP and other repeater(s), both the uplink and downlink information would be displayed.
This is the index number of the root AP or repeater in this list.
MAC Address
This is the MAC address of the root AP or repeater to which the Zyxel Device is connected using WDS.
Band
This is the frequency band of the WiFi network to which the Zyxel Device is connected using WDS.
Radio
This is the radio number on the root AP or repeater to which the Zyxel Device is connected using WDS.
SSID Name
This indicates the name of the WiFi network to which the Zyxel Device is connected using WDS.
Security Mode
This indicates which secure encryption methods is being used by the Zyxel Device to connect to the root AP or repeater using WDS.
Signal Strength
This is the RSSI (Received Signal Strength Indicator) of the wireless connection in WDS.
Tx Rate
This is the maximum transmission rate of the root AP or repeater to which the Zyxel Device is connected using WDS.
Rx Rate
This is the maximum reception rate of the root AP or repeater to which the Zyxel Device is connected using WDS.
Association Time
This displays the time the Zyxel Device first associated with the wireless network using WDS.
Refresh
Detected Device
Use this screen to view information about surrounding APs which you could mark as Rogue or Friendly. For more information about Rogue APs, see Rogue AP.
*Turn on Enable Rogue AP Detection in the Configuration > Wireless > Rogue AP screen to detect other APs.
Monitor > Wireless > Detected Device
Label
Description
Discovered APs
Rogue AP
This shows how many devices are detected as rogue APs.
Suspected rogue AP
This shows how many devices are detected as possible rogue APs based on the classification rule(s) in Rogue AP.
Friendly AP
This shows how many devices are detected as friendly APs.
Un-classified AP
This shows how many devices are detected, but have not been classified as either Rogue or Friendly by the Zyxel Device.
Detect Now
Click this button for the Zyxel Device to scan for APs in the network.
Detected Device
Mark as Rogue AP
Click this button to mark the selected AP as a rogue AP. For more on managing rogue APs, see the Configuration > Wireless > Rogue AP screen.
Mark as Friendly AP
Click this button to mark the selected AP as a friendly AP. For more on managing friendly APs, see the Configuration > Wireless > Rogue AP screen.
This is the detected device’s index number in this list.
Role
This indicates the detected device’s role (such as friendly or rogue).
Classified by
This indicates the detected device’s classification rule.
MAC Address
This indicates the detected device’s MAC address.
SSID Name
This indicates the detected device’s SSID.
Band
Channel ID
This indicates the detected device’s channel ID.
802.11 Mode
This indicates the 802.11 mode (a/b/g/n/ac/ax) transmitted by the detected device.
Security
This indicates the encryption method (if any) used by the detected device.
Description
This displays the detected device’s description. For more on managing friendly and rogue APs, see the Configuration > Wireless > Rogue AP screen (Rogue AP).
Last Seen
This indicates the last time the device was detected by the Zyxel Device.
Refresh
View Log
Log messages are stored in two separate logs, one for regular log messages and one for debugging messages. In the regular log, you can look at all the log messages by selecting All Logs, or you can select a specific category of log messages (for example, user). You can also look at the debugging log by selecting Debug Log. All debugging messages have the same priority.
*When a log reaches the maximum number of log messages, new log messages automatically overwrite existing log messages, starting with the oldest existing log message first.
Events that generate an alert (as well as a log message) display in red. Regular logs display in black. Click a column’s heading cell to sort the table entries by that column’s criteria. Click the heading cell again to reverse the sort order.
The Web Configurator saves the filter settings once you click Search. If you leave the View Log screen and return to it later, the last filter settings would still apply.
Monitor > Log > View Log
Label
Description
Show Filter or Hide Filter
Click this button to show or hide the filter settings.
The Priority, Source Address, Destination Address, Source Interface, Destination Interface, Protocol, Keyword, and Search fields are only available if the filter settings are shown.
Display
Select the category of log message(s) you want to view. You can also view All Logs at one time, or you can view the Debug Log.
Priority
This displays when you show the filter. Select the priority of log messages to display. The log displays the log messages with this priority or higher. Choices are: any, emerg, alert, crit, error, warn, notice, and info, from highest priority to lowest priority. This field is read-only if the Category is Debug Log.
Source Address
This displays when you show the filter. Type the source IP address of the incoming packet that generated the log message. Do not include the port in this filter.
Destination Address
This displays when you show the filter. Type the IP address of the destination of the incoming packet when the log message was generated. Do not include the port in this filter.
Source Interface
This displays when you show the filter. Select the source interface of the packet that generated the log message.
This displays when you show the filter. Select the destination interface of the packet that generated the log message.
Protocol
This displays when you show the filter. Select a service protocol whose log messages you would like to see.
Keyword
This displays when you show the filter. Type a keyword to look for in the Message, Source, Destination and Note fields. If a match is found in any field, the log message is displayed. You can use up to 63 alphanumeric characters and the underscore, as well as punctuation marks ()’ ,:;?! +-*/= #$% @ ; the period, double quotes, and brackets are not allowed.
Search
This displays when you show the filter. Click this button to update the log using the current filter settings.
Email Log Now
Click this button to send log messages to the Active email addresses specified in the Send Log To field on the Configuration > Log & Report > Log Settings screen.
Refresh
Click this to update the list of logs.
Clear Log
Click this button to clear the whole log, regardless of what is currently displayed on the screen.
This field is a sequential value, and it is not associated with a specific log message.
Time
This field displays the time the log message was recorded.
Priority
This field displays the priority of the log message. It has the same range of values as the Priority field above.
Category
This field displays the log that generated the log message. It is the same value used in the Display and (other) Category fields.
Message
This field displays the reason the log message was generated. The text “[count=x]”, where x is a number, appears at the end of the Message field if log consolidation is turned on and multiple entries were aggregated to generate into this one.
Source
This field displays the source IP address and the port number in the event that generated the log message.
Source Interface
This field displays the source interface of the packet that generated the log message.
Destination
This field displays the destination IP address and the port number of the event that generated the log message.
This field displays the destination interface of the packet that generated the log message.
Protocol
This field displays the service protocol in the event that generated the log message.
Note
This field displays any additional information about the log message.
