LEDs
Overview
The LEDs of your Zyxel Device can be controlled such that they stay lit (ON) or OFF after the Zyxel Device is ready. There are two features that control the LEDs of your Zyxel Device – Locator and Suppression.
Suppression
The LED Suppression feature allows you to control how the LEDs of your Zyxel Device behave after it is ready. The default LED suppression setting of your AP is different depending on your Zyxel Device model.
You can go to the Maintenance > LEDs > Suppression screen to see the default LED behavior and change the LED suppression setting. After you make changes in the suppression screen, it will be stored as the default when the Zyxel Device is restarted. See (Zyxel Device Product Feature Comparison) for information on default values for different models.
*When the Zyxel Device is booting or performing firmware upgrade, the LEDs will light up regardless of the setting in LED suppression.
The following table describes fields in the above screen.
Maintenance > LED > Suppression
label
description
Suppression On
If the Suppression On checkbox is checked, the LEDs of your Zyxel Device will turn off after it’s ready.
If the checkbox is unchecked, the LEDs will stay lit after the Zyxel Device is ready.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Locator
The Locator feature identifies the location of your Zyxel Device among several devices in the network. You can run this feature and set a timer in this screen.
To run the locator feature, enter a number of minutes and click Turn On button to have the Zyxel Device find its location. The Locator LED will start to blink for the number of minutes set in the Locator screen. The default setting is 10 minutes. While the locator is running, the turn on button will gray out and return after it’s finished. If you make changes to the time default setting, it will be stored as the default when the Zyxel Device restarts.
*The Locator feature is not affected by the Suppression setting.
Maintenance > LED > Locator
label
description
Turn On / Turn Off
Click Turn On button to activate the locator. The Locator function will show the actual location of the Zyxel Device between several devices in the network.
Otherwise, click Turn Off to disable the locator feature.
Automatically Extinguish After
Enter a time interval between 1 and 60 minutes to stop the locator LED from blinking. Default is 10 minutes.
Apply
Click Apply to save changes in this screen.
Refresh
Click Refresh to update the information in this screen.
