Wireless
Overview
This chapter discusses how to configure the WiFi network settings in your Zyxel Device.
The following figure provides an example of a WiFi network.
Example of a WiFi Network
The WiFi network is the area within the dotted line. In this WiFi network, devices A and B are called WiFi clients. The WiFi clients use the Zyxel Device to interact with other devices (such as the printer) or with the Internet.
The AP Management screen (AP Management) allows you to manage the Zyxel Device’s general WiFi settings.
The Rogue AP screen (Rogue AP) allows you to assign APs either to the rogue AP list or the friendly AP list.
The DCS screen (DCS) allows you to configure dynamic radio channel selection.
What You Need to Know
The following terms and concepts may help as you read this chapter.
Station / WiFi Client
A station or WiFi client is any WiFi-capable device that can connect to an AP using a WiFi signal.
Dynamic Channel Selection (DCS)
Dynamic Channel Selection (DCS) is a feature that allows an AP to automatically select the radio channel which it broadcasts. For more information, see An Example Three-Channel Deployment.
AP Management
Use this screen to manage the Zyxel Device’s general WiFi settings. Click Configuration > Wireless > AP Management to access this screen.
*Not all Zyxel Devices support the wireless bridge VLAN settings; see Zyxel Device Product Feature Comparison for more information.
Configuration > Wireless > AP Management– AP Mode (for 2.4 GHz and 5 GHz models)
Configuration > Wireless > AP Management (for 2.4 GHz, 5 GHz, and 6 GHz models)
Configuration > Wireless > AP Management– Repeater Mode (for 2.4 GHz and 5 GHz models)
Configuration > Wireless > AP Management– Repeater Mode (for 2.4 GHz, 5 GHz and 6 GHz models)
Configuration > Wireless > AP Management > Setup Wireless Bridge Vlan ID: Wireless Bridge Vlan Setting
Each field is described in the following table.
Label
Description
Radio 1 Setting
Radio 1 Activate
Select the checkbox to enable the Zyxel Device’s first (default) radio.
Radio 1 OP Mode
Select the operating mode for radio 1.
AP Mode means the radio can receive connections from WiFi clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing).
Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a WDS (Wireless Distribution System) to extend its wireless network.
Repeater means the radio can establish a wireless connection with other APs (in either root AP or repeater mode) to form a WDS.
Radio 1 Profile
Select the radio profile the radio uses.
*You can only apply a 2.4G AP radio profile to radio 1. Otherwise, the first radio will not be working.
Add
This button is not available after you configure the Zyxel Device using the wizard.
Click the Add icon ()to open a screen where you can create a new entry. For features where the entry’s position in the numbered list is important (features where the Zyxel Device applies the table’s entries in order like the SSID for example), you can select an entry and click Add to create a new entry after the selected entry.
Radio 1 WDS Profile
This field is available only when the radio is in Root AP or Repeater mode.
Select the WDS profile the radio uses to connect to a root AP or repeater.
Enable WDS Wireless Bridging
If you set the Zyxel Device as a root AP, the radio that’s bridging with the Zyxel Device should be in repeater mode.
Be careful to avoid bridge loops. For example, if your root AP and the Zyxel Device are connected to a switch, and they’re also connected to each other using a WiFi connection. This will create bridge loops.
This field is available only when the radio is in Repeater mode. Select this to enable WDS wireless bridging on the Zyxel Device. See Zyxel Device Roles for more information on Wireless Distribution System (WDS).
Uplink Selection Mode
Select AUTO to have the Zyxel Device automatically use the settings in the applied WDS profile to connect to a root AP or repeater.
Select Manual to have the Zyxel Device connect to the root AP or repeater with the MAC address specified in the Radio 1 Uplink MAC Address field.
This appears if you select Enable WDS Wireless Bridging.
Click this to show the Wireless Bridge Vlan Setting pop-up window. This link is available only when the radio is in Root AP or Repeater mode.
Add
Click this to add an entry in the table.
Remove
Select an entry and click this to remove the selected entry.
This field is a sequential value. It is not associated with any VLAN ID.
Enter a VLAN ID for the wireless bridge. The VLAN IDs you set on your root AP should be the same as the VLAN ID you set here. See Zyxel Device Roles for more information on wireless bridge.
OK
Click OK to save your changes back to the Zyxel Device.
Close
Click Close to close the pop-up window without saving your changes.
Max Output Power
Enter the maximum output power (between 0 to 30 dBm) of the Zyxel Device in this field. If there is a high density of APs in an area, decrease the output power of the Zyxel Device to reduce interference with other APs.
*Reducing the output power also reduces the Zyxel Device’s effective broadcast radius.
MBSSID Settings
Edit
Click the Edit icon ()to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied.
This field shows the index number of the SSID
SSID Profile
This field displays the SSID profile that is associated with the radio profile.
Band
This field displays the frequency bands to which the SSID profile is applicable. If the SSID profile is not applicable to the current radio, the SSID profile will not be enabled.
You can configure the SSID profile’s applicable frequency bands in the Edit SSID Profile screen (click the Edit button next to the profile).
Add
Radio 2 Setting
Radio 2 Activate
This displays if the Zyxel Device has a second radio.
Select the checkbox to enable the Zyxel Device’s second radio.
Radio 2 OP Mode
This displays if the Zyxel Device has a second radio. Select the operating mode for radio 2.
Root AP means the radio acts as an AP and also supports the wireless connections with other APs (in repeater mode) to form a WDS to extend its wireless network.
Radio 2 Profile
This displays if the Zyxel Device has a second radio. Select the radio profile the radio uses.
Radio 2 WDS Profile
Add
Remove
OK
Close
Max Output Power
MBSSID Settings
Edit
Click Edit ()to open a screen where you can modify the entry’s settings. In some tables you can just click a table entry and edit it directly in the table. For those types of tables small red triangles display for table entries with changes that you have not yet applied.
SSID Profile
This field shows the SSID profile that is associated with the radio profile.
Band
This field displays the radio bands to which the SSID profile is applicable. If the SSID profile is not applicable to the current radio, the SSID profile will not be enabled.
You can configure the SSID profile’s applicable radio bands in the Edit SSID Profile screen (click the Edit button next to the profile).
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Rogue AP
Use this screen to enable Rogue AP Detection and import/export a rogue or friendly AP list in a txt file. Click Configuration > Wireless > Rogue AP to access this screen.
Rogue APs
A rogue AP is a wireless access point operating in a network’s coverage area that is not under the control of the network administrator, and which can potentially open up holes in a network’s security.
In the following example, a corporate network’s security is compromised by a rogue AP (RG) set up by an employee at his workstation in order to allow him to connect his notebook computer wirelessly (A). The company’s legitimate WiFi network (the dashed ellipse B) is well-secured, but the rogue AP uses inferior security that is easily broken by an attacker (X) running readily available encryption-cracking software. In this example, the attacker now has access to the company network, including sensitive data stored on the file server (C).
Rogue AP Example
Friendly APs
If you have more than one AP in your WiFi network, you should also configure a list of “friendly” APs. Friendly APs are wireless access points that you know are not a threat. It is recommended that you export (save) your list of friendly APs often, especially if you have a network with a large number of access points. Exported lists show MAC addresses in txt file format separated by line breaks.
Rogue AP Detection
This feature allows the Zyxel Device to monitor the WiFi signals for other wireless APs (see also Radio Frequency (RF) Monitor). Detected APs will appear in the Monitor > Wireless > Detected Device screen, where the Zyxel Device will label APs with the criteria you select in Suspected Rogue AP Classification Rule as a suspected rogue. The APs which you mark as either rogue or friendly APs in the Monitor > Wireless > Detected Device screen will appear in the Wireless > Rogue AP screen. See Zyxel Device Product Feature Comparison to know which models support Rogue AP Detection.
*Enabling Rogue AP Detection might affect the performance of WiFi clients associated with the Zyxel Device.
Label
Description
Rogue AP Detection Setting
Enable Rogue AP Detection
Select this checkbox to detect Rogue APs in the network.
Select the checkboxes (Weak Security (Open, WEP, WPA-PSK), Hidden SSID, SSID Keyword) of the characteristics an AP should have for the Zyxel Device to mark it as a Rogue AP.
Add
Click this to add an SSID Keyword.
Edit
Select an SSID Keyword and click this button to modify it.
Remove
Select an existing SSID keyword and click this button to delete it.
This is the SSID Keyword’s index number in this list.
SSID Keyword
This field displays the SSID Keyword.
Rogue/Friendly AP List
Add
Click this button to add an AP to the list and assign it either friendly or rogue status.
Edit
Select an AP in the list to edit and reassign its status.
Remove
Select an AP in the list to remove.
This field is a sequential value, and it is not associated with any interface.
Role
This field indicates whether the selected AP is a rogue-ap or a friendly-ap. To change the AP’s role, click the Edit button.
MAC Address
This field indicates the AP’s radio MAC address.
Description
This field displays the AP’s description. You can modify this by clicking the Edit button.
Rogue/Friendly AP List Importing/Exporting
These controls allow you to export the current list of rogue and friendly APs or import existing lists.
File Path / Browse / Importing
Enter the file name and path of the list you want to import or click the Browse button to locate it. Once the File Path field has been populated, click Importing to bring the list into the Zyxel Device.
You need to wait a while for the importing process to finish.
Exporting
Click this button to export the current list of either rogue APs or friendly APS.
Apply
Reset
Add/Edit Rogue/Friendly AP List
Click Add or select an AP and click the Edit button in the Configuration > Wireless > Rogue AP table to display this screen.
Configuration > Wireless > Rogue AP > Add/Edit Rogue/Friendly AP List
Label
Description
MAC
Enter the MAC address of the AP you want to add to the list. A MAC address is a unique hardware identifier in the following hexadecimal format: xx:xx:xx:xx:xx:xx where xx is a hexadecimal number separated by colons.
Description
Enter up to 60 characters for the AP’s description. Spaces and underscores are allowed.
Role
Select either Rogue AP or Friendly AP for the AP’s role.
OK
Cancel
Click Cancel to close the window with changes unsaved.
DCS
Use this screen to configure dynamic radio channel selection (see Dynamic Channel Selection (DCS) ).Click Configuration > Wireless > DCS to access this screen.
Label
Description
DCS Now
Click this to have the Zyxel Device scan for and select an available channel immediately.
Apply
Reset
Technical Reference
The following section contains additional technical information about the features described in this chapter.
When numerous APs broadcast within a given area, they introduce the possibility of heightened radio interference, especially if some or all of them are broadcasting on the same radio channel. If the interference becomes too great, then the network administrator must open his AP configuration options and manually change the channel to one that no other AP is using (or at least a channel that has a lower level of interference) in order to give the connected stations a minimum degree of interference. Dynamic channel selection frees the network administrator from this task by letting the AP do it automatically. The AP can scan the area around it looking for the channel with the least amount of interference.
In the 2.4 GHz spectrum, each channel from 1 to 13 is broken up into discrete 22 MHz segments that are spaced 5 MHz apart. Channel 1 is centered on 2.412 GHz while channel 13 is centered on 2.472 GHz.
Three channels are situated in such a way as to create almost no interference with one another if used exclusively: 1, 6 and 11. When an AP broadcasts on any of these 3 channels, it should not interfere with neighboring APs as long as they are also limited to same trio.
An Example Four-Channel Deployment
However, some regions require the use of other channels and often use a safety scheme with the following four channels: 1, 4, 7 and 11. While they are situated sufficiently close to both each other and the three so-called “safe” channels (1,6 and 11) that interference becomes inevitable, the severity of it is dependent upon other factors: proximity to the affected AP, signal strength, activity, and so on.
Finally, there is an alternative four channel scheme for ETSI, consisting of channels 1, 5, 9, 13. This offers significantly less overlap that the other one.
An Alternative Four-Channel Deployment
