MSP Alert Templates
The MSP administrator can configure MSP alert template to monitor Nebula Devices for unexpected events (for example, online / offline events). This screen will list the alert templates you have created. See Alert Settings for details on creating an alert template.
To access this screen, click MSP > MSP cross-org manage > Alert templates in the navigation panel.
Label
Description
+ Create
Click this button to add a new alert template (see Alert Settings).
Delete
Click this button to remove alert templates already created.
Search
Specify your desired search criteria to filter the list of alerts.
selected in
This shows the number of alerts that match your filter criteria after you perform a search.
Template
This shows the number of alert templates you have created.
Name
This shows a descriptive name of the alert template.
Description
This shows more details on the alert template.
Creator
This shows your email address.
Bound organizations
This shows All organizations or a list of the selected organizations to send alerts to.
Exclude sites
This shows the sites that will not receive any alerts.
Enable
Click this to activate the alert template.
*To edit the Name, Description, Creator, Bound organizations, and Exclude sites fields, just click the field and the Update alert screen will appear.
Alert Settings
Use this screen to set which alerts are created and emailed, and set the email addresses to which an alert is sent. Click MSP > MSP cross-org manage > Alert templates > Create to access this screen.
*NCC’s Smart Alert Engine uses knowledge of network topology and cross-device functionality to only generate alerts for unexpected events. This helps avoids unnecessary emails and notifications.
For example, an AP is receiving power from a PoE switch. If the AP loses power because its Ethernet cable is disconnected, NCC generates an alert. If the AP loses power because the switch has a PoE schedule that disables power to the AP, NCC does not generate an alert.
MSP > MSP cross-org manage > Alert templates > Create/Update alert
Label
Description
General
Template name
Enter a descriptive name for the alert template (up to 64 alphanumeric characters including spaces).
Description
Enter more details of the alert template (up to 64 alphanumeric characters including spaces).
Email recipient
Enter the email addresses to which you want to send alerts.
Apply to
Select All organizations or specify the selected organizations to send alerts to.
Exclude sites
Select the sites in organizations that will not receive any alerts.
Enable
System alerts
Notification Type
For each alert, you can set how to receive alert notifications:
• Email: Alert notifications are sent by email to configured recipients.
• In-app Push: Alert notifications are sent to site administrators who are logged into the Nebula Mobile app. This type of notification is not available for some features.
• Both: Alert notifications are sent by email and app notification.
• Disable: No alerts are sent.
Show additional recipients
Add additional user accounts who will receive email and in-app notifications for the alert.
Hide additional recipients
Do not show the additional user accounts who will receive email and/or in-app notifications for the alert.
System alerts
Wireless
Specify how long in minutes the NCC waits before generating and sending an alert when an access point goes offline.
WiFi Aid
Specify how long (15/30 minutes / 1 hour) the NCC waits before generating and sending an alert.
Select the items to have the NCC generate and send an alert by email when the following events has reached the threshold (maximum 999):
• WiFi clients with failed connection attempts (WiFi connection / DHCP failures / DNS failures).
• WiFi clients with failed WiFi connection attempts.
• WiFi clients with DHCP failures.
• WiFi clients with DNS failures.
Switches
Specify how long in minutes (5/10/15/30/60) the NCC waits before generating and sending an alert when a port or a Switch or a stacking member goes offline, when the Switch temperature rises above the threshold, or the fan is functioning above the normal speed.
Port advisor
Specify how long (15/30 minutes / 1 hour) the NCC waits before generating and sending an alert when the following events occur:
• Storm guard: A broadcast/multicast-storm event occurs when the number of broadcast /multicast packets per second that the Nebula Device accepts on the ports exceeds the threshold set in Site-wide > Configure > Switches > Port: Broadcast Limit (pps) and Site-wide > Configure > Switches > Port: Multicast Limit (pps).
• Cable health: A Poor cable quality hit is triggered when Port advisor detects that the network cable is damaged.
• PoE detection: A PoE event occurs when any of the following conditions are met:
PoE short-circuit – There is a short circuit detected between the port and the PD (powered device).
PoE overload – The PD requested more PoE power than the port allows.
PoE power management – The PD is unable to get PoE power based on its PoE priority setting in Site-wide > Configure > Switches > Switch ports.
• Bandwidth pulse – Port bandwidth has exceeded N percentage: A bandwidth pulse event occurs when any of the following conditions are met:
RX bandwidth usage exceeded the specified threshold that you set in Site-wide > Configure > Alert settings: Port advisor: Bandwidth pulse.
TX bandwidth usage exceeded the specified threshold that you set in Site-wide > Configure > Alert settings: Port advisor: Bandwidth pulse.
• Loop and BPDU (Bridge Protocol Data Units)) watch: A loop event occurs when packets sent out on a port loop back to the Nebula Device. A BPDU watch event occurs when an STP-aware (Spanning Tree Protocol) Switch connects to an existing network and causes STP topology changes in the network.
*This feature requires the port’s loop guard, BPDU guard, and err-disable recovery to be enabled.
Security appliance
Specify how long in minutes the NCC waits before generating and sending an alert when the following events occur:
• A security firewall, security gateway, or security router goes offline.
• Any DHCP pool on the security firewall, security gateway, or security router runs out of IP addresses to assign.
• A VPN connection to or from the security firewall, security gateway, or security router is created or terminated.
• The WAN connectivity goes offline.
Broadband router / Accessory
Specify how long in minutes the NCC waits before generating and sending an alert when a broadband router or accessory goes offline.
Other
Specify whether to send an alert each time configuration settings are changed.
Security alerts
CDR containment
Specify whether to send an alert each time a CDR block or containment action is triggered.
SecuReporter
Notification mode
Select whether to receive email security reports from SecuReporter.
Email subject
Enter an email title here.
Email description
Enter a description of the emails to be sent here. For example, maybe these emails are just for high severity events.
Notification interval
Specify how often to receive a SecuReporter report.
If no security events were triggered, SecuReporter will not send a report.
Event severity
Select the severity level of events that will be included in each report.
Event threshold
This table lists the events that trigger SecuReporter security alerts. See Table 44 on page 348 for details about each event.
You can set the alert threshold. For example, X count(s) of malware/virus attack within 5 minutes means SecuReporter includes a report in the email if the total number of combined malware and virus detection events exceed X within a 5 minute time period.
