LED | COLOR | STATUS | DESCRIPTION |
POWER ![]() | White | On | The Zyxel Device is receiving power and ready for use. |
POWER | White | Blinking | The Zyxel Device is booting or self-testing. |
POWER | White | Off | The Zyxel Device is not receiving power. |
Internet ![]() | White | On | There is Internet connection. |
Internet | White | Blinking | The Zyxel Device is sending or receiving IP traffic. |
Internet | White | Off | There is no Internet connection. |
LTE/3G ![]() | White | On | The Zyxel Device is registered and successfully connected to a 4G network. |
LTE/3G | White | Blinking (slow) | The Zyxel Device is connected to a 3G network. |
LTE/3G | White | Blinking (fast) | The Zyxel Device is trying to connect to a 3G/4G network. |
LTE/3G | White | Off | There is no service. |
LTE/3G | Green | On | The Zyxel Device has an Ethernet connection on the WAN. |
LTE/3G | Green | Off | There is no Ethernet connection on the WAN. |
Signal Strength ![]() | Green | On | The signal strength is excellent. |
Signal Strength | Amber | On | The signal strength is fair. |
Signal Strength | Red | On | The signal strength is poor. |
Signal Strength | Red | Blinking | There is no SIM card inserted, no signal, or the signal strength is below the poor level. |
Signal Strength | Red | Off | The SIM card is invalid, or the PIN code is not correct. |
WLAN ![]() | Green | On | The 2.4G wireless network is activated. |
WLAN | Green | Blinking (slow) | The Zyxel Device is setting up a WPS connection with a 2.4G wireless client. |
WLAN | Green | Blinking (fast) | The Zyxel Device is communicating with 2.4G wireless clients. |
WLAN | White | On | The 5G wireless network is activated. |
WLAN | White | Blinking (slow) | The Zyxel Device is setting up a WPS connection with a 5G wireless client. |
WLAN | White | Blinking (fast) | The Zyxel Device is communicating with 2.4G and 5G wireless clients. |
WLAN | White | Off | The wireless network is not activated. |
USB ![]() | White | On | The Zyxel Device recognizes a USB connection through the USB port. |
USB | White | Blinking | The Zyxel Device is sending/receiving data to/from the USB device connected to it. |
USB | White | Off | The Zyxel Device does not detect a USB connection through the USB port. |
Power/USB ![]() | Green | On | The Zyxel Device is receiving power and ready for use. |
Power/USB | Green | Blinking | The Zyxel Device is booting. |
Power/USB | Green | Off | The Zyxel Device is not receiving power. |
Power/USB | Blue | On | A USB device is connected to the USB port on the Zyxel Device. |
Internet/SMS ![]() | Green | On | The Zyxel Device is connected to the Internet using 3G/4G. |
Internet/SMS | Green | Blinking | There is a new SMS message. |
Internet/SMS | Green | Off | The Zyxel Device is not connected to the Internet. |
Internet/SMS | Blue | On | The Zyxel Device is connected to the Internet using 5G. |
Cellular Signal Strength ![]() | Green | On | The signal strength is excellent. |
Cellular Signal Strength | Orange | On | The signal strength is fair. |
Cellular Signal Strength | Red | On | The signal strength is poor. |
Cellular Signal Strength | Red | Blinking | There is no cellular signal, or signal strength is below the poor level. |
WiFi/WPS ![]() | Green | On | WiFi is enabled. |
WiFi/WPS | Green | Blinking (fast) | Data is being transmitted and received. |
WiFi/WPS | Green | Blinking (slow) | WPS is activated, and the Zyxel Device is establishing a WPS connection. |
Power ![]() | Green | On | The Zyxel Device is receiving power and ready for use. |
Power | Green | Blinking | The Zyxel Device is booting. |
Power | Green | Off | The Zyxel Device is not receiving power. |
Power | Red | On | Zyxel Device error, need to take action. |
Power | Blue | On | There is a new SMS message. |
Power | Blue | Blinking | The Inbox is full. |
Internet ![]() | Blue | On | The Zyxel Device is connected to the Internet using 5G. |
Internet | Green | On | The Zyxel Device is connected to the Internet using 4G, or is connected in Ethernet WAN mode. |
Internet | Red | On | Internet connection is unavailable. |
Cellular Signal Strength ![]() | Blue | On | The signal strength is good. |
Cellular Signal Strength | Blue | Blinking | No SIM card or invalid SIM card. |
Cellular Signal Strength | Green | On | The signal strength is medium. |
WiFi/WPS | Green | Blinking | WPS is activated, and the Zyxel Device is establishing a WPS connection. |
WiFi/WPS | Green | Off | WiFi is disabled. |
Power ![]() | Blue | On | There is a new SMS message. |
Power | Blue | Blinking | The SMS inbox is full. |
Power | Green | On | The Zyxel Device is receiving power and ready for use. |
Power | Off | Off | The Zyxel Device is not receiving power. |
Power | Red | On | The Zyxel Device has encountered an error, and requires action. |
Internet | Red | On | The Internet connection is unavailable. |
Cellular Signal Strength | Blue | Blinking | There is no SIM card or the SIM card is invalid. |
Cellular Signal Strength | Red | Blinking | There is no signal or it is too weak to be detected. |
WiFi or WPS ![]() | Green | On | The WiFi network is enabled. |
WiFi or WPS | Green | Blinking | WPS is activated, and the Zyxel Device is establishing a WPS connection. |
WiFi or WPS | Off | Off | The WiFi network is disabled. |
All LEDs | Green | Blinking | The Zyxel Device is resetting to factory default settings or upgrading firmware. |
SMS ![]() | Green | On | There is a new SMS message. |
SMS | Green | Blinking | The Inbox is full. |
SMS | Green | Off | There is no unread SMS message. |
Cellular Signal Strength | Red | Off | The Zyxel Device is booting. |
Power | Green | Intermittent On | The Zyxel Device is in power-saving mode. |
color | status | description |
Red | Blinking | The Zyxel Device is booting or self-testing. |
Red | On | The Zyxel Device encountered an error. |
Green | Blinking | The Zyxel Device is trying to connect to the Internet. |
Green | On | The Zyxel Device is connected to the Internet. |
Amber | Blinking | The Zyxel Device WiFi is on. |
Amber | On | The WiFi is activated. The Zyxel Device is connected to the Internet. |
Amber | Blinking | The WiFi is activated. The Zyxel Device is not connected to the Internet. |
Red | On | The Zyxel Device is not connected to the Internet. |
Red | Off | There is a system failure. |
Green/Amber/Red | Looping | Firmware upgrade is in process. |
Signal | Green | On | The 5G signal strength is excellent. |
Signal | Green | Blinking | The 4G signal strength is excellent. |
Signal | Amber | On | The 5G signal strength is fair. |
Signal | Amber | Blinking | The 4G signal strength is fair. |
Signal | Red | On | The 5G signal strength is weak. |
Signal | Red | Blinking | The 4G signal strength is weak. |
Signal | Red | Off | The Zyxel Device is not connected to the Internet. |
Status | Green | On | The Zyxel Device is connected to the Internet with WiFi off. |
Status | Green | Fast blinking | The Zyxel Device is trying to connect to the Internet with WiFi off. |
Status | Green | Slow blinking | The Zyxel Device is booting. |
Status | Amber | On | The Zyxel Device is connected to the Internet with WiFi on. |
Status | Amber | Blinking | The Zyxel Device is trying to connect to the Internet with WiFi on. |
Status | Red | On | There is a system failure. |
Status | Red | Off | The power is off. |
Status | Green / Amber / Red | Looping | Firmware upgrade is in progress. |
Cellular Signal Strength | Amber | On | The signal strength is fair. |
Cellular Signal Strength | Red | On | The signal strength is weak. |
Cellular Signal Strength | Red | Blinking | There is no cellular signal, or signal strength is below the weak level. |
Status ![]() | Green | On | The Zyxel Device is connected to the Internet. |
Status | Green | Blinking | The Zyxel Device is trying to connect to the Internet. |
Status | Green | Off | The Zyxel Device is not receiving power. |
Status | Amber | On | The WiFi is on. |
Status | Red | Blinking | The Zyxel Device is booting. |
Status | Green/Amber/Red | Looping | Firmware upgrade is in progress. |
Cellular Signal Strength ![]() | Green | On | The 5G signal strength is excellent. |
Cellular Signal Strength | Green | Blinking | The 4G signal strength is excellent. |
Cellular Signal Strength | Amber | On | The 5G signal strength is fair. |
Cellular Signal Strength | Amber | Blinking | The 4G signal strength is fair. |
Cellular Signal Strength | Red | On | The 5G signal strength is weak. |
Cellular Signal Strength | Red | Blinking | The 4G signal strength is weak. |
Cellular Signal Strength | Off | Off | The Zyxel Device is not connected to the Internet. |
Status ![]() | Green | On | The Zyxel Device is connected to the Internet with WiFi off. |
Status | Off | Off | The power is off. |
LABELS | DESCRIPTION |
ANT1-ANT2 | Install the external antennas to strengthen the cellular signal. |
Micro SIM | Insert a micro-SIM card into the slot with the chip facing down and the beveled corner in the top left corner. |
USB | The USB port of the Zyxel Device is used for file sharing. |
LAN4/WAN | LAN mode: LAN4 is a 1G LAN port that supports speeds of 100/1000 Mbps. Connect computers or other Ethernet devices to Ethernet ports for Internet access. WAN mode: The 1G WAN port supports speeds of 100/1000 Mbps. Use an Ethernet cable to connect the WAN port to a gateway/modem for Internet connection. |
LAN3- LAN1 | LAN3 – LAN1 are 1G LAN ports that support speeds of 100/1000 Mbps. Connect computers or other Ethernet devices to Ethernet ports for Internet access. |
RESET | Press the RESET button for more than 5 seconds to return the Zyxel Device to the factory defaults. Press the RESET button for more than 2 seconds but less than 5 seconds, it will cause the system to reboot. |
POWER | Press the POWER button after the power adapter is connected to start the Zyxel Device. |
POWER / DC IN | Connect the power adapter and press the POWER button to start the Zyxel Device. |
WiFi | Press the WLAN (WiFi) button for more than 5 seconds to enable WiFi. |
WPS | After WiFi is enabled, press the WLAN button for more than one second but less than 5 seconds to quickly set up a secure wireless connection between the Zyxel Device and a WPS-compatible client. |
WPS/WiFi On and Off | Press for 1 second: Enable or disable WiFi. Press for more than 5 seconds: Activate WPS connection process. |
ANT1-ANT2 / Antenna | Install the external antennas to strengthen the cellular signal. |
INT/EXT | Select between the internal or external cellular antennas. |
LAN1/WAN | LAN mode: LAN1 is a 1G LAN port that supports speeds of 100/1000 Mbps. Connect computers or other Ethernet devices to Ethernet ports for Internet access. WAN mode: The 1G WAN port supports speeds of 100/1000 Mbps. Use an Ethernet cable to connect the WAN port to a gateway/modem for Internet connection. |
LAN2 | Connect a computer to the LAN using an RJ45 cable. |
RESET | Press for 2 seconds: Reboot the Zyxel Device. Press for 5 seconds: Restore the Zyxel Device to its factory default settings. |
POWER Button | Press the POWER button after the power adapter is connected to start the Zyxel Device. |
POWER | Connect the power adapter and press the POWER button to start the Zyxel Device. |
ANT1-ANT2/Antenna | Install the external antennas to strengthen the cellular signal. |
LAN1 | Connect a computer to the LAN using an RJ45 cable. |
LAN2/WAN | LAN mode: Connect a computer to the LAN using an RJ45 cable. WAN mode: Connect the Zyxel Device to the Internet through the WAN. |
ON/OFF | Press the ON/OFF button after the power adapter is connected to start the Zyxel Device. |
POWER | Connect the power adapter and press the ON/OFF button to start the Zyxel Device. |
WiFi/WPS | Press the WiFi/WPS button to activate WPS connection process. See WiFi/WPS Button for more information. |
RESET | Press the RESET button to reboot or reset the Zyxel Device. See RESET Button for more information. |
Micro SIM | Insert a Micro-SIM card into the slot with the chip facing down and the beveled corner in the top left corner. |
Nano SIM | Insert a nano SIM card into the slot with the chip facing left and the beveled corner positioned inward. |
WiFi or WPS | Press the WiFi or WPS button to activate WPS connection process. See WiFi/WPS Button for more information. |
ANT | Connect external antennas to better receive the cellular signal from the base station. |
EXT/INT | Select between the external or internal cellular antennas. |
NanoSIM | Place the Nano-SIM card on the tray with the chip facing up. Insert the tray into the slot with the beveled corner positioned at the top and facing forward. |
WAN/LAN2 | LAN mode: Connect a computer to the LAN using an RJ45 cable. WAN mode: Connect the Zyxel Device to the Internet through the WAN. |
labels | description |
LAN (PoE) | Connect a computer through the PoE injector for configuration. Connect the PoE injector to a power outlet to start the device. |
WPS | After WiFi is enabled, press the WLAN button for more than one second but less than 5 seconds to quickly set up a secure WiFi connection between the Zyxel Device and a WPS-compatible client. |
RESET | Press the button for more than 5 seconds to return the Zyxel Device to the factory defaults. |
LAN (PoE) | Connect the PoE port on the PoE injector to the Zyxel Device’s LAN port through an Ethernet cable. Connect the LAN port on the PoE injector to your computer’s RJ45 port through another Ethernet cable. |
SIM 1/2 | Insert a micro-SIM card into the slot with the chip facing down and the beveled corner in the top left corner. |
Nano SIM | Insert a nano-SIM card into the slot with the chip facing down and the beveled corner in the top left corner. |
LAN (PoE) | Connect the PoE port on the PoE injector to the Zyxel Device's LAN port through an Ethernet cable. Connect the LAN port on the PoE injector to your computer's RJ45 port through another Ethernet cable. |
Reset | Press the Reset button to reboot or reset the Zyxel Device. See RESET Button for more information. |
Models | wifi button press hold time |
Nebula LTE3301-PLUS | More than 5 seconds. |
Nebula LTE7461-M602 | More than 5 seconds. |
Nebula NR7101 | More than 5 seconds. |
Nebula NR5101 | Press for 1 second. |
Nebula FWA505 | More than 10 seconds. |
Nebula FWA510 | WiFi can only be enabled/disabled through the Web Configurator. |
Nebula LTE3301-PLUS | More than 1 second but less than 5 seconds. |
Nebula LTE7461-M602 | More than 1 second but less than 5 seconds. |
Nebula NR7101 | More than 1 second but less than 5 seconds. |
Nebula NR5101 | More than 5 seconds. |
Nebula FWA505 | More than 3 seconds. |
Nebula FWA505v2 | More than 3 seconds. |
Nebula FWA510 | More than 3 seconds. |
