Label | Description |
Add New Static Route | Click this to set up a new static route on the Zyxel Device. |
# | This is the number of an individual static route. |
Status | This field indicates whether the rule is active (yellow bulb) or not (gray bulb). |
Name | This is the name of the static route. |
Destination IP | This parameter specifies the IP network address of the final destination. Routing is always based on network number. |
Subnet Mask/ Prefix Length | This parameter specifies the IP network subnet mask of the final destination. |
Gateway | This is the IP address of the gateway. The gateway is a router or switch on the same network segment as the device's LAN or WAN port. The gateway helps forward packets to their destinations. |
Interface | This is the WAN interface through which the traffic is routed. |
Modify | Click the Edit icon to go to the screen where you can set up a static route on the Zyxel Device. Click the Delete icon to remove a static route from the Zyxel Device. |
Active | Click this switch to activate static route. Otherwise, click to disable. |
Route Name | Enter a name for your static route. You can use up to 15 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. |
IP Type | Select between IPv4 or IPv6. Compared to IPv4, IPv6 (Internet Protocol version 6) is designed to enhance IP address size and features. The increase in IPv6 address size to 128 bits (from the 32-bit IPv4 address) allows up to 3.4 x 1038 IP addresses. The Zyxel Device can use IPv4/IPv6 dual stack to connect to IPv4 and IPv6 networks, and supports IPv6 rapid deployment (6RD). |
Destination IP Address | This parameter specifies the IP network address of the final destination. Routing is always based on network number. If you need to specify a route to a single host, use a subnet mask of 255.255.255.255 in the subnet mask field to force the network number to be identical to the host ID. |
Subnet Mask | If you are using IPv4 and need to specify a route to a single host, use a subnet mask of 255.255.255.255 in the subnet mask field to force the network number to be identical to the host ID. Enter the IP subnet mask here. |
Prefix Length | If you are using IPv6, enter the address prefix length to specify how many most significant bits in an IPv6 address compose the network address. |
Use Gateway IP Address | The gateway is a router or switch on the same network segment as the device's LAN or WAN port. The gateway helps forward packets to their destinations. Click this switch to enable or disable the gateway IP address. When the switch goes to the right, the function is enabled. Otherwise, it is not. |
User Interface | You can decide if you want to forward packets to a gateway IP address (Default) or a bound interface (Cellular WAN). If you want to configure bound interface, choose an interface through which the traffic is sent. You must have the WAN interfaces already configured in the Broadband screen. |
OK | Click this to save your changes. |
Cancel | Click this to exit this screen without saving. |
Device / Computer | IP address |
The Zyxel Device’s WAN | 172.16.1.1 |
The Zyxel Device’s LAN | 192.168.1.1 |
IP Type | IPv4 |
Use Interface | Default |
A | 192.168.1.34 |
R’s N1 | 192.168.1.253 |
R’s N2 | 192.168.10.2 |
B | 192.168.10.33 |
Add New DNS Route | Click this to create a new entry. |
# | This is the number of an individual DNS route. |
Domain Name | This is the domain name to which the DNS route applies. |
WAN Interface | This is the WAN interface through which the matched DNS request is routed. |
Subnet Mask | This parameter specifies the IP network subnet mask. |
Modify | Click the Edit icon to configure a DNS route on the Zyxel Device. Click the Delete icon to remove a DNS route from the Zyxel Device. |
Active | Enable DNS route in your Zyxel Device. |
Domain Name | Enter the domain name you want to resolve. You can use up to 64 alphanumeric (0-9, a-z, A-Z) characters with hyphens [ – ] and periods [ . ]. You can use the wildcard character, an “*” (asterisk) as the left most part of a domain name, such as *.example.com. The Zyxel Device forwards DNS queries for any domain name ending in example.com to the WAN interface specified in this route. |
WAN Interface | Select a WAN interface through which the matched DNS query is sent. You must have the WAN interfaces already configured in the Broadband screen. |
Add New Policy Route | Click this to create a new policy forwarding rule. |
# | This is the index number of the entry. |
Status | This field displays whether the DNS route is active or not. A yellow bulb signifies that this DNS route is active. A gray bulb signifies that this DNS route is not active. |
Name | This is the name of the rule. |
Source IP | This is the source IP address. |
Source Subnet Mask | This is the source subnet mask address. |
Protocol | This is the transport layer protocol. |
Source Port | This is the source port number. |
Source MAC | This is the source MAC address. |
Source Interface | This is the interface from which the matched traffic is sent. |
WAN Interface | This is the WAN interface through which the traffic is routed. |
Modify | Click the Edit icon to edit this policy. Click the Delete icon to remove a policy from the Zyxel Device. A window displays asking you to confirm that you want to delete the policy. |
Active | Click this switch to activate this policy route. Otherwise, click to disable. |
Route Name | Enter a descriptive name of this policy route. You can use up to 15 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. |
Source IP Address | Enter the source IP address. |
Source Subnet Mask | Enter the source subnet mask address. |
Protocol | Select the transport layer protocol (TCP, UDP, or None). |
Source Port | Enter the source port number. |
Source MAC | Enter the source MAC address. |
Source Interface (example: br0 or LAN 1 – LAN 4) | Enter the name of the interface from which the matched traffic is sent. |
WAN Interface | Select a WAN interface through which the traffic is sent. You must have the WAN interfaces already configured in the Broadband screens. |
Cancel | Click Cancel to exit this screen without saving. |
OK | Click OK to save your changes. |
# | This is the index of the interface in which the RIP setting is used. |
Interface | This is the name of the interface in which the RIP setting is used. |
Version | The RIP version controls the format and the broadcasting method of the RIP packets that the Zyxel Device sends (it recognizes both formats when receiving). RIPv1 is universally supported but RIPv2 carries more information. RIPv1 is probably adequate for most networks, unless you have an unusual network topology. When set to Both, the Zyxel Device will broadcast its routing table periodically and incorporate the RIP information that it receives. |
Operation | Select Passive to have the Zyxel Device update the routing table based on the RIP packets received from neighbors but not advertise its route information to other routers in this interface. Select Active to have the Zyxel Device advertise its route information and also listen for routing updates from neighboring routers. |
Enable | Select the checkbox to activate the settings. |
Disable Default Gateway | Select the checkbox to set the Zyxel Device to not send the route information to the default gateway. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
