Label | Description |
General Settings | |
Enable | Select this checkbox to activate the settings in this section. |
Enable Malicious Mail | Select this to identify spam email by content, such as malicious content. |
Malicious Mail Tag | Enter a message or label using up to 15 single-byte characters to add to the beginning of the mail subject of emails that are determined to spam based on the mail content analysis. Accepted characters are 0-9a-zA-Z-.[]_ !”#$%&’()*+,/;<=>?@\^‘{|} are not allowed. This tag is only added if the email security policy is configured to forward spam mail with a spam tag. |
Enable DNSBL | Select this checkbox to check email against the Zyxel Device’s configured DNSBL domains. The Zyxel Device classifies email that matches a DNS black list as spam. |
DNSBL Spam Tag | Enter a message or label using up to 15 single-byte characters to add to the beginning of the mail subject of emails that have a sender or relay IP address in the header that matches a black list maintained by one of the DNSBL domains listed in the Zyxel Device. Accepted characters are 0-9a-zA-Z-.[]_ !”#$%&’()*+,/;<=>?@\^‘{|} are not allowed. This tag is only added if the email security policy is configured to forward spam mail with a spam tag. |
DNSBL Domain List | |
Add | Click this to create a new entry. |
Edit | Select an entry and click this to be able to modify it. |
Remove | Select an entry and click this to delete it. |
Activate | To turn on an entry, select it and click Activate. |
Inactivate | To turn off an entry, select it and click Inactivate. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
# | This is the entry’s index number in the list. |
DNSBL Domain | This is the name of a domain that maintains DNSBL servers. Enter the domain that is maintaining a DNSBL. |
Actions for Spam Mail | Use this section to set how the Zyxel Device is to handle spam mail. |
SMTP | Select how the Zyxel Device is to handle spam SMTP mail. Select drop to discard spam SMTP mail. Select forward to allow spam SMTP mail to go through. Select forward with tag to add a spam tag to an SMTP spam mail’s mail subject and send it on to the destination. |
POP3 | Select how the Zyxel Device is to handle spam POP3 mail. Select forward to allow spam POP3 mail to go through. Select forward with tag to add a spam tag to an POP3 spam mail’s mail subject and send it on to the destination. |
Log | Select whether to have the ZyXEL device generate a log (log), log and alert (log alert) or neither (no) by default when traffic matches a signature in this category. |
Action taken when mail sessions threshold is reached | An email session is when an email client and email server (or two email servers) connect through the Zyxel Device. Select how to handle concurrent email sessions that exceed the maximum number of concurrent email sessions that the email security feature can handle. See the chapter of product specifications for the threshold. Select Forward Session to have the Zyxel Device allow the excess email sessions without any spam filtering. Select Drop Session to have the Zyxel Device drop mail connections to stop the excess email sessions. The email client or server will have to re-attempt to send or receive email later when the number of email sessions is under the threshold. |
Query Timeout Settings | |
SMTP | Select how the Zyxel Device is to handle SMTP mail query timeout. Select drop to discard SMTP mail. Select forward to allow SMTP mail to go through. Select forward with tag to add a tag to an SMTP query timeout mail’s mail subject and send it on to the destination. |
POP3 | Select how the Zyxel Device is to handle POP3 mail query timeout. Select forward to allow POP3 mail to go through. Select forward with tag to add a tag to an POP3 query timeout mail’s mail subject and send it on to the destination. |
Timeout Value | Set how long the Zyxel Device waits for a reply from the mail scan server. If there is no reply before this time period expires, the Zyxel Device takes the action defined in the relevant Actions when Query Timeout field. |
Timeout Tag | Enter a message or label using up to 15 single-byte characters to add to the mail subject of emails that the Zyxel Device forwards if queries to the mail scan servers time out. Accepted characters are 0-9a-zA-Z-.[]_ !”#$%&’()*+,/;<=>?@\^‘{|} are not allowed. |
Timeout X-Header | Specify the name and value for the X-Header to be added when queries to the mail scan servers time out. |
DNSBL Settings | |
Max. IPs Checking Per Mail | Set the maximum number of sender and relay server IP addresses in the mail header to check against the DNSBL domain servers. |
IP Selection Per Mail | Select first N IPs to have the Zyxel Device start checking from the first IP address in the mail header. This is the IP of the sender or the first server that forwarded the mail. Select last N IPs to have the Zyxel Device start checking from the last IP address in the mail header. This is the IP of the last server that forwarded the mail. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Enable Allow List | Select this to bypass checking by this feature (if enabled) and automatically classifies email that matches a white list entry as legitimate (not spam). |
Rule Summary | |
Type | This field displays whether the entry is based on the email’s subject, source or relay IP address, source email address, or header. |
Content | This field displays the subject content, source or relay IP address, source email address, or header value for which the entry checks. |
Enable Block List | Select this to bypass checking by this feature (if enabled) and automatically classifies email that matches a block list entry as spam. |
Block List Spam Tag | Enter a message or label using up to 15 single-byte characters to add to the mail subject of emails that match the Zyxel Device’s spam block list. Accepted characters are 0-9a-zA-Z-.[]_ !”#$%&’()*+,/;<=>?@\^‘{|} are not allowed. |
Rule Summary | |
Enable Rule | Select this to have the Zyxel Device use this entry as part of the block or allowed list. To actually use the entry, you must also turn on the use of the list in the corresponding list screen, enable the email security feature in the email security general screen, and configure an email security policy to use the list. |
Type | Use this field to base the entry on the email’s subject, source or relay IP address, source email address, or header. Select Subject to have the Zyxel Device check email for specific content in the subject line. Select IP Address to have the Zyxel Device check email for a specific source or relay IP address. Select IPv6 Address to have the Zyxel Device check email for a specific source or relay IPv6 address. Select E-Mail Address to have the Zyxel Device check email for a specific source email address or domain name. Select Mail Header to have the Zyxel Device check email for specific header fields and values. Configure black list header entries to check for email from bulk mail programs or with content commonly used in spam. Configure white list header entries to allow certain header values that identify the email as being from a trusted source. |
Mail Subject Keyword | This field displays when you select the Subject type. Enter 1 to 63 single-byte characters of text to check for in email headers. 0-9a-zA-Z!#$%’()*+,-./:;=?@_ “&<>[\]^‘{|} and spaces are not allowed, although you could substitute a question mark (?). See Regular Expressions in Block or Allow List Entries for more details. |
Sender or Mail Relay IP Address | This field displays when you select the IP Address type. Enter an IP address in dotted decimal notation. |
Sender or Mail Relay IPv6 Address | This field displays when you select the IPv6 Address type. Enter an IPv6 address with prefix. |
Netmask | This field displays when you select the IP type. Enter the subnet mask here, if applicable. |
Sender E-Mail Address | This field displays when you select the E-Mail type. Enter a keyword with 1 to 63 single-byte characters. Accepted characters are 0-9a-zA-Z*-./?@_ !”#$%&’()+:;,<=>[\]^‘{|} and spaces are not allowed. See Regular Expressions in Block or Allow List Entries for more details. |
Mail Header Field Name | This field displays when you select the Mail Header type. Type the name part of an email header (the part that comes before the colon). Use 1 to 63 single-byte characters, including 0-9a-zA-Z-._ !”#$%&’()*+,/:;<=>?@[\]^‘{|} and spaces are not allowed. For example, if you want the entry to check the “Received:” header for a specific mail server’s domain, enter “Received” here. |
Field Value Keyword | This field displays when you select the Mail Header type. Type the value part of an email header (the part that comes after the colon). Use 1 to 63 single-byte characters, including 0-9a-zA-Z!#$%’()*+,-./:;=?@_ “&<>[\]^‘{|} and spaces are not allowed. For example, if you want the entry to check the “Received:” header for a specific mail server’s domain, enter the mail server’s domain here. See Regular Expressions in Block or Allow List Entries for more details. |
OK | Click OK to save your changes. |
Cancel | Click Cancel to exit this screen without saving your changes. |
Router# configure terminal Router(config)# secure-policy-style advance Router(config)# show secure-policy-style status secure-policy-style: advance |
Add | Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry. |
Edit | Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings. |
Remove | Select an entry and click Remove to delete the selected entry. |
# | This field is a sequential value showing the number of the profile. The profile order is not important. |
Name | This displays the name of the profile created. |
Description | This displays the description of the profile. |
Scan Options | This displays which lists are checked for email security: White List (WL), Black List (BL), Malicious Mail, DNSBL. |
Name | Type the name of the profile. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. These are valid, unique profile names: • MyProfile • mYProfile • Mymy12_3-4 These are invalid profile names: • 1mYProfile • My Profile • MyProfile? • Whatalongprofilename123456789012 |
Description | Type a description for the profile rule to help identify the purpose of rule. You may use 1-31 alphanumeric characters, underscores (_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. This field is optional. |
Scan Options | |
Check White List | Select this checkbox to check email against the white list. The Zyxel Device classifies email that matches a white list entry as legitimate (not spam). |
Check Black List | Select this checkbox to check email against the black list. The Zyxel Device classifies email that matches a black list entry as spam. |
Check Malicious Mail | Select this to identify spam email by content, such as malicious content. |
Check DNSBL | Select this checkbox to check email against the Zyxel Device’s configured DNSBL domains. The Zyxel Device classifies email that matches a DNS black list as spam. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
Inspect all traffic, setting: | Select this to have all traffic inspected by the default_profile. You cannot rename or delete the default_profile profile, but you can edit it by clicking the link here. |
Inspect by policy | If you configured a specific profile in the Profile tab for this service, select this to have specific traffic inspected by that profile. You must bind the profile to a policy in Security Policy > Policy Control. |
Action | |
DNSBL Settings | |
Router# configure terminal Router(config)# secure-policy-style general Router(config)# show secure-policy-style status secure-policy-style: general |
