Label | Description |
Poll Interval | Enter how often you want this window to be updated automatically, and click Set Interval. |
Set Interval | Click this to set the Poll Interval the screen uses. |
Stop | Click this to stop the window from updating automatically. You can start it again by setting the Poll Interval and clicking Set Interval. |
Switch to Graphic View | Click this to display the port statistics as a line graph. |
# | This field is a sequential value, and it is not associated with a specific port. |
Port | This field displays the physical port number. |
Status | This field displays the current status of the physical port. Down - The physical port is not connected. Speed / Duplex - The physical port is connected. This field displays the port speed and duplex setting (Full or Half). |
TxPkts | This field displays the number of packets transmitted from the Zyxel Device on the physical port since it was last connected. |
RxPkts | This field displays the number of packets received by the Zyxel Device on the physical port since it was last connected. |
Collisions | This field displays the number of collisions on the physical port since it was last connected. |
Tx B/s | This field displays the transmission speed, in bytes per second, on the physical port in the one-second interval before the screen updated. |
Rx B/s | This field displays the reception speed, in bytes per second, on the physical port in the one-second interval before the screen updated. |
Up Time | This field displays how long the physical port has been connected. |
System Up Time | This field displays how long the Zyxel Device has been running since it last restarted or was turned on. |
Refresh Interval | Enter how often you want this window to be automatically updated. |
Refresh Now | Click this to update the information in the window right away. |
Port Selection | Select the number of the physical port for which you want to display graphics. |
Switch to Grid View | Click this to display the port statistics as a table. |
bps | The y-axis represents the speed of transmission or reception. |
time | The x-axis shows the time period over which the transmission or reception occurred |
TX | This line represents traffic transmitted from the Zyxel Device on the physical port since it was last connected. |
RX | This line represents the traffic received by the Zyxel Device on the physical port since it was last connected. |
Last Update | This field displays the date and time the information in the window was last updated. |
Interface Status If an Ethernet interface does not have any physical ports associated with it, its entry is displayed in light gray text. | |
Name | This field displays the name of each interface. If there is an Expand icon (plus-sign) next to the name, click this to look at the status of virtual interfaces on top of this interface. |
Port/Binding | This field displays the physical port number. |
Status | This field displays the current status of each interface. The possible values depend on what type of interface it is. For Ethernet interfaces: • Inactive - The Ethernet interface is disabled. • Down - The Ethernet interface does not have any physical ports associated with it or the Ethernet interface is enabled but not connected. • Speed / Duplex - The Ethernet interface is enabled and connected. This field displays the port speed and duplex setting (Full or Half). For cellular (mobile broadband) interfaces, see USB Storage Screen for the status that can appear. For the auxiliary interface: • Inactive - The auxiliary interface is disabled. • Connected - The auxiliary interface is enabled and connected. • Disconnected - The auxiliary interface is not connected. For virtual interfaces, this field always displays Up. If the virtual interface is disabled, it does not appear in the list. For VLAN and bridge interfaces, this field always displays Up. If the VLAN or bridge interface is disabled, it does not appear in the list. For PPP interfaces: • Connected - The PPP interface is connected. • Disconnected - The PPP interface is not connected. If the PPP interface is disabled, it does not appear in the list. For WLAN interfaces: • Up - The WLAN interface is enabled. • Down - The WLAN interface is disabled. |
Zone | This field displays the zone to which the interface is assigned. |
IP Addr/Netmask | This field displays the current IP address and subnet mask assigned to the interface. If the IP address and subnet mask are 0.0.0.0, the interface is disabled or did not receive an IP address and subnet mask through DHCP. If this interface is a member of an active virtual router, this field displays the IP address it is currently using. This is either the static IP address of the interface (if it is the master) or the management IP address (if it is a backup). |
IP Assignment | This field displays how the interface gets its IP address. • Static - This interface has a static IP address. • DHCP Client - This interface gets its IP address from a DHCP server. |
Services | This field lists which services the interface provides to the network. Examples include DHCP relay, DHCP server, DDNS, RIP, and OSPF. This field displays n/a if the interface does not provide any services to the network. |
Action | Use this field to get or to update the IP address for the interface. Click Renew to send a new DHCP request to a DHCP server. Click Connect to try to connect a PPPoE/PPTP interface. If the interface cannot use one of these ways to get or to update its IP address, this field displays n/a. |
Tunnel Interface Status This displays the details of the Zyxel Device’s configured tunnel interfaces. | |
Name | This field displays the name of the interface. |
Status | The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive. |
IP Address | This is the IP address of the interface. If the interface is active (and connected), the Zyxel Device tunnels local traffic sent to this IP address to the Remote Gateway Address. |
My Address | This is the interface or IP address uses to identify itself to the remote gateway. The Zyxel Device uses this as the source for the packets it tunnels to the remote gateway. |
Remote Gateway Address | This is the IP address or domain name of the remote gateway to which this interface tunnels traffic. |
Mode | This field displays the tunnel mode that you are using. |
IPv6 Interface Status If an Ethernet interface does not have any physical ports associated with it, its entry is displayed in light gray text. | |
IP Address | This field displays the current IPv6 address assigned to the interface. If the IPv6 address is ::, the interface is disabled or did not receive an IPv6 address through DHCP. If this interface is a member of an active virtual router, this field displays the IPv6 address it is currently using. This is either the static IPv6 address of the interface (if it is the master) or the management IPv6 address (if it is a backup). |
Interface Statistics This table provides packet statistics for each interface. | |
Refresh | Click this button to update the information on the screen. |
Name | This field displays the name of each interface. If there is a Expand icon (plus-sign) next to the name, click this to look at the statistics for virtual interfaces on top of this interface. |
Status | This field displays the current status of the interface. • Down - The interface is not connected. • Speed / Duplex - The interface is connected. This field displays the port speed and duplex setting (Full or Half). This field displays Connected and the accumulated connection time (hh:mm:ss) when the PPP interface is connected. |
TxPkts | This field displays the number of packets transmitted from the Zyxel Device on the interface since it was last connected. |
RxPkts | This field displays the number of packets received by the Zyxel Device on the interface since it was last connected. |
Tx B/s | This field displays the transmission speed, in bytes per second, on the interface in the one-second interval before the screen updated. |
Rx B/s | This field displays the reception speed, in bytes per second, on the interface in the one-second interval before the screen updated. |
Data Collection | |
Collect Statistics | Select this to have the Zyxel Device collect data for the report. If the Zyxel Device has already been collecting data, the collection period displays to the right. The progress is not tracked here real-time, but you can click the Refresh button to update it. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Statistics | |
Interface | Select the interface from which to collect information. You can collect information from Ethernet, VLAN, bridge and PPPoE/PPTP interfaces. |
Sort By | Select the type of report to display. Choices are: • Host IP Address/User - displays the IP addresses or users with the most traffic and how much traffic has been sent to and from each one. • Service/Port - displays the most-used protocols or service ports and the amount of traffic for each one. • Web Site Hits - displays the most-visited Web sites and how many times each one has been visited. • Country - displays the countries with the most traffic and the amount of traffic for each one. Each type of report has different information in the report (below). |
Refresh | Click this button to update the report display. |
Flush Data | Click this button to discard all of the screen’s statistics and update the report display. |
These fields are available when the Traffic Type is Host IP Address/User. | |
# | This field is the rank of each record. The IP addresses and users are sorted by the amount of traffic. |
Direction | This field indicates whether the IP address or user is sending or receiving traffic. • Ingress- traffic is coming from the IP address or user to the Zyxel Device. • Egress - traffic is going from the Zyxel Device to the IP address or user. |
IP Address/User | This field displays the IP address or user in this record. The maximum number of IP addresses or users in this report is indicated in Maximum Values for Reports. |
Amount | This field displays how much traffic was sent or received from the indicated IP address or user. If the Direction is Ingress, a red bar is displayed; if the Direction is Egress, a blue bar is displayed. The unit of measure is bytes, Kbytes, Mbytes or Gbytes, depending on the amount of traffic for the particular IP address or user. The count starts over at zero if the number of bytes passes the byte count limit. |
These fields are available when the Traffic Type is Service/Port. | |
# | This field is the rank of each record. The protocols and service ports are sorted by the amount of traffic. |
Service/Port | This field displays the service and port in this record. |
Protocol | This field indicates what protocol the service was using. |
Direction | This field indicates whether the indicated protocol or service port is sending or receiving traffic. • Ingress - traffic is coming into the Zyxel Devicethrough the interface • Egress - traffic is going out from the Zyxel Device through the interface |
Amount | This field displays how much traffic was sent or received from the indicated service / port. If the Direction is Ingress, a red bar is displayed; if the Direction is Egress, a blue bar is displayed. The unit of measure is bytes, Kbytes, Mbytes, Gbytes, or Tbytes, depending on the amount of traffic for the particular protocol or service port. The count starts over at zero if the number of bytes passes the byte count limit. |
These fields are available when the Traffic Type is Web Site Hits. | |
# | This field is the rank of each record. The domain names are sorted by the number of hits. |
Web Site | This field displays the domain names most often visited. The Zyxel Device counts each page viewed on a Web site as another hit. |
Hits | This field displays how many hits the Web site received. The Zyxel Device counts hits by counting HTTP GET packets. Many Web sites have HTTP GET references to other Web sites, and the Zyxel Device counts these as hits too. The count starts over at zero if the number of hits passes the hit count limit. |
These fields are available when the Traffic Type is Country. | |
# | This field is the rank of each record. The country name is sorted by the amount of traffic. |
Country Name | This field displays the name of the country. |
Country | This field displays the country code. |
Amount | This field displays how much traffic was sent or received from the indicated country. If the Direction is Ingress, a red bar is displayed; if the Direction is Egress, a blue bar is displayed. The unit of measure is bytes, Kbytes, Mbytes, Gbytes, or Tbytes, depending on the amount of traffic for the particular protocol or service port. The count starts over at zero if the number of bytes passes the byte count limit. • Ingress - traffic is coming into the Zyxel Device from the country. • Egress - traffic is going from the Zyxel Device to the country. |
Maximum Number of Records | 20 |
Byte Count Limit | 264 bytes; this is just less than 17 million terabytes. |
Hit Count Limit | 264 hits; this is over 1.8 x 1019 hits. |
View | Select how you want the established sessions that passed through the Zyxel Device to be displayed. Choices are: • sessions by users - display all active sessions grouped by user • sessions by services - display all active sessions grouped by service or protocol • sessions by source IP - display all active sessions grouped by source IP address • session by source region - display all active sessions grouped by where the traffic is coming from by country • sessions by destination IP - display all active sessions grouped by destination IP address • sessions by destination region - display all active sessions grouped by where the traffic is going to by country • all sessions - filter the active sessions by the User, Service, Source Address, and Destination Address, and display each session individually (sorted by user). |
Refresh | Click this button to update the information on the screen. The screen also refreshes automatically when you open and close the screen. |
The User, Service, Source Address, Destination Address, Source Country and Destination Country fields display if you view all sessions. Select your desired filter criteria and click the Refresh button to filter the list of sessions. | |
User | This field displays when View is set to all sessions. Enter the user whose sessions you want to view. It is not possible to enter part of the user name or use wildcards in this field; you must enter the whole user name. |
Service | This field displays when View is set to all sessions. Select the service or service group whose sessions you want to view. The Zyxel Device identifies the service by comparing the protocol and destination port of each packet to the protocol and port of each services that is defined. |
Source Address | This field displays when View is set to all sessions. Enter the source IP address whose sessions you want to view. You cannot include the source port. |
Source Country | This field displays when View is set to all sessions. Select the country where the traffic is coming from. |
Destination Address | This field displays when View is set to all sessions. Enter the destination IP address whose sessions you want to view. You cannot include the destination port. |
Destination Country | This field displays when View is set to all sessions. Select the country where the traffic is going to. |
Search | Click this to display all sessions in the table below according to the criteria you defined above. |
Clear Clear All | Administrators can use these buttons to forcibly terminate selected TCP/UDP connections. Select one or multiple connections and then click Clear; click Clear All to terminate all connections displayed. Cleared sessions display on the Log > View Log screen. |
# | This field is the rank of each record. The names are sorted by the name of user in active session. You can use the pull down menu on the right to choose sorting method. |
User | This field displays the user in each active session. If you are looking at the sessions by users (or all sessions) report, click + or - to display or hide details about a user’s sessions. |
Service | This field displays the protocol used in each active session. If you are looking at the sessions by services report, click + or - to display or hide details about a protocol’s sessions. |
Source | This field displays the source IP address and port in each active session. If you are looking at the sessions by source IP report, click + or - to display or hide details about a source IP address’s sessions. |
Source Country | This field displays the source country in each active session. |
Destination | This field displays the destination IP address and port in each active session. If you are looking at the sessions by destination IP report, click + or - to display or hide details about a destination IP address’s sessions. |
Destination Country | This field displays the destination country in each active session. |
Rx | This field displays the amount of information received by the source in the active session. |
Tx | This field displays the amount of information transmitted by the source in the active session. |
Duration | This field displays the length of the active session in seconds. |
Current DHCP List | |
Interface | Select a Zyxel Device interface that has DHCP enabled to show to which devices it has assigned DHCP IP addresses. |
Keyword | Enter a keyword to display the interfaces and their information, such as IP addresses, MAC addresses and so on. The field is case-sensitive. |
Search | Click to update the list of interfaces shown in the table below based on the search criteria. Your search criteria is retained when navigating between screens. |
Reset | Click to return this search criteria to the factory defaults and display all interfaces with DHCP enabled. |
Release | Select an entry and click on this button to let other devices use the dynamic DHCP that is currently assigned to the selected entry. |
Reserve | Select an entry and click on this button to set the entry as a static DHCP entry. The IP address will be reserved for the MAC address after you click this button. |
Unreserve | Select an entry and click on this button to set the entry from a static DHCP entry to a dynamic DHCP entry. The IP address is assigned to a DHCP client. |
Export | To export as a csv file on your computer, select them and click Export. Click Save in the file download dialogue box and then select a location and name for the file. You can edit the file after it is saved on your computer. To import the file you export here to recover the settings you configure now later on the Zyxel Device, go to Configuration > Network > Interface > Ethernet/VLAN > DCHP Setting. |
# | This field is a sequential value, and it is not associated with a specific entry. |
Interface | This field identifies the interface that assigned an IP address to a DHCP client. |
IP Address | This field displays the IP address currently assigned to a DHCP client or reserved for a specific MAC address. Click the column’s heading cell to sort the table entries by IP address. Click the heading cell again to reverse the sort order. |
Host Name | This field displays the name used to identify this device on the network (the computer name). The Zyxel Device learns these from the DHCP client requests. “None” shows here for a static DHCP entry. |
MAC Address | This field displays the MAC address to which the IP address is currently assigned or for which the IP address is reserved. Click the column’s heading cell to sort the table entries by MAC address. Click the heading cell again to reverse the sort order. |
Expiration Time | This displays the date and time the DHCP-assigned address will be renewed. |
Last Access | This is when the last time any traffic pass through the interface. |
Description | For a static DHCP entry, the host name or the description you configured shows here. This field is blank for dynamic DHCP entries. |
Static | This field displays if the address in the IP address field is reserved for the clients connected to this interface. Yes means that the clients connected to the interface will always get the IP address shown in the table. |
label | description |
Hide/Show Advanced Settings | Click this button to display a greater or lesser number of configuration fields. |
Edit | Double-click an entry or select it and click Edit to modify the entry’s settings in the Description field. |
Remove | Select an entry and click Remove to remove a client from the table that’s no longer connected to your network. For example, guest A visited your company over a month ago. Guest A used his cellphone to connect to your Zyxel Device networks. His cellphone was identified and shown in the Device Insight table. Guest A has left for over a month and you’re sure he will not return in the near future. You can use the Remove button to remove his device from this table. Guest A’s device will be identified and shown in the table again if he connects to your Zyxel Device networks in the future. Please note that clients that are blocked cannot be removed. Make sure to unblock clients before you remove them. |
Add to block list | Select an entry and click Add to block list to stop the selected client from connecting to the Zyxel Device. |
Remove from block list | Select an entry and click Remove from block list to allow the selected client to connect to the Zyxel Device. |
Feedback | Select an entry and click Feedback to report on a client that is wrongly identified regarding its Category, Operating System or Type. |
# | This field is a sequential value, and it is not associated with a specific service. |
Status | This field displays the status of the clients. On line ( )- The VPN connection between the client and the Zyxel Device is up.Off line ( )- The VPN connection between the client and the Zyxel Device is down.Block ( )- The client is blocked from the connection to the Zyxel Device.CDR Block ( )- The client’s MAC address is blocked by CDR. |
MAC Address | This field displays the MAC address of the client. |
IP Address | This field displays the IP address of the client. |
Hostname | This field displays the name used to identify this device on the network. |
Manufacturer | This field displays the manufacturer of the client, such as Apple or Samsung. |
Category | This field displays the type of the device of the client, such as printer or smart TV. |
OS | This field displays the operating system of the client. |
OS Version | This field displays the version of the operating system of the client. |
Type | This field displays the model names of the client. |
First-seen | This field displays the time when the client first sends traffic to the Zyxel Device. |
Last-seen | This field displays the time when the client last sends traffic to the Zyxel Device. |
User | This field displays the type of user account the client uses. See User/Group for more information the user account types. |
Auth method | This field displays the authentication method that is used to authenticate the client. |
TX rate (Kbps) | This field displays the transmission rate of the client to which the Zyxel Device is connected. |
RX rate (Kbps) | This field displays the reception rate of the client to which the Zyxel Device is connected. |
Connected to | This field displays if the client is connected directly to the Zyxel Device or to an AP that is connected to the Zyxel Device. |
Description | This field displays the descriptive name of the client. |
Description | Enter a descriptive name for this client. You can use up to 31 characters, spaces and underscores are allowed. |
OK | Click OK to save your changes back to the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving your changes. |
Current Device Information | |
MAC address | This field displays the MAC address of the client. |
Operating System | This field displays the operating system of the client. |
Expect Device Information | |
Category | This field will display the current type of the client device identified by the Zyxel Device. If you think it’s wrong, select the type of device you believe is correct from the drop-down list box. If it is correct, leave it as it is. |
Operating System | This field will display the current operating system of the client identified by the Zyxel Device. If you think it’s wrong, select the operating system you believe is correct from the drop-down list box. If it is correct, leave it as it is. |
Type | This field will display the current model name of the client identified by the Zyxel Device. If you think it’s wrong, enter the model name you believe is correct. If it is correct, leave it as it is. |
OK | Click OK to send your feedback to the Zyxel database. |
Force Logout | Select a user row and click this icon to end a user’s session. |
# | This field is a sequential value and is not associated with any entry. |
User ID | This field displays the user name of each user who is currently logged in to the Zyxel Device. |
Reauth/Lease Time | This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each user. See User/Group User Summary for more information on the reauthentication time and lease time. |
Session Timeout | This field displays the total account of time the account (authenticated by an external server) can use to log into the Zyxel Device or access the Internet through the Zyxel Device. This shows unlimited for an administrator account. |
Type | This field displays the way the user logged into the Zyxel Device. The user can log into the Zyxel Device using HTTP, HTTPS, Telnet, SSH, FTP and console. |
IP Address | This field displays the IP address of the computer used to log in to the Zyxel Device. |
Country | The Internet Assigned Numbers Authority (IANA) has reserved the following blocks of Private IPv4 addresses: • 10.0.0.0 - 10.255.255.255 • 172.16.0.0 - 172.31.255.255 • 192.168.0.0 - 192.168.255.255 • 224.0.0.0 - 239.255.255.255 The Zyxel Device cannot identify a user’s country if the user accessed the Zyxel Device using one of the private IPv4 addresses listed above. This field will display a hyphen (-). |
MAC | This field displays the MAC address of the computer used to log into the Zyxel Device. |
User Info | This field displays the types of user accounts the Zyxel Device uses. If the user type is ext-user (external user), this field will show its external-group information when you move your mouse over it. If the external user matches two external-group objects, both external-group object names will be shown. See What You Need To Know for more information on the user accounts. |
Created Date | This field displays the date the account was created. This field displays a hyphen (-) if the account was created on a Zyxel Device with firmware version earlier than 5.10. |
Acct. Status | For a captive portal login, this field displays the accounting status of the account used to log into the Zyxel Device. Accounting-on means accounting is being performed for the user login. Accounting-off means accounting has stopped for this user login. A “-” displays if accounting is not enabled for this login. |
RADIUS Profile Name | This field displays the name of the RADIUS profile used to authenticate the login through the captive portal. N/A displays for logins that do not use the captive portal and RADIUS server authentication. |
Dynamic Guest List | |
Remove | Select an entry and click this button to remove it from the list. |
Status | This field displays whether the dynamic user account is active or not. |
Username | This field displays the user name of the dynamic user account. |
Create Time | This field displays when the dynamic user account was created. |
Remaining Time | This field displays the amount of Internet access time remaining for each dynamic user account. |
Time Period | This field displays the duration of Internet access for the dynamic user account. |
Expiration Time | This field displays the date and time the Internet access becomes invalid. Once the time allocated to a dynamic account is used up or a dynamic account remains unused after the expiration time, the account is deleted from the account list. |
Quota (T/U/D) | This field displays how much data in both directions (Total) or upstream data (Upload) and downstream data (Download) can be transmitted through the WAN interface before the Internet access expires. |
Remaining Quota | This field displays how much more data can be transmitted through the WAN interface before the Internet access expires. |
Bandwidth (U/D) | This field displays the maximum upstream (Upload) and downstream (Download) bandwidth allowed for the dynamic user account in kilobits per second. |
Charge | This field displays access price per time unit. |
Payment Info | This field displays the method of payment for each account. |
Real Name | This field displays the user’s name of the account. |
Email | This field displays the email address of the account. |
Phone Number | This displays the user’s phone number. |
User Role | This field displays the role of the account. |
![]() | This guest account is un-used. |
![]() | This guest account is in use and online. |
![]() | This guest account has been used but is offline now. |
![]() | This guest account expired. |
![]() | This guest account has been deleted. |
# | This field is a sequential value, and it is not associated with a specific I GMP Statistics. |
Group | This field displays the group of devices in the IGMP. |
Source IP | This field displays the host source IP information of the IGMP. |
Incoming Interface | This field displays the incoming interface that’s connected on the IGMP. |
Packet Count | This field displays the packet size of the data being transferred. |
Bytes | This field displays the size of the data being transferred in Byes. |
Outgoing Interface | This field displays the outgoing interface that’s connected on the IGMP. |
Update | Click this to have the Zyxel Device update the profile to the DDNS server. The Zyxel Device attempts to resolve the IP address for the domain name. |
# | This field is a sequential value, and it is not associated with a specific DDNS server. |
Profile Name | This field displays the descriptive profile name for this entry. |
Domain Name | This field displays each domain name the Zyxel Device can route. |
Effective IP | This is the (resolved) IP address of the domain name. |
Last Update | This shows whether the last attempt to resolve the IP address for the domain name was successful or not. Updating means the Zyxel Device is currently attempting to resolve the IP address for the domain name. |
Last Update Time | This shows when the last attempt to resolve the IP address for the domain name occurred (in year-month-day hour:minute:second format). |
Interface | Select a Zyxel Device interface that has IP/MAC binding enabled to show to which devices it has assigned an IP address. |
# | This field is a sequential value, and it is not associated with a specific IP/MAC binding entry. |
IP Address | This is the IP address that the Zyxel Device assigned to a device. |
Host Name | This field displays the name used to identify this device on the network (the computer name). The Zyxel Device learns these from the DHCP client requests. |
MAC Address | This field displays the MAC address to which the IP address is currently assigned. |
Last Access | This is when the device last established a session with the Zyxel Device through this interface. |
Description | This field displays the description of the IP/MAC binding. |
More Information | Click this to display more information on your mobile broadband, such as the signal strength, IMEA/ESN and IMSI. This is only available when the mobile broadband device attached and activated on your Zyxel Device. |
# | This field is a sequential value, and it is not associated with any interface. |
Extension Slot | This field displays where the entry’s cellular card is located. |
Connected Device | This field displays the model name of the cellular card. |
Status | • No device - no mobile broadband device is connected to the Zyxel Device. • No Service - no mobile broadband network is available in the area; you cannot connect to the Internet. • Limited Service - returned by the service provider in cases where the SIM card is expired, the user failed to pay for the service and so on; you cannot connect to the Internet. • Device detected - displays when you connect a mobile broadband device. • Device error - a mobile broadband device is connected but there is an error. • Probe device fail - the Zyxel Device’s test of the mobile broadband device failed. • Probe device ok - the Zyxel Device’s test of the mobile broadband device succeeded. • Init device fail - the Zyxel Device was not able to initialize the mobile broadband device. • Init device ok - the Zyxel Device initialized the mobile broadband card. • Check lock fail - the Zyxel Device’s check of whether or not the mobile broadband device is locked failed. • Device locked - the mobile broadband device is locked. • SIM error - there is a SIM card error on the mobile broadband device. • SIM locked-PUK - the PUK is locked on the mobile broadband device’s SIM card. • SIM locked-PIN - the PIN is locked on the mobile broadband device’s SIM card. • Unlock PUK fail - Your attempt to unlock a WCDMA mobile broadband device’s PUK failed because you entered an incorrect PUK. • Unlock PIN fail - Your attempt to unlock a WCDMA mobile broadband device’s PIN failed because you entered an incorrect PIN. • Unlock device fail - Your attempt to unlock a CDMA2000 mobile broadband device failed because you entered an incorrect device code. • Device unlocked - You entered the correct device code and unlocked a CDMA2000 mobile broadband device. • Get dev-info fail - The Zyxel Device cannot get cellular device information. • Get dev-info ok - The Zyxel Device succeeded in retrieving mobile broadband device information. • Searching network - The mobile broadband device is searching for a network. • Get signal fail - The mobile broadband device cannot get a signal from a network. • Network found - The mobile broadband device found a network. • Apply config - The Zyxel Device is applying your configuration to the mobile broadband device. • Inactive - The mobile broadband interface is disabled. • Active - The mobile broadband interface is enabled. • Incorrect device - The connected mobile broadband device is not compatible with the Zyxel Device. • Correct device - The Zyxel Device detected a compatible mobile broadband device. • Set band fail - Applying your band selection was not successful. • Set band ok - The Zyxel Device successfully applied your band selection. • Set profile fail - Applying your ISP settings was not successful. • Set profile ok - The Zyxel Device successfully applied your ISP settings. • PPP fail - The Zyxel Device failed to create a PPP connection for the cellular interface. • Need auth-password - You need to enter the password for the mobile broadband card on the cellular edit screen. • Device ready - The Zyxel Device successfully applied all of your configuration and you can use the mobile broadband connection. |
Service Provider | This displays the name of your network service provider. This shows Limited Service if the service provider has stopped service to the mobile broadband card. For example if the bill has not been paid or the account has expired. |
Cellular System | This field displays what type of cellular network the mobile broadband connection is using. The network type varies depending on the mobile broadband card you inserted and could be UMTS, UMTS/HSDPA, GPRS or EDGE when you insert a GSM mobile broadband card, or 1xRTT, EVDO Rev.0 or EVDO Rev.A when you insert a CDMA mobile broadband card. |
Signal Quality | This displays the strength of the signal. The signal strength mainly depends on the antenna output power and the distance between your Zyxel Device and the service provider’s base station. |
Signal Strength | This is the Signal Quality measured in dBm. |
Device Manufacturer | This shows the name of the company that produced the mobile broadband device. |
Device Model | This field displays the model name of the cellular card. |
Device Firmware | This shows the software version of the mobile broadband device. |
Device IMEI/ESN | IMEI (International Mobile Equipment Identity) is a 15-digit code in decimal format that identifies the mobile broadband device. ESN (Electronic Serial Number) is an 8-digit code in hexadecimal format that identifies the mobile broadband device. |
SIM Card IMSI | IMSI (International Mobile Subscriber Identity) is a 15-digit code that identifies the SIM card. |
# | This is the index number of the UPnP-created NAT mapping rule entry. |
Remote Host | This field displays the source IP address (on the WAN) of inbound IP packets. Since this is often a wild-card, the field may be blank. When the field is blank, the Zyxel Device forwards all traffic sent to the External Port on the WAN interface to the Internal Client on the Internal Port. When this field displays an external IP address, the NAT rule has the Zyxel Device forward inbound packets to the Internal Client from that IP address only. |
External Port | This field displays the port number that the Zyxel Device “listens” non the WAN port) for connection requests destined for the NAT rule’s Internal Port and Internal Client. The Zyxel Device forwards incoming packets (from the WAN) with this port number to the Internal Client on the Internal Port (on the LAN). If the field displays “0”, the Zyxel Device ignores the Internal Port value and forwards requests on all external port numbers (that are otherwise unmapped) to the Internal Client. |
Protocol | This field displays the protocol of the NAT mapping rule (TCP or UDP). |
Internal Port | This field displays the port number on the Internal Client to which the Zyxel Device should forward incoming connection requests. |
Internal Client | This field displays the DNS host name or IP address of a client on the LAN. Multiple NAT clients can use a single port simultaneously if the internal client field is set to 255.255.255.255 for UDP mappings. |
Internal Client Type | This field displays the type of the client application on the LAN. |
Description | This field displays a text explanation of the NAT mapping rule. |
Delete All | Click this to remove all mapping rules from the NAT table. |
Device description | This is a basic description of the type of USB device. |
Usage | This field displays how much of the USB storage device’s capacity is currently being used out of its total capacity and what percentage that makes. |
Filesystem | This field displays what file system the USB storage device is formatted with. This field displays Unknown if the file system of the USB storage device is not supported by the Zyxel Device, such as NTFS. |
Speed | This field displays the connection speed the USB storage device supports. |
Status | Ready - you can have the Zyxel Device use the USB storage device. Click Remove Now to stop the Zyxel Device from using the USB storage device so you can remove it. Unused - the connected USB storage device was manually unmounted by using the Remove Now button or for some reason the Zyxel Device cannot mount it. Click Use It to have the Zyxel Device mount a connected USB storage device. This button is grayed out if the file system is not supported (unknown) by the Zyxel Device. none - no USB storage device is connected. |
Detail | This field displays any other information the Zyxel Device retrieves from the USB storage device. • Deactivated - the use of a USB storage device is disabled (turned off) on the Zyxel Device. • OutofSpace - the available disk space is less than the disk space full threshold. • Mounting - the Zyxel Device is mounting the USB storage device. • Removing - the Zyxel Device is unmounting the USB storage device. • none - the USB device is operating normally or not connected. |
Local Port (Description) | This field displays the port of the Zyxel Device, on which the neighboring device is discovered. For Zyxel Devices that support Port Role, if ports 3 to 5 are grouped together and there is a connection to P5 only, the Zyxel Device will display P3 as the interface port number (even though there is no connection to that port). |
Model Name | This field displays the model name of the discovered device. |
System Name | This field displays the system name of the discovered device. |
Firmware Version | This field displays the firmware version of the discovered device. |
Port (Description) | This field displays the first internal port on the discovered device. Internal is an interface type displayed on the Network > Interface > Ethernet > Edit screen. For example, if P1 and P2 are WAN, P3 to P5 are LAN, and P6 is DMZ, then Zyxel Device will display P3 as the first internal interface port number. For Zyxel Devices that support Port Role, if ports 3 to 5 are grouped together and there is a connection to P5 only, the Zyxel Device will display P3 as the first internal interface port number (even though there is no connection to that port). |
IP Address | This field displays the IP address of the discovered device. |
MAC Address | This field displays the MAC address of the discovered device. |
IPv4 FQDN Object Cache List You must first configure IPv4 FQDN objects in Configuration > Object > Address/Geo IP in the IPv4 Address Configuration field. | |
FQDN Object | Select a previously created object from the drop-down list box to display related FQDN object caches used in DNS queries. |
# | This is the index number of the FQDN entry. |
Name | This field displays the name of the selected FQDN object used in DNS queries. |
FQDN | This field displays a host’s fully qualified domain name. |
IP Address | This field displays the mapping of the FQDN to an IP address. This is the IP address of a host. |
TTL | This field displays the number of seconds the Zyxel Device holds IP address - FQDN object mapping in its cache. The mapping is updated when the TTL (Time To Live) setting expires. |
IPv6 FQDN Object Cache List You must first configure IPv6 FQDN objects in Configuration > Object > Address/Geo IP in the IPv6 Address Configuration field. | |
FQDN Object | Select an object from the drop-down list box to display related IPv6 FQDN object caches used in DNS queries. |
# | This is the index number of the IPv6 FQDN entry. |
Name | This field displays the name of the selected IPv6 FQDN object used in DNS queries. |
IP Address | This field displays the mapping of the FQDN to an IPv6 address. This is the IPv6 address of a host. |
View | Select how to view the virtual server load balancing traffic. • Traffic/Connections By Packets: This will display this number of connections and the number of bytes to/from a specific server. • Traffic/Connections By Rates: This will display this number of connections per second and the number of bytes per second to/from a specific server. |
# | This is the index number of a table entry. |
Server IP | This field displays the IP address of the real server to which the virtual server load balancing traffic is coming from/going to. |
Server Port | This field displays the port number on the real server that identifies the service the client requested. |
Status | This field displays the result of the health check. If the health check fails, it will display Off-line, if the health check is OK, it displays On-line. |
The following fields display when you choose Traffic/Connections By Packets | |
Active Connection | This field displays the number of active connections between the real server and clients for the specified service. |
Inactive Connection | This field displays the number of once active, but now idle connections between the real server and clients for the specified service. |
Incoming Packets | This field displays the number of packets going to the real server from clients for the specified service. |
Outgoing Packets | This field displays the number of packets coming from the real server to clients for the specified service. |
Incoming Bytes | This field displays the number of bytes going to the real server from clients for the specified service. |
Outgoing Bytes | This field displays the number of bytes coming from the real server to clients for the specified service. |
The following fields display when you choose Traffic/Connections By Rates | |
Connections/s | This field displays the number of connections per second between the real server and clients for the specified service. |
Incoming Packets/s | This field displays the number of packets per second going to the real server from clients for the specified service. |
Outgoing Packets/s | This field displays the number of packets per second coming from the real server to clients for the specified service. |
Incoming Bytes/s | This field displays the number of bytes per second going to the real server from clients for the specified service. |
Outgoing Bytes/s | This field displays the number of bytes per second coming from the real server to clients for the specified service. |
Filter | Click Show Advanced Settings to reveal Filter fields where you can display managed APs by status, keyword or those managed by the Nebula portal. |
AP List | Select the type of APs you want to display. Select All to show all kinds of APs that are currently or used to be connected to the Zyxel Device. Select NebulaFlexPRO to show the APs that can work in Nebula cloud management mode. |
Status | Select the status of APs you want to display. You can display APs managed by the Zyxel Device according to the following: • Online All: APs that are online now + APs with configuration conflict + APs with non-supported features + APs that are now updating firmware • Online: APs that are online now • Conflict: APs with configurations in conflict with the Zyxel Device (see More Details) • Non Support: APs with features not supported by the Zyxel Device (see More Details) • Updating: APs that are have updated firmware and rebooted • Offline All: Offline + Offline for Firmware Update • Offline: The CAPWAP server did not receive keep-alive packets from these APs in the last 2 minutes (Offline All - Offline for Firmware Update) • Offline for Firmware Update: APs that were rebooted before updating firmware • Un-Mgmt: APs that are not managed by the Zyxel Device |
Keyword | Enter a keyword to display the APs that include it in their AP information, such as model number, firmware version, MAC address and so on. This field is case-sensitive. |
Search | Click this to update the list of APs based on the search criteria. Your search criteria is retained when navigating between screens. |
Reset | Click this to return the search criteria to the factory defaults and display all currently or previously connected APs without a filter. |
Enable Column Freeze | Select this to lock the index columns in place while scrolling to the right. |
Edit the selected rule | Select an AP and click this to change the selected AP’s properties, such as its group, radio, VLAN and port settings. |
Add to Mgmt AP List | Select an AP and click this to add the selected AP to the managed AP list. |
Reboot device | Select one or multiple APs and click this button to force the AP(s) to restart. |
Remove the selected rule | Select one or multiple APs and click this button to remove the AP(s) from the manged AP list. |
DCS Now | Select one or multiple APs and click this button to use DCS (Dynamic Channel Selection) to allow the AP to automatically find a less-used channel in an environment where there are many APs and there may be interference. |
More Information | Select an AP and click this to view a daily station count about the selected AP. The count records station activity on the AP over a consecutive 24 hour period. |
Radio Information | Select an online AP and click this button to go to the Monitor > Wireless > AP Information > Radio List screen to view detailed information about the AP’s radios. |
Query Controller Log | Select one or multiple APs and click this button to go to the Monitor > Log > View Log screen to view the selected AP’s current log messages. |
Nebula | Select an AP and click this to open a screen where you can set whether the AP’s IP address and VLAN settings will be changed when it goes into Nebula cloud management mode. |
Upgrade Firmware Now | Select one or more APs and click this button to update the APs’ firmware version. |
Suppression On | Select an AP and click this button to enable the AP’s LED suppression mode. All the LEDs of the AP will turn off after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode. |
Suppression Off | Select an AP and click this button to disable the AP’s LED suppression mode. The AP LEDs stay lit after the AP is ready. This button is not available if the selected AP doesn’t support suppression mode. |
Locator On | Select an AP and click this button to run the locator feature. The AP’s Locator LED will start to blink for 10 minutes by default. It will show the actual location of the AP between several devices on the network. |
# | This field is a sequential value, and it is not associated with any entry. |
Status | This field displays the status of AP. • Online All: APs that are online now + APs with configuration conflict + APs with non-supported features + APs that are now updating firmware • Online: APs that are online now • Conflict: APs with configurations in conflict with the Zyxel Device (see More Details) • Non Support: APs with features not supported by the Zyxel Device (see More Details) • Updating: APs that are have updated firmware and rebooted • Offline All: Offline + Offline for Firmware Update • Offline: The CAPWAP server did not receive keep-alive packets from these APs in the last 2 minutes (Offline All - Offline for Firmware Update) • Offline for Firmware Update: APs that were rebooted before updating firmware • Un-Mgmt: APs that are not managed by the Zyxel Device |
Description | This field displays the AP’s description, which you can configure by selecting the AP’s entry and clicking the Edit button. |
CPU Usage | This field displays the CPU Usage of the AP. |
IP Address | This field displays the IP address of the AP. |
MAC Address | This field displays the MAC address of the AP. |
Station 2.4G | This field displays the number of 2.4G wireless clients connected to the AP. |
Station 5G | This field displays the number of 5G wireless clients connected to the AP. |
Station 6G | This field displays the number of 6G wireless clients connected to the AP. |
Recent Online Time | This displays the most recent time the AP came on-line. N/A displays if the AP has not come on-line since the Zyxel Device last started up. |
Power | This field displays the AP’s power status. Full - the AP receives power using a power adapter and/or through a PoE switch/injector using IEEE 802.3at PoE plus. The PoE device that supports IEEE 802.3at PoE Plus can supply power of up to 30W per Ethernet port. Limited - the AP receives power through a PoE switch/injector using IEEE 802.3af PoE even when it is also connected to a power source using a power adaptor. The PoE device that supports IEEE 802.3af PoE can supply power of up to 15.4W per Ethernet port. When the AP is in limited power mode, the AP throughput decreases and has just one transmitting radio chain. It always shows Full if the AP does not support power detection. |
Type | This indicates whether the AP is on the managed AP list (Mgmt) or not (Un-Mgmt). This displays Limited when the AP is configured by conflicted or unsupported setting(s). |
Model | This field displays the AP’s hardware model information. It displays N/A (not applicable) only when the AP disconnects from the Zyxel Device and the information is unavailable as a result. |
R1 Mode/ Profile/ ZyMesh Profile | This field displays the operating mode (AP, MON, rootap, or repeater), AP radio profile name and ZyMesh profile name for Radio1. It displays - for the ZyMesh profile for a radio not using a ZyMesh profile. |
R2 Mode/ Profile/ ZyMesh Profile | This field displays the operating mode (AP, MON, rootap, or repeater), AP radio profile name and ZyMesh profile name for Radio2. It displays - for the ZyMesh profile for a radio not using a ZyMesh profile. |
R3 Mode/ Profile/ ZyMesh Profile | This field displays the operating mode (AP, MON, rootap, or repeater), AP radio profile name and ZyMesh profile name for Radio3. It displays - for the ZyMesh profile for a radio not using a ZyMesh profile. |
Version | This field displays the AP’s current firmware version. |
Group | This displays the name of the AP group to which the AP belongs. |
Mgnt. VLAN ID (AC/AP) | This displays the Access Controller (the Zyxel Device) and runtime management VLAN ID setting for the AP. VLAN Conflict displays if the AP’s management VLAN ID does not match the Mgmnt. VLAN ID(AC). This field displays n/a if the Zyxel Device cannot get VLAN information from the AP. |
Last Off-line Time | This field displays the date and time that the AP was last logged out. |
LED Status | This field displays the AP LED status. N/A displays if the AP does not support LED suppression mode and/or have a locator LED to show the actual location of the AP. A gray LED icon signifies that the AP LED suppression mode is enabled. All the LEDs of the AP will turn off after the AP is ready. A green LED icon signifies that the AP LED suppression mode is disabled and the AP LEDs stay lit after the AP is ready. A sun icon signifies that the AP’s locator LED is blinking. A circle signifies that the AP’s locator LED is extinguished. |
Ethernet Uplink | This field displays the AP’s uplink port speed and duplex mode (Full or Half). |
Bluetooth | This field displays the AP’s Bluetooth Low Energy (BLE) capability. Bluetooth Low Energy, which is also known as Bluetooth Smart, transmits less data over a shorter distance and consumes less power than classic Bluetooth. APs communicate with other BLE enabled devices using advertisements. N/A displays if the AP does not support BLE. Unavailable displays if the AP supports Bluetooth, but there is no BLE USB dongle connected to the USB port of the AP. Some APs, such as the WAC5302D-S, need to have a supported BLE USB dongle attached to act as a beacon to broadcast packets. Available displays if the AP supports Bluetooth, detects a BLE device and advertising is inactive. Advertising displays if the AP supports Bluetooth, detects a BLE device and advertising is activated, which means the BLE device can broadcasts packets to every device around it. |
Location | This field displays the AP’s location you configured. |
Roaming Group | This field displays the name of roaming group to which the AP belongs. |
Load Balancing Group | This field displays the AP’s load balance status when load balancing is enabled on the Zyxel Device. Otherwise, it shows nothing when load balancing is disabled or the radio is in monitor mode. |
S/N | This field displays the serial number of the AP. |
System Name | This field displays the system name to identify the AP on a network. |
Refresh | Click Refresh to update the AP list. |
Configuration Status | This displays whether or not any of the AP’s configuration is in conflict with the Zyxel Device’s settings for the AP. |
Conflict | If any of the AP’s configuration conflicts with the ZyWALL’s settings for the AP, this field displays which configuration conflicts. It displays n/a if none of the AP’s configuration conflicts with the ZyWALL’s settings for the AP. |
Non Support | If any of the AP’s configuration conflicts with the Zyxel Device’s settings for the AP, this field displays which configuration conflicts. It displays n/a if none of the AP’s configuration conflicts with the Zyxel Device’s settings for the AP. |
Port Status | |
Port | This shows the name of the physical Ethernet port on the Zyxel Device. |
Status | This field displays the current status of each physical port on the AP. Down - The port is not connected. Speed / Duplex - The port is connected. This field displays the port speed and duplex setting (Full or Half). |
PVID | This shows the port’s PVID. A PVID (Port VLAN ID) is a tag that adds to incoming untagged frames received on a port so that the frames are forwarded to the VLAN group that the tag defines. |
Tx Bcast | This field displays the number of broadcast packets transmitted on the port. |
Rx Bcast | This field displays the number of broadcast packets received on the port. |
VLAN Configuration | |
Name | This shows the name of the VLAN. |
Status | This displays whether or not the VLAN is activated. |
VID | This shows the VLAN ID number. |
Member | This field displays the Ethernet port(s) that is a member of this VLAN. |
Ethernet Neighbor | |
Station Count | |
The y-axis represents the number of connected stations. | |
The x-axis shows the time over which a station was connected. | |
Create new Object | Use this menu to create a new Radio Profile object to associate with this AP. |
MAC | This displays the MAC address of the selected AP. |
Description | Enter a description for this AP. You can use up to 31 characters, spaces and underscores allowed. |
Group Setting | Select an AP group to which you want this AP to belong. |
System Name | Enter a name to identify the AP on a network. This is usually the AP’s fully qualified domain name. |
Location | Specify the name of the place where the AP is located. |
Roaming Group | Specify the name of the roaming group to which the AP belongs. You can use up to 31 alphanumeric and @# characters. Dashes and underscores are also allowed. The name should start with a letter or digit. The 802.11k neighbor list a client requests from the AP is generated according to the roaming group and RCPI (Received Channel Power Indicator) value of its neighbor APs. When a client wants to roam from the current AP to another, other APs in the same roaming group or not in a roaming group will be candidates for roaming. Neighbor APs in a different roaming group will be excluded from the 802.11k neighbor lists even when the neighbor AP has the best signal strength. If the AP’s roaming group is not configured, any neighbor APs can be candidates for roaming. |
Load Balancing Group 1/2 | Load balancing is only applied to APs within the same group. If a load balancing group is not assigned to an AP, it will belong to a default group. Each AP can belong to up to two groups. |
Radio 1/2/3 Setting | |
Override Group Radio Setting | Select this option to overwrite the AP radio settings with the settings you configure here. |
Radio 1/2/3 OP Mode | Select the operating mode for radio 1, radio 2 or radio 3. AP Mode means the AP can receive connections from wireless clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). MON Mode means the AP monitors the broadcast area for other APs, then passes their information on to the Zyxel Device where it can be determined if those APs are friendly or rogue. If an AP is set to this mode it cannot receive connections from wireless clients. |
Radio 1/2/3 Profile | Select a profile from the list. If no profile exists, you can create a new one through the Create new Object menu. |
Override Group Output Power Setting | Select this option to overwrite the AP output power setting with the setting you configure here. |
Output Power | Set the output power of the AP. |
Override Group SSID Setting | Select this option to overwrite the AP SSID profile setting with the setting you configure here. This section allows you to associate an SSID profile with the radio. |
Edit | Select an SSID and click this button to reassign it. The selected SSID becomes editable immediately upon clicking. |
# | This is the index number of the SSID profile. You can associate up to eight SSID profiles with an AP radio. |
SSID Profile | Indicates which SSID profile is associated with this radio profile. |
IP Setting | |
Force Overwrite IP Setting | Select this to change the AP’s IP address setting to match the configuration in this screen. |
Get Automatically | Select this to have the AP act as a DHCP client and automatically get the IP address, subnet mask, and gateway address from a DHCP server. |
Used Fixed IP Address | Select this if you want to specify the IP address, subnet mask, gateway and DNS server address manually. |
IP Address | Enter the IP address for the AP. |
Subnet Mask | Enter the subnet mask of the AP in dot decimal notation. The subnet mask indicates what part of the IP address is the same for all devices in the network. |
Gateway | Enter the IP address of the gateway. The AP sends packets to the gateway when it does not know how to route the packet to its destination. The gateway should be on the same network as the AP. |
DNS Server IP Address | Enter the IP address of the DNS server. |
VLAN Settings | |
Override Group VLAN Setting | Select this option to overwrite the AP VLAN setting with the setting you configure here. |
Force Overwrite VLAN Config | Select this to have the Zyxel Device change the AP’s management VLAN to match the configuration in this screen. |
Management VLAN ID | Enter a VLAN ID for this AP. |
As Native VLAN | Select this option to treat this VLAN ID as a VLAN created on the Zyxel Device and not one assigned to it from outside the network. |
Storm Control Setting | Traffic storm control limits the number of broadcast and/or multicast packets the Zyxel Device receives on the ports. When the maximum number of allowable broadcast and/or multicast packets is reached, the subsequent packets are discarded. Select Broadcast Storm Control to enable broadcast storm control on the Zyxel Device. Enabling this will drop ingress broadcast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. Select Multicast Storm Control to enable multicast storm control on the Zyxel Device. Enabling this will drop ingress multicast traffic in the physical Ethernet port if it exceeds the maximum traffic rate. |
Rogue AP Detection Setting | This feature allows the Zyxel Device to monitor the WiFi signals for other wireless APs. A rogue AP is a wireless access point operating in a network’s coverage area that is not under the control of the network administrator, and which can potentially open up holes in a network’s security. Select this checkbox to detect Rogue APs in the network. |
Antenna Setting | Select Wall if you mount the Zyxel Device to a wall. Select Ceiling if the Zyxel Device is mounted on a ceiling. You can switch from Wall to Ceiling if there are still wireless dead zones, and vice versa. |
LED Suppression Mode Configuration | If the Suppression On checkbox is checked, the LEDs of yourZyxel Device will turn off after it’s ready. If the checkbox is unchecked, the LEDs will stay lit after theZyxel Device is ready. |
Power Setting | Select this checkbox if you are using a PoE injector that does not support PoE negotiation. Otherwise, the Zyxel Device cannot draw full power from the power sourcing equipment. Enable this power mode to improve the Zyxel Device’s performance in this situation. |
Locator LED Configuration | Click Turn On button to activate the locator. The Locator function will show the actual location of the Zyxel Device between several devices in the network. Otherwise, click Turn Off to disable the locator feature. |
Automatically Extinguish After | Enter a time interval between 1 and 60 minutes to stop the locator LED from blinking. Default is 10 minutes. |
Reset AP Configuration | Click Apply Factory Default to reset all of the AP settings to the factory defaults. |
Cancel | Click Cancel to close the window with changes unsaved. |
More Information | Click this icon to see the traffic statistics, station count, SSID, Security Mode and VLAN ID information on the AP. |
# | This field is a sequential value, and it is not associated with a specific radio. |
Loading | This indicates the AP’s load balance status (UnderLoad or OverLoad) when load balancing is enabled on the AP. Otherwise, it shows - when load balancing is disabled or the radio is in monitor mode. |
AP Description | Enter a description for this AP. You can use up to 31 characters, spaces and underscores allowed. |
Frequency Band | This field displays the WLAN frequency band using the IEEE 802.11 a/b/g/n standard of 2.4 or 5 GHz. |
Channel ID | This field displays the WLAN channels using the IEEE 802.11 protocols. |
Tx Power | This shows the radio’s output power (in dBm). |
Station | This field displays the station count information. |
Rx | This field displays the total number of bytes received by the radio. |
Tx | This field displays the total number of bytes transmitted by the radio. |
Radio | This field displays the Radio number. For example 1. |
OP Mode | This field displays the operating mode of the AP. It displays n/a for the profile for a radio not using an AP profile. AP Mode means the AP can receive connections from wireless clients and pass their data traffic through to the Zyxel Device to be managed (or subsequently passed on to an upstream gateway for managing). |
MBSSID Detail | This list shows information about the SSID(s) that is associated with the radio over the preceding 24 hours. |
# | This is the items sequential number in the list. It has no bearing on the actual data in this list. |
SSID Name | This displays an SSID associated with this radio. There can be up to eight maximum. |
BSSID | This displays the MAC address associated with the SSID. |
Security Mode | This displays the security mode in which the SSID is operating. |
Forwarding Mode | This field indicates the forwarding mode (Local Bridge or Tunnel) associated with the SSID profile. |
VLAN | This displays the VLAN ID associated with the SSID. |
Traffic Statistics | This graph displays the overall traffic information about the radio over the preceding 24 hours. |
y-axis | This axis represents the amount of data moved across this radio in megabytes per second. |
x-axis | This axis represents the amount of time over which the data moved across this radio. |
Station Count | This graph displays information about all the wireless clients that have connected to the radio over the preceding 24 hours. |
y-axis | The y-axis represents the number of connected wireless clients. |
x-axis | The x-axis shows the time over which a wireless client was connected. |
Last Update | This field displays the date and time the information in the window was last updated. |
OK | Click this to close this window. |
Cancel | Click this to close this window. |
Single Station Status | |
Usage by | Select the measure unit in GB or MB to display the graph. |
Traffic Usage | This graph displays traffic in the preceding 24 hours. |
y-axis | The y-axis represents the amount of traffic in megabytes/gigabytes. |
x-axis | The x-axis represents the time over which wireless traffic flows transmitting from/to the AP. |
Station Count | This graph displays the number of wireless stations that have connected to the AP in the preceding 24 hours. |
y-axis | The y-axis represents the number of connected wireless stations. |
x-axis | The x-axis represents the time over which a wireless client was connected. |
Refresh | Click Refresh to update this screen. |
View | Select this to view the top five or top ten wireless traffic for the preceding 24 hours. |
Usage by | If you view the data usage by Usage, select the frequency band and the measure unit in GB or MB to display the graph. If you view the date usage by Station Number, select the measure unit in GB or MB to display the graph. |
Traffic Usage | This graph displays the overall traffic information about the top five or top ten wireless traffic for the preceding 24 hours. |
Station Count | This graph displays information about all the wireless stations that have connected to the AP for the preceding 24 hours. |
AP Selection | Select a managed AP from the drop-down list box to view its wireless traffic usage and wireless stations. |
Traffic Usage | This graph displays the overall traffic information about the AP you specified for the preceding 24 hours. |
# | This field displays the index number of the managed AP (in repeater mode) in this list. |
Description | This field displays the descriptive name of the managed AP (in repeater mode). |
IP Address | This field displays the IP address of the managed AP (in repeater mode). |
Channel ID | This field displays the number of the channel used by the managed AP (in repeater mode). |
Hop | This is the hop count of the managed AP. For example, “1” means the managed AP is connected to a root AP directly. “2” means there is another repeater AP between the managed AP and the root AP. |
Uplink AP Info | This shows the role and descriptive name of the managed AP to which this managed AP is connected wirelessly. |
SSID Name | This indicates the name of the wireless network (SSID) the managed AP uses to associated with another managed AP. |
Signal Strength | Before the slash, this shows the signal strength the uplink AP (a root AP or a repeater) receives from this managed AP (in repeater mode). After the slash, this shows the signal strength this managed AP (in repeater mode) receives from the uplink AP. |
Link Up Time | This field displays the time the managed AP first associated with the root AP or repeater. |
MAC Address | This field displays the MAC address of the managed AP (in repeater mode). |
Tx Power | This field displays the output power of the managed AP (in repeater mode). |
Root AP | This field displays the descriptive name of the root AP to which the managed AP is connected wirelessly. |
Tx Rate | This field displays the maximum transmission rate of the root AP or repeater to which the managed AP is connected. |
Rx Rate | This field displays the maximum reception rate of the root AP or repeater to which the managed AP is connected. |
# | This is the SSID’s index number in this list. |
SSID | This indicates the name of the wireless network to which the client is connected. A single AP can have multiple SSIDs or networks. |
2.4GHz | This shows the number of wireless clients which are currently connected to the SSID using the 2.4 GHz frequency band, Click the number to go to the Station Info > Station List screen. See Station Info: Top N Stations. |
5GHz | This shows the number of wireless clients which are currently connected to the SSID using the 5 GHz frequency band, Click the number to go to the Station Info > Station List screen. See Station Info: Top N Stations. |
6GHz | This shows the number of wireless clients which are currently connected to the SSID using the 6 GHz frequency band, Click the number to go to the Station Info > Station List screen. See Station Info: Top N Stations. |
SSID Profile Name | This indicates the name of the SSID profile in which the SSID is defined, |
Security Mode | This indicates which secure encryption methods is being used by the SSID. |
Show Filter/ Hide Filer | Click this button to show or hide the filter settings. |
Filter | |
IP Address | Enter the IP address of the station you want to display. This field is case-sensitive. |
Associated AP | Select the AP(s) with which the stations you want to display associate. |
SSID Name | Select the SSID(s) to which the stations you want to display are connected. |
MAC Address | Enter the MAC address of the station you want to display. This field is case-sensitive. |
Security Mode | Select the security mode(s) used by the stations you want to display. |
Account | Enter the user account name of the station you want to display. This field is case-sensitive. |
Login Type | Select the login method(s) used by the stations you want to display. |
Band | Select the frequency band used by the stations you want to display. |
Search | Click this to update the list of stations based on the search criteria. Your search criteria is retained when navigating between screens. |
Reset | Click this to return the search criteria to the factory defaults and display all connected stations without a filter. |
Station List | |
# | This field is a sequential value, and it is not associated with a specific station. |
MAC Address | This field displays the MAC address of the station. |
SSID Name | This field displays the SSID names of the station. |
Associated AP | This field displays the APs that are associated with the station. |
IP Address | This field displays the IP address of the station. |
Channel | This field displays the number of the channel used by the station to connect to the network. |
Rx Rate | This field displays the receive data rate of the station. |
Tx Rate | This field displays the transmit data rate of the station. |
Signal Strength | This field displays the signal strength of the station. |
Association Time | This field displays the time duration the station was online and offline. |
Enterprise | This field displays the RADIUS server of the station. |
Captive Portal | This displays whether the station logged into the network through the captive portal login page. |
MAC Auth | This displays whether the station logged into the network through MAC authentication. |
Band | This field displays the frequency band which is currently being used by the station. |
Capability | This displays the supported standard currently being used by the station or the standards supported by the station. |
802.11 Features | This displays whether the station supports IEEE802.11r, IEEE 802.11k, IEEE 802.11v or none of the above (N/A). |
Security Mode | This field displays the security mode the station is using. |
Download | This field displays the number of bytes received by the station. |
Upload | This field displays the number of bytes transmitted from the station. |
View | Select this to view the top five or top ten traffic statistics of the wireless stations. |
Traffic Usage | This graph displays the overall traffic information about the stations for the preceding 24 hours. |
y-axis | This axis represents the amount of data moved across stations in megabytes per second. |
Station Selection | Select this to view the traffic statistics of the wireless station. |
Traffic Usage | This graph displays the overall traffic information about the station over the preceding 24 hours. |
y-axis | This axis represents the amount of data moved across this station in megabytes per second. |
Discovered APs | |
Rogue AP | This shows how many devices are detected as rogue APs. |
Suspected rogue AP | This shows how many devices are detected as possible rogue APs. |
Friendly AP | This shows how many devices are detected as friendly APs. |
Un-Classified AP | This shows how many devices are detected, but have not been classified as either Rogue or Friendly by the Zyxel Device. |
Detect now | Click this button for the Zyxel Device to scan for APs in the network. |
Mark as Rogue AP | Click this button to mark the selected AP as a rogue AP. A rogue AP can be contained on the Configuration > Wireless > MON Mode screen. |
Mark as Friendly AP | Click this button to mark the selected AP as a friendly AP. For more on managing friendly APs, see the Configuration > Wireless > MON Mode screen. |
# | This is the station’s index number in this list. |
Role | This indicates the detected device’s role (such as friendly or rogue). |
Classified by | This indicates the detected device’s classification rule. |
MAC Address | This indicates the detected device’s MAC address. |
SSID Name | This indicates the detected device’s SSID. |
Channel ID | This indicates the detected device’s channel ID. |
802.11 Mode | This indicates the 802.11 mode (a/b/g/n) transmitted by the detected device. |
Security | This indicates the encryption method (if any) used by the detected device. |
Seen by | This indicates which AP detects the device. If an AP in monitor mode detected this AP, this column will show “N/A”. If an AP using Rogue AP Detection detected this device, it will show the name of the AP and the signal strength from the detected device. If the wireless device is detected by more than one AP, only the top 5 APs with the highest signal strength will be shown. |
Group | This indicates which group the detected device belongs. |
Description | This displays the detected device’s description. For more on managing friendly and rogue APs, see the Configuration > Wireless > MON Mode screen. |
Last Seen | This indicates the last time the device was detected by the Zyxel Device. |
Refresh | Click this to refresh the items displayed on this page. |
Label | Description |
Top 10 Alert Count | This chart shows the top 10 APs that are in poor states of wireless health for the most times. |
Date | This field shows the current date in theZyxel Device. |
Radio Alert Count | Select 2.4G, 5G or 6G to view the APs 2.4G, 5G or 6G radios wireless health. |
y-axis | The y-axis represents the state of wireless health. |
x-axis | The x-axis shows the time period over which the APs health states are recorded. |
Station Alert Count | This chart shows how many times the client is in a poor state or wireless health. |
x-axis | The x-axis shows the time period over which the client health state is recorded. |
# | This is the index number of the printer in the list. |
IPv4 Address | This field displays the IP address of the printer that you configured in the screen. |
Update Time | This field displays the date and time the Zyxel Device last synchronized with the printer. This shows n/a when the printer status is sync fail. |
Status | This field displays whether the Zyxel Device can connect to the printer and update the printer information. |
Description | This field displays the descriptive name of the printer that you configured in the screen. |
Nickname | This field displays the nickname of the printer that you configured in the Edit screen. |
Firmware Version | This field displays the model number and firmware version of the printer. This shows n/a when the printer status is sync fail. |
MAC | This field displays the MAC address of the printer. |
Name | Enter the name of a IPSec SA here and click Search to find it (if it is associated). You can use a keyword or regular expression. Use up to 30 alphanumeric and _+-.()!$*^:?|{}[]<>/ characters. See Regular Expressions in Searching IPSec SAs for more details. |
Policy | Enter the IP address(es) or names of the local and remote policies for an IPSec SA and click Search to find it. You can use a keyword or regular expression. Use up to 30 alphanumeric and _+-.()!$*^:?|{}[]<>/ characters. See Regular Expressions in Searching IPSec SAs for more details. |
Search | Click this button to search for an IPSec SA that matches the information you specified above. |
Disconnect | Select an IPSec SA and click this button to disconnect it. |
Connection Check | Select an IPSec SA and click this button to check the connection. |
# | This field is a sequential value, and it is not associated with a specific SA. |
User | This field only displays the client names if they’re using EAP or X-auth for authentication. If a client is connected to the Zyxel Device without using Extended Authentication Protocol (EAP) or X-Auth, this field will be empty. |
Serial Number | This field displays the serial number of this Zyxel Device. |
System Name | This field displays the name used to identify the Zyxel Device. |
Name | This field displays the name of the IPSec SA. |
Policy | This field displays the content of the local and remote policies for this IPSec SA. The IP addresses, not the address objects, are displayed. |
My Address | This field displays the IP address of local computer. |
Secure Gateway | This field displays the secure gateway information. |
Up Time | This field displays how many seconds the IPSec SA has been active. This field displays N/A if the IPSec SA uses manual keys. |
Timeout | This field displays how many seconds remain in the SA life time, before the Zyxel Device automatically disconnects the IPSec SA. This field displays N/A if the IPSec SA uses manual keys. |
Inbound (Bytes) | This field displays the amount of traffic that has gone through the IPSec SA from the remote IPSec router to the Zyxel Device since the IPSec SA was established. |
Outbound (Bytes) | This field displays the amount of traffic that has gone through the IPSec SA from the Zyxel Device to the remote IPSec router since the IPSec SA was established. |
label | description |
Disconnect | Select a connection and click this button to terminate the user’s connection and delete corresponding session information from the Zyxel Device. |
# | This field is a sequential value, and it is not associated with a specific SSL. |
User | This field displays the account user name used to establish this SSL VPN connection. |
Access | This field displays the name of the SSL VPN application the user is accessing. |
Login Address | This field displays the IP address the user used to establish this SSL VPN connection. |
Connected Time | This field displays the time this connection was established. |
Inbound (Bytes) | This field displays the number of bytes received by the Zyxel Device on this connection. |
Outbound (Bytes) | This field displays the number of bytes transmitted by the Zyxel Device on this connection. |
Disconnect | Select a connection and click this button to disconnect it. |
# | This field is a sequential value, and it is not associated with a specific L2TP VPN session. |
User Name | This field displays the remote user’s user name. |
Hostname | This field displays the name of the computer that has this L2TP VPN connection with the Zyxel Device. |
Assigned IP | This field displays the IP address that the Zyxel Device assigned for the remote user’s computer to use within the L2TP VPN tunnel. |
Public IP | This field displays the public IP address that the remote user is using to connect to the Internet. |
Name | Enter the name of a remote AP here and click Search to find it (if it is associated). You can use a keyword or regular expression. Use up to 30 alphanumeric and _+-.()!$*^:?|{}[]<>/ characters. See Regular Expressions in Searching IPSec SAs for more details. |
Policy | Enter the IP address or name of the local and remote policies for a remote AP and click Search to find it. You can use a keyword or regular expression. Use up to 30 alphanumeric and _+-.()!$*^:?|{}[]<>/ characters. See Regular Expressions in Searching IPSec SAs for more details. |
Search | Click this button to search for a remote AP that matches the information you specified above. |
Disconnect | Select a remote AP and click this button to disconnect it. |
# | This field is a sequential value, and it is not associated with a specific remote AP. |
Remote AP Description | This fields displays the remote AP description, which you can configure in Configuration> Wireless> AP Management, see AP Management Screens for more information. |
Assigned IP | This field displays the IP address the Zyxel Device assigns to the remote AP from the IP address pool you set in Configuration > VPN > Remote AP VPN. See Remote AP VPN for more information. |
Policy | This field displays the content of the local and remote policies for this remote AP. The IP addresses, not the address objects, are displayed. |
My Address | This field displays the IP address of the Zyxel Device. |
Secure Gateway | This field displays the IP address of the remote AP. |
Up Time | This field displays how many seconds the remote AP has been connected to the Zyxel Device. |
Timeout | This field displays how many seconds remain before the Zyxel Device disconnects from the remote AP. |
Inbound (Bytes) | This field displays the amount of traffic that has gone through the IPSec tunnel from the remote AP to the Zyxel Device since the remote AP was established. |
Outbound (Bytes) | This field displays the amount of traffic that has gone through the IPSec tunnel from the Zyxel Device to the remote AP since the remote AP was established. |
Collect Statistics | Select this checkbox to have the Zyxel Device collect app patrol statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Apply | Click Apply to save your changes back to the Zyxel Device. |
Reset | Click Reset to return the screen to its last-saved settings. |
Refresh | Click this button to update the report display. |
Flush Data | Click this button to discard all of the screen’s statistics and update the report display. |
App Patrol Statistics | |
# | This field is a sequential value, and it is not associated with a specific App Patrol session. |
Application | This is the protocol. |
Forwarded Data (KB) | This is how much of the application’s traffic the Zyxel Device has sent (in kilobytes). |
Dropped Data (KB) | This is how much of the application’s traffic the Zyxel Device has discarded without notifying the client (in kilobytes). This traffic was dropped because it matched an application policy set to “drop”. |
Rejected Data (KB) | This is how much of the application’s traffic the Zyxel Device has discarded and notified the client that the traffic was rejected (in kilobytes). This traffic was rejected because it matched an application policy set to “reject”. |
Matched Auto Connection | This is how much of the application’s traffic the Zyxel Device identified by examining the IP payload. |
Inbound Kbps | This field displays the amount of the application’s traffic that has gone to the ZyWALL (in kilo bits per second). |
Outbound Kbps | This field displays the amount of the application’s traffic that has gone from the ZyWALL (in kilo bits per second). |
General Settings | |
Collect Statistics | Select this checkbox to have the Zyxel Device collect web content filtering statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Summary | |
Total Web Page Inspected | This field displays the number of web pages that the Zyxel Device’s web content filter feature has checked. |
Blocked | This is the number of web pages that the Zyxel Device blocked access. |
Web Pages Blocked by Category Service | This is the number of web pages that matched an external database web content filtering category selected in the Zyxel Device and for which the Zyxel Device displayed a warning before allowing users access. |
Web Page Blocked by Custom Service | This is the number of web pages to which the Zyxel Device did not allow access due to the web content filtering custom service configuration. |
Restricted Web Features | This is the number of web pages to which the ZyWALL limited access or removed cookies due to the content filtering custom service's restricted web features configuration. |
Forbidden Web Sites | This is the number of web pages to which the Zyxel Device did not allow access because they matched the content filtering custom service’s forbidden web sites list. |
URL Keywords | This is the number of web pages to which the Zyxel Device did not allow access because they contained one of the content filtering custom service’s list of forbidden keywords. |
Warned | This is the number of web pages for which the Zyxel Device displayed a warning message to the access requesters. |
Passed | This is the number of web pages to which the Zyxel Device allowed access. |
Collect Statistics | Select this checkbox to have the Zyxel Device collect DNS content filtering statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Summary | |
Total DNS Inspected | This field displays the number of FQDNs that the Zyxel Device’s DNS content filter feature has checked. |
Redirected | This is the number of FQDNs that the Zyxel Device redirects. |
Passed | This is the number of FQDNs to which the Zyxel Device allowed access. |
Collect Statistics | Select this checkbox to have the Zyxel Device collect anti- statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Total Viruses Detected | This field displays the number of different viruses that the Zyxel Device has detected. |
Top Entries By | Use this field to have the following (read-only) table display the top anti- log entries by Virus Name, Source IP, and Destination IP, Source IPv6 and Destination IPv6. This table displays the most common, recent virus logs. See the log screen for less common virus logs or use a syslog server to record all virus logs. Select Virus Name to list the most common viruses that the Zyxel Device has detected. Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most virus-infected files. Select Destination IP to list the most common destination IP addresses for virus-infected files that Zyxel Device has detected. Select Source IPv6 to list the source IPv6 addresses from which the Zyxel Device has detected the most virus-infected files. Select Destination IPv6 to list the most common destination IPv6 addresses for virus-infected files that Zyxel Device has detected. |
Add to allow list | Select an entry and click this to add it to the anti-malware allow list. |
Remove from allow list | Select an entry and click this to remove it from the anti-malware allow list. |
# | This field displays the entry’s rank in the list of the top entries. |
Virus name | This column displays when you display the entries by Virus Name. This displays the name of a detected virus. |
Hash | This column displays a hash value, MD5 (Message Digest 5) and SHA (Secure Hash Algorithm), of the detected virus file. MD5 and SHA are hash algorithms used to authenticate packet data. |
Source IP | This column displays when you display the entries by Source IP. It shows the source IP address of virus-infected files that the Zyxel Device has detected. |
Source IPv6 | his column displays when you display the entries by Source IPv6. It shows the source IPv6 address of virus-infected files that the Zyxel Device has detected. |
Destination IP | This column displays when you display the entries by Destination IP. It shows the destination IP address of virus-infected files that the Zyxel Device has detected. |
Destination IPv6 | This column displays when you display the entries by Destination IPv6. It shows the destination IPv6 address of virus-infected files that the Zyxel Device has detected. |
Occurrences | This field displays how many times the Zyxel Device has detected the event described in the entry. |
Allow List | Click this to add this signature to the anti-malware allow list.Click this to remove this signature from the anti-malware allow list. |
Summary | |
IP Scanned | This field displays the total number of IPv4 addresses that have been scanned. |
IP Hit Count | This field displays the total number of the hit counts on the scanned IPv4 addresses. |
Statistics | |
Add to allow list | Select an entry and click this to add it to the IP reputation allow list. |
Remove from allow list | Select an entry and click this to remove it from the IP reputation allow list. |
Time | This field displays the date and time the entry was created. |
Malicious IP | This field displays the IPv4 address with bad reputation. |
Infected/Victim Host | This field displays the MAC address of the infected host. |
Threat Category | This field displays the category of the entry. |
Threat Level | This field displays the threat level of the entry. |
Summary | |
DNS Filter Scanned | This field displays the total number of FQDNs that have been scanned. |
DNS Filter Hit Count | This field displays the total number of the hit counts on the scanned FQDNs. |
Statistics | |
Add to allow list | Select an entry and click this to add it to the DNS filtering allow list. |
Remove from allow list | Select an entry and click this to remove it from the DNS filtering allow list. |
Source IP | This field displays the source IP address of traffic that you want to trace. |
FQDN | This field displays the FQDN of an infected website. |
Summary | |
URL Scanned | This field displays the total number of URLs that have been scanned. |
URL Hit Count | This field displays the total number of the hit counts on the scanned URLs. |
Statistics | |
Add to allow list | Select an entry and click this to add it to the URL Threat filtering allow list. |
Remove from allow list | Select an entry and click this to remove it from the URL Threat filtering allow list. |
Destination IP | This field displays the destination IP address of traffic. |
Threat URL | This field displays the URL of an infected website or a botnet C&C server. IP reputation only blocks incoming and outgoing traffic coming from an IP address that is defined as botnet. If an IP address is not defined as botnet, only incoming traffic is blocked. |
DNS Filter FQDN Detected | |
Add to white list | Select an entry and click this to add it to the DNS filtering white list. |
Remove from white list | Select an entry and click this to remove it from the DNS filtering white list. |
Collect Statistics | Select this checkbox to have the Zyxel Device collect IPS statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Total Session Scanned | This field displays the number of sessions that the Zyxel Device has checked for intrusion characteristics. |
Total Packet Dropped | The Zyxel Device can detect and drop malicious packets from network traffic. This field displays the number of packets that the Zyxel Device has dropped. |
Total Packet Reset | The Zyxel Device can detect and drop malicious packets from network traffic. This field displays the number of packets that the Zyxel Device has reset. |
Top Entries By | Use this field to have the following (read-only) table display the top IPS log entries by Signature Name, Source IP or Destination IP. This table displays the most common, recent IPS logs. See the log screen for less common IPS logs or use a syslog server to record all IPS logs. Select Signature Name to list the most common signatures that the Zyxel Device has detected. Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most intrusion attempts. Select Destination IP to list the most common destination IP addresses for intrusion attempts that the Zyxel Device has detected. |
Add to allow list | Select a signature and click this to add the selected signature to the IPS allow list. |
Remove from allow list | Select a signature and click this to remove the selected signature from the IPS allow list. |
Statistics | |
Signature Name | This column displays when you display the entries by Signature Name. The signature name identifies the type of intrusion pattern. Click the hyperlink for more detailed information on the intrusion. |
Signature ID | This column displays when you display the entries by Signature Name. The signature ID is a unique value given to each intrusion detected. |
Type | This column displays when you display the entries by Signature Name. It shows the categories of intrusions. |
Severity | This column displays when you display the entries by Signature Name. It shows the level of threat that the intrusions may pose. |
Source IP | This column displays when you display the entries by Source. It shows the source IP address of the intrusion attempts. |
Destination IP | This column displays when you display the entries by Destination. It shows the destination IP address at which intrusion attempts were targeted. |
Allow List | Click this to add this signature to the IPS allow list.Click this to remove this signature from the IPS allow list. |
Rate Based Signatures Statistics | This table displays the rate based signatures statistics. IPS signatures identify traffic packets with suspicious malicious patterns. The Zyxel Devicecan then respond instantaneously according to the action you define. If you do not want the Zyxel Device to respond instantaneously for each suspicious packet detected, use rate based signatures. See What You Need To Know for more information on rate based signatures. |
Time | This column displays the date and time IPS blocked this IP address. |
Blocked IP | This field displays the IP address that is blocked by IPS. |
Interactive/Victim Host | This field displays the IP address of the infected host. |
Time Remaining | This field displays the amount of time left until the blocked IP address is released by IPS. |
Collect Statistics | Select this checkbox to have the Zyxel Device collect sandboxing statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Submission Summary | |
Total | This field displays the total number of files that the Zyxel Device sent to the Defend Center for analysis. |
Scanning | This field displays the total number of files that the Zyxel Device is still scanning. |
Scanned | This field displays the total number of files that have been scanned. |
Destroyed Files | This shows the number of files that have been destroyed. |
Scan Result | |
Malicious Files | This shows the number of malicious files that have been detected. Malicious files are files given a high score for characteristics by the Defend Center. |
Suspicious Files | This shows the number of suspicious files that have been detected. Suspicious files are files given a medium score for characteristics by the Defend Center. |
Safe File | This shows the number of clean files that have been detected. Safe files are files given a low score for characteristics by the Defend Center. |
Other | This shows the number of internal and external networks errors. |
Statistics | |
# | This is the entry’s index number in the list. |
File Name | This column displays the file name of the detected virus file. |
Type | This field displays the file type of the detected virus file. |
Occurrence | This field displays how many times the Zyxel Device has detected the event described in the entry. |
Update Time | This field displays the last time the Zyxel Device updates the sandboxing statistics table. |
Collect Statistics | Select this checkbox to have the Zyxel Device collect email security statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Summary | |
Total Mails Scanned | This field displays the number of emails that the Zyxel Device’s email security feature has checked. |
Safe Mails | This is the number of emails that the Zyxel Device has determined to not be spam. |
Safe Mails Detected by Allow list | This is the number of emails that matched an entry in the Zyxel Device’s email security allow list. |
Spam Mails | This is the number of emails that the Zyxel Device has determined to be spam. |
Spam Mails Detected by Block List | This is the number of emails that matched an entry in the Zyxel Device’s email security block list. |
Spam Mails Detected by Malicious Mail | This is the number of emails that the Zyxel Device has determined to have malicious contents. |
Spam Mails Detected by DNSBL | The Zyxel Device can check the sender and relay IP addresses in an email’s header against DNS (Domain Name Service)-based spam Black Lists (DNSBLs). This is the number of emails that had a sender or relay IP address in the header which matched one of the DNSBLs that the Zyxel Device uses. |
Query Timeout | This is how many queries that were sent to the Zyxel Device’s configured list of DNSBL domains or Mail Scan services and did not receive a response in time. |
When mail session threshold is reached | |
Mail Sessions Forwarded | This is how many email sessions the Zyxel Device allowed because they exceeded the maximum number of email sessions that the email security feature can check at a time. You can see the Zyxel Device’s threshold of concurrent email sessions on the Email Security > Status screen. Use the Email Security > Summary screen to set whether the Zyxel Device forwards or drops sessions that exceed this threshold. |
Mail Sessions Dropped | This is how many email sessions the Zyxel Device dropped because they exceeded the maximum number of email sessions that the email security feature can check at a time. You can see the Zyxel Device’s threshold of concurrent email sessions on the Email Security > Status screen. Use the Email Security > Summary screen to set whether the Zyxel Device forwards or drops sessions that exceed this threshold. |
Statistics | |
Top Sender By | Use this field to list the top email or IP addresses from which the Zyxel Device has detected the most spam. Select Sender IP to list the source IP addresses from which the Zyxel Device has detected the most spam. Select Sender Email Address to list the top email addresses from which the Zyxel Device has detected the most spam. |
Sender IP | This column displays when you display the entries by Sender IP. It shows the source IP address of spam emails that the Zyxel Device has detected. |
Sender Email Address | This column displays when you display the entries by Sender Email Address. This column displays the email addresses from which the Zyxel Device has detected the most spam. |
Occurrence | This field displays how many spam emails the Zyxel Device detected from the sender. |
Resource Status | |
Concurrent Mail Session Scanning | The darker shaded part of the bar shows how much of the Zyxel Device’s total spam checking capability is currently being used. The lighter shaded part of the bar and the pop-up show the historical high. The first number to the right of the bar is how many email sessions the Zyxel Device is presently checking for spam. The second number is the maximum number of email sessions that the Zyxel Device can check at once. An email session is when an email client and email server (or two email servers) connect through the Zyxel Device. |
Refresh | Click this button to update the information displayed on this screen. |
Flush | Click this button to clear the DNSBL statistics. This also clears the concurrent mail session scanning bar’s historical high. |
Mail Scan Statistics | These are the statistics for the service the Zyxel Device uses. These statistics are for when the Zyxel Device actually queries the service servers. |
Service | This displays the name of the service. |
Total Queries | This is the total number of queries the Zyxel Device has sent to this service. |
Avg. Response Time (sec) | This is the average for how long it takes to receive a reply from this service. |
No Response | This is how many queries the Zyxel Device sent to this service without receiving a reply. |
DNSBL Statistics | These are the statistics for the DNSBL the Zyxel Device uses. These statistics are for when the Zyxel Device actually queries the DNSBL servers. Matches for DNSBL responses stored in the cache do not affect these statistics. |
DNSBL Domain | These are the DNSBLs the Zyxel Device uses to check sender and relay IP addresses in emails. |
Total Queries | This is the total number of DNS queries the Zyxel Device has sent to this DNSBL. |
Avg. Response Time (sec) | This is the average for how long it takes to receive a reply from this DNSBL. |
No Response | This is how many DNS queries the Zyxel Device sent to this DNSBL without receiving a reply. |
Containment List | This table displays up to 512 devices that CDR is blocking or quarantining. Containment list items remain even if the Zyxel Device or managed AP reboots. |
Group by | Choose to sort security events for contained devices by IP Address or MAC Address. For example, if three security events occur for a client identified by IP address, then under Time, the IP address of the client is shown with the times the security events occurred beneath this IP address. • Wired clients are blocked based on IP address by default. You can change that to blocking based on MAC address using the cdr blocked-by mac command in configuration mode in the Command Line Interface (CLI). Note that if you have a switch between the client and the Zyxel Device, then blocking by MAC address could block all traffic from the switch if the client MAC address is not forwarded through the switch. • WiFi clients are blocked or quarantined based on MAC address by default. |
Add to exempt list | Select a client and then click this to release this device from CDR containment and also bypass this device from future CDR checking. This device is then removed from this table and added to the History screen. |
Release | Select a client and then click this to release this device from CDR containment. This device is then removed from this table and added to the History screen. |
Time | This field displays the date and time CDR contained this client |
IP Address | This field displays the IPv4 address of the client contained by CDR. |
MAC Address | This field displays the MAC address of the client contained by CDR. |
User | The field displays the user name of a client contained by CDR who has been authenticated for Internet access. The field is blank if user authentication is not required. |
Security Events | This field displays details on the category of signature that triggered CDR: Web Filtering, Anti-Malware or IPS (IDP). |
Containment | This field displays if the client is blocked, quarantined or just triggers an alert. |
Time Remaining (Seconds) | This field displays the amount of time left until this client is released by CDR |
Connect to | This field displays the description of the AP or the interface of the Zyxel Device that the contained client is connected to. |
Refresh | Click this button to update the information on the screen. |
History | This table displays up to 1024 devices that CDR has blocked or quarantined |
Collect Statistics | Select this checkbox to have the Zyxel Device collect SSL Inspection statistics. The collection starting time displays after you click Apply. All of the statistics in this screen are for the time period starting at the time displayed here. The format is year, month, day and hour, minute, second. All of the statistics are erased if you restart the Zyxel Device or click Flush Data. Collecting starts over and a new collection start time displays. |
Status | |
Concurrent Sessions | This shows the actual number of simultaneous SSL Inspection sessions in progress. This number displays in red when you have reached the maximum number of simultaneous SSL Inspection sessions allowed for your Zyxel Device model. |
Summary | |
Total SSL Sessions | This is the total of SSL sessions inspected and number of sessions blocked and number of sessions passed since data was last flushed or the Zyxel Device last rebooted after Collect Statistics was enabled. |
Sessions Inspected | This shows the total number of SSL sessions inspected since data was last flushed or the Zyxel Device last rebooted after Collect Statistics was enabled |
Decrypted (Kbytes) | This shows the number of kilobytes (KB) of data that was decrypted for Security Service inspection. |
Encrypted (Kbytes) | This shows the number of kilobytes (KB) of data that was re-encrypted after Security Service inspection and then forwarded. |
Sessions Blocked | This shows the number of SSL sessions blocked. |
Sessions Passed | This shows the number of SSL sessions passed. |
Certificate Cache List | |
Add to Exclude list | Select and item in the list and click this icon to add the common name (CN) to the Exclude List. |
# | This field is a sequential value, and it is not associated with a specific entry. |
In Exclude List | If any one of common name, DNS name, email address or IP address of the certificate is in the Exclude List, then traffic to the server identified by the certificate is excluded from inspection. The icons here are defined as follows: • Gray: The identity of the certificate is not in the Exclude List • Green: The common name of the certificate is in the Exclude List • Yellow: The common name of certificate is not in the Exclude List but one of the DNS name, email address or IP address is. |
Time | This is the latest date (yyyy-mm-dd) and time (hh-mm-ss) that the record in the certificate cache list was met. |
Common Name | This displays the common name in the certificate of the SSL traffic destination server. |
Server Name Indication | Server Name Indication (SNI) is the domain name entered in the browser, FTP client, etc. to begin the SSL session with the server. It allows multiple SSL sessions to the same IP address and port number with different certificates from different SNI. This field displays the SNI for this SSL session. |
SSL Version | This field shows the SSL version. SSLv3/TLS1.0 is currently supported. |
Destination | This displays the IP address and port number of the SSL traffic destination server. |
Valid Time | This displays the cache item expiry time in seconds. The cache item is deleted when the remaining time expires. |
Show (Hide) Filter | Click this button to show or hide criteria that allow you to filter logs that will be displayed. If the filter settings are hidden, the Category, Email Log Now, Refresh, and Clear fields are available. If the filter settings are shown, the Category, Priority, Source Address, Destination Address, Source Interface, Destination Interface, Service, Keyword, Protocol and Search fields are available. |
Category | Select the type of log message(s) you want to view. You can also view All Logs at one time, or you can view the Debug Log. |
Priority | This displays when you show the filter. Select the priority of log messages to display. The log displays the log messages with this priority or higher. Choices are: any, emerg, alert, crit, error, warn, notice, and info, from highest priority to lowest priority. This field is grayed out if the Category is Debug Log. |
Source Address | This displays when you show the filter. Enter the source IP address of the incoming packet that generated the log message. Do not include the port in this filter. |
Destination Address | This displays when you show the filter. Enter the IP address of the destination of the incoming packet when the log message was generated. Do not include the port in this filter. |
Source Interface | This displays when you show the filter. Enter the source interface of the incoming packet that generated the log message. |
Destination Interface | This displays when you show the filter. Enter the interface of the destination of the incoming packet when the log message was generated. |
Service | This displays when you show the filter. Select the service whose log messages you would like to see. The Web Configurator uses the protocol and destination port number(s) of the service to select which log messages you see. |
Keyword | This displays when you show the filter. Enter a keyword to look for in the Message, Source, Destination and Note fields. If a match is found in any field, the log message is displayed. You can use up to 63 alphanumeric characters and the underscore, as well as punctuation marks ()’ ,:;?! +-*/= #$% @ ; the period, double quotes, and brackets are not allowed. |
Protocol | This displays when you show the filter. Select a service protocol whose log messages you would like to see. |
Search | This displays when you show the filter. Click this button to update the log using the current filter settings. |
Email Log Now | Click this button to send log messages to the Active email addresses specified in the Send Log To field on the Log Settings page. Please note that only the following log messages will be sent: • Log messages that have not been sent before, and • log messages that match the categories you selected in Configuration > Log & Report > Log Settings > Edit > Active Log and Alert. |
Clear | Click this button to clear the whole log, regardless of what is currently displayed on the screen. |
# | This field is a sequential value, and it is not associated with a specific log message. |
Time | This field displays the time the log message was recorded. |
Priority | This field displays the priority of the log message. It has the same range of values as the Priority field above. |
Category | This field displays the log that generated the log message. It is the same value used in the Category field above. |
Message | This field displays the reason the log message was generated. The text “[count=x]”, where x is a number, appears at the end of the Message field if log consolidation is turned on and multiple entries were aggregated to generate into this one. |
Source | This field displays the source IP address and the port number in the event that generated the log message. |
Destination | This field displays the destination IP address and the port number of the event that generated the log message. |
Note | This field displays any additional information about the log message. |
Show Filter | Click this button to show or hide the filter settings. If the filter settings are hidden, the Display, Email Log Now, Refresh, and Clear fields are available. If the filter settings are shown, the Display, Priority, Source Address, Destination Address, Source Interface, Destination Interface, Service, Keyword, Protocol, and Search fields are available. |
Select an AP | Click the pull down menu to choose an AP. |
Query | Click Query to create a Query log. |
Log Query Status | The field displays the |
AP Information | This field displays the AP information. N/A is displayed when |
Log File Status | This field displays how many logs are available. It will display Empty if there’s none. |
Last Log Query Time | This field displays the most recent time a log query was solicited. |
Display | Select the category of log message(s) you want to view. You can also view All Logs at one time, or you can view the Debug Log. |
Priority | This displays when you show the filter. Select the priority of log messages to display. The log displays the log messages with this priority or higher. Choices are: any, emerg, alert, crit, error, warn, notice, and info, from highest priority to lowest priority. This field is read-only if the Category is Debug Log. |
Source Address | Enter the IP address of the source AP. |
Service | Select a policy service available from Zyxel Device from the pull down menu. |
Keyword | Enter a keyword of the policy service available from Zyxel Device to search for a log. |
Protocol | Select the protocol of the AP from the pull down menu. |
Search | Click this to start the search. |
Category | This field displays the log that generated the log message. It is the same value used in the Display and (other) Category fields. |
Message | This field displays the message of the log. |
Source | This displays the source IP address of the selected log message. |
Destination | This displays the source IP address of the selected log message. |
Begin/End Date | Select the first and last dates to specify a time period. The Zyxel Device displays log messages only for the accounts created during the specified time period after you click Search. |
Begin/End Time | Select the begin time of the first date and the end time of the last date to specify a time period. The Zyxel Device displays log messages only for the accounts created during the specified time period after you click Search. |
Search | Click this button to update the information on the screen using the filter criteria in the date and time fields. |
Refresh | Click this button to update the information in the screen. |
Clear | Click this button to delete the log messages for invalid accounts. |
# | This is the index number of the dynamic guest account in the list. |
Status | This field displays whether an account expires or not. |
Username | This field displays the user name of the account. |
Create Time | This field displays when the account was created. |
Remaining Time | This field displays the amount of Internet access time remaining for each account. |
Time Period | This field displays the total account of time the account can use to access the Internet through the Zyxel Device. |
Expiration Time | This field displays the date and time the account becomes invalid. |
Quota (T/U/D) | This field displays how much data in both directions (Total) or upstream data (Upload) and downstream data (Download) can be transmitted through the WAN interface before the account expires. |
Remaining Quota (T/U/D) | This field displays the remaining amount of data that can be transmitted or received by each account. You can see the amount of either data in both directions (Total) or upstream data (Upload) and downstream data (Download). |
Bandwidth (U/D) | This field displays the maximum upstream (Upload) and downstream (Download) bandwidth allowed for the user account in kilobits per second. |
Real Name | This field displays the user’s name of the account. |
Email | This field displays the email of the account. |
Charge | This field displays the total cost of the account. |
Payment Info | This field displays the method of payment for each account. |
Phone Num | This field displays the telephone number for the user account. |
