Monitor
Overview
Use the Monitor screens to check status and statistics information.
Use the Monitor screens for the following.
• Use the Traffic Statistics > Application Usage (The Application Usage Screen) screen to view application statistics.
• Use the Traffic Statistics > Port (The Port Statistics Screen) screen to view the packets statistics for each port selected for monitoring.
• Use the Traffic Statistics > Interface (The Interface Statistics Screen) screen to view the packets statistics for each interface selected for monitoring.
• Use the Traffic Statistics > Session Monitor screen (see The Session Monitor Screen) to view sessions by user or service.
• Use the Security Statistics > Content Filter screen (The Content Filter Screen) to start or stop data collection and view content filter statistics.
• Use the Security Statistics > Reputation Filter screens (The Reputation Filter Screens) to view statistics of IP reputation, DNS threat filtering and URL threat filtering.
• Use the Security Statistics > IPS screen (The IPS Screen) to start or stop data collection and view IPS statistics.
• Use the Security Statistics > Anti-Malware (The Anti-Malware Screen) screen to view anti-malware statistics.
• Use the Security Statistics > Sandbox screen (The Sandbox Screen) to view sandbox statistics.
• Use the Security Statistics > SSL Inspection screen (The SSL Inspection Screens) to see a report on SSL Inspection and a certificate cache list.
• Use the Network Status > Interface screen (see The Session Monitor Screen) to view the interface packets statistics.
• Use the Network Status > Device Insight screen (see The Device Insight Screen) to view the status of the clients connected to the Zyxel Device.
• Use the Network Status > Login Users screen (The Login Users Screen) to look at a list of the users currently logged into the Zyxel Device.
• Use the Network Status > Lockout IPs screen (The Lockout IPs Screen) to look at a list of the IP addresses currently locked out of the Zyxel Device.
• Use the Network Status > DHCP Table screen (see The DHCP Table Screen) to view a list of interfaces and their DHCP-assigned IP addresses.
• Use the VPN Status > IPSec VPN > Site to Site VPN screen (The Site to Site VPN Screen) to display and manage active IPSec Policies.
• Use the VPN Status > IPSec VPN > Remote Access VPN screen (The Remote Access VPN Screen) to display and manage remote access VPN clients.
• Use the VPN Status > SSL VPN > Remote Access VPN screen (The SSL VPN Screen) to list the users currently logged into the SSL VPN client portal. You can also log out individual users and delete related session information.
• Use the VPN Status > Tailscale screen (The Tailscale Screen) to display Tailscale VPN connection information.
• Use the VPN Status > Remote AP VPN screen (The Remote AP VPN Screen) to display Remote AP VPN connection information.
• Use the Wireless Status > Access Points screen (The Access Points Screen) to view traffic usage of managed APs.
• Use the Wireless Status > WLAN Clients screen (The WLAN Clients Screen) to view traffic usage of client devices.
What You Need to Know
Collaborative Detection & Response
Collaborative Detection & Response (CDR) allows you to detect wired and WiFi clients that are sending malicious traffic in your network and then block or quarantine traffic coming from them. In this way, malicious traffic is not spread throughout the network. Secure policies can block malicious traffic for specific traffic flows, but CDR can block malicious traffic from the sender. Malicious traffic is identified using a combination of Web Filtering, Anti-Malware and IPS (IDP) signatures.
*This feature can only be configured through Nebula. Refer to the NCC User’s Guide for details.
This screen provides a convenient way to monitor the use of various applications by hosts in the network.
If a license has expired, you will see a reminder in this screen. You need to renew the license in order to keep using the feature. Click Buy Now to go to Marketplace to purchase a new license. Click See Details to go to the Zyxel web page to find more information on licenses for your Zyxel Device.
This screen displays usage by application type or the IP addresses of hosts in your network.
label
description
Last 24 Hours Summary
If you want to view more data than the past 24 hours in SecuReporter, click View More. You should already have a SecuReporter account.
Pie Chart
Click an item in the pie chart for more detailed information.
Refresh
Click this button to update the report display.
Flush Data
Click this button to discard all of the screen’s statistics for inactive sessions. Flushing data only removes traffic logs from ended sessions. Active sessions remain unaffected. Click Refresh to update the report display.
Top Usage by
Select to display usage by application or host IP address.
Application
If you selected by application, then this is the name of the application identified.
Category
This is the category the application belongs to.
Usage
This is how much traffic the application has used.
%Usage
This is the percentage of traffic the application has used.
Client IP address
If you selected by host IP address, then this is the IP address of the host identified.
Client Description
This is the name of the host identified.
MAC Address
This is the MAC address of the host device.
Usage
This is how much traffic the host has used.
%Usage
This is the percentage of traffic the host has used.
Use this screen to look at packets statistics for each Gigabit Ethernet port. Ports are physical ports to which you connect cables.
Select one or multiple ports to monitor. The table below lists the maximum number of displayable ports for each model at the time of writing.
Maximum Displayable Ports
Model
Number of Interfaces
USG FLEX 50H
USG FLEX 50HP
5
USG FLEX 100H
USG FLEX 100HP
USG FLEX 200H
USG FLEX 200HP
USG FLEX 500H
USG FLEX 700H
8
System Statistics > Port
label
description
Monitor Port
Select one or multiple ports from the drop-down list to view port packet statistics. The maximum number of displayable ports varies by model. See Maximum Displayable Ports for the maximum number of ports you can select. A warning message will appear if you attempt to select more than the maximum.
Poll Interval
Enter how often you want this window to be updated automatically, and click Refresh.
TX
This line represents traffic transmitted from the Zyxel Device on the selected physical port since it was last connected. Click TX to show or hide the TX line in the chart.
RX
This line represents the traffic received by the Zyxel Device on the selected physical port since it was last connected. Click RX to show or hide the RX line in the chart.
Use this screen to look at packets statistics for each interface. Interfaces are used within the system operationally. You use them in configuring various features.
Select one or multiple interfaces to monitor. The table below lists the maximum number of displayable interfaces for each model at the time of writing.
Maximum Displayable Interfaces
Model
USG FLEX 50H
USG FLEX 50HP
USG FLEX 100H
USG FLEX 100HP
USG FLEX 200H
USG FLEX 200HP
USG FLEX 500H
USG FLEX 700H
8
label
description
Monitor Interface
Select one or multiple interfaces from the drop-down list to view the interface packets statistics. See Maximum Displayable Interfaces for the maximum number of interfaces you can select. A warning message will appear if you attempt to select more than the maximum.
Poll Interval
TX
This line displays the transmission speed, in bytes per second, on the interface in the one-second interval before the screen updated.
RX
This line displays the reception speed, in bytes per second, on the interface in the one-second interval before the screen updated.
The Session Monitor screen displays all established sessions that pass through the Zyxel Device for debugging or statistical analysis. It is not possible to manage sessions in this screen. The following information is displayed.
• User who started the session
• Protocol or service port used
• Source address and country
• Destination address and country
• Number of bytes received (so far)
• Number of bytes transmitted (so far)
• Duration (so far)
• BWM rule applied
You can look at all established sessions that passed through the Zyxel Device by user, service, source IP address, or destination IP address. You can also filter the information by user, protocol / service or service group, source address, and/or destination address and view it by user.
Label
Description
View
Select how you want the established sessions that passed through the Zyxel Device to be displayed. Choices are:
• sessions by user - display all active sessions grouped by user
• sessions by services - display all active sessions grouped by service or protocol
• sessions by source IP - display all active sessions grouped by source IP address
• sessions by source region - display all active sessions grouped by source IP address
• sessions by destination IP - display all active sessions grouped by destination IP address
• sessions by destination region - display all active sessions grouped by destination IP address
• all sessions - filter the active sessions by the User, Service, Source IP, and Destination IP, and display each session individually (sorted by user).
Clear Session
Select a session, then click this button to remove the selected session.
Clear All Sessions
Click this button to remove all sessions.
Refresh
Click this button to update the information on the screen. The screen also refreshes automatically when you open and close the screen.
Search
Type an item in the search box, then click this to display all sessions in the table below according to the item you typed.
Clear All
Click this to remove all items found in the search.
Filter
Click the Filter icon , click + to display Add Filter, pick a filter, then click Search to display specific sessions according to the filter selected. You may select multiple filters, but just one of each type, configured one at a time.
The User, Service, Source Address, Destination Address, Source Country and Destination Country fields display if you view all sessions.
This field is the rank of each record. The names are sorted by the name of user in active session. You can use the pull down menu on the right to choose sorting method.
User
This field displays the user in each active session.
If you are looking at the sessions by users (or all sessions) report, click + or - to display or hide details about a user’s sessions.
Services
This field displays the protocol used in each active session.
If you are looking at the sessions by services report, click + or - to display or hide details about a protocol’s sessions.
Source
This field displays the source IP address and port in each active session.
If you are looking at the sessions by source IP report, click + or - to display or hide details about a source IP address’s sessions.
Destination
This field displays the destination IP address and port in each active session.
If you are looking at the sessions by destination IP report, click + or - to display or hide details about a destination IP address’s sessions.
Rx
This field displays the amount of information received by the source in the active session.
Tx
This field displays the amount of information transmitted by the source in the active session.
Session Count
Select sessions by ... in the View field to group the sessions. This field displays the number of sessions. Click this number to view the details of each session.
Duration
This field displays the length of the active session in hours, minutes, seconds format.
BWM Rule
Hover over the BWM Rule icon for a session to see which BWM rule it is using.
This field is displayed only when viewing the table of all sessions. To see it, select all sessions in the View field, or click the Session Count after selecting sessions by... in the View field.
The Zyxel Device content filtering includes HTTP(S) traffic scan and DNS domain scan. The HTTP(S) traffic scan allows the Zyxel Device to block access to specific websites, by inspecting the URL or Server Name Indication (SNI) that the user’s web browser sends to the web server. The DNS domain scan allows the Zyxel Device to block access to specific websites by inspecting DNS queries made by users on your network. If the website in the DNS query contains prohibited material, then the Zyxel Device replies to the DNS query with a IP address that points to the block page.
These screens display some basic statistics on HTTP(S) traffic scan and DNS domain scan.
Label
Description
Pie Chart
Top entry by
Use this field to have the following (read-only) table display the top content filter log entries by Blocked Category, Blocked Source IP, Blocked URL, Allowed Category, Allowed Source IP, or Allowed URL. This table displays the most common, recent content filter logs. See the log screen for less common content filter logs or use a syslog server to record all content filter logs.
Select Blocked Category to list the web site categories the Zyxel Device has blocked.
Select Blocked Source IP to list the source IP addresses of the web sites the Zyxel Device has blocked.
Select Blocked URL to list the URLs of the web sites the Zyxel Device has blocked.
Select Allowed Category to list the web site categories the Zyxel Device has allowed.
Select Allowed Source IP to list the source IP addresses of the web sites the Zyxel Device has allowed.
Select Allowed URL to list the URLs of the web sites the Zyxel Device has allowed.
Refresh
Flush Data
Click this button to discard all of the screen’s statistics. Click Refresh to update the report display.
Time
This column displays the date and time when the users access the URL or FQDN.
Action
This column displays whether the Zyxel Device blocks or passes the accessed URL or FQDN.
URL/Domain
This column displays the URL or domain name of the web site accessed.
Profile
This column displays the content filter profile the website belongs to.
Category
This column displays the category the accessed web site belongs to.
Source IP
This column displays the source IP address of the web site the Zyxel Device has checked.
Destination IP
This column displays the destination IP address at which the traffic of the web site the Zyxel Device has checked is sent.
These screens display reputation filter statistics.
The Zyxel Device reputation filter includes IP reputation, DNS threat filter and URL threat filter.
IP Reputation
This screen displays IP reputation statistics. IP reputation checks the reputation of an IP address from a database.
Security Statistics > Reputation Filter > IP Reputation
Label
Description
Pie Chart
Top Entries By
Use this field to have the following (read-only) table display the top IP reputation log entries by Category, Infected/Victim Host or Malicious IP. This table displays the most common, recent IP reputation logs. See the log screen for less common IP reputation logs or use a syslog server to record all IP reputation logs.
Select Category to list the most common categories of packets that the Zyxel Device has detected.
Select Infected/Victim Host to list the most common IP addresses of the infected hosts.
Select Malicious IP to list the most common IPv4 addresses with bad reputation that have sent packets to the Zyxel Device.
Refresh
Flush Data
IP Reputation Events
Time
This field displays the date and time the entry was created.
+ Allow List
Select an entry and click this to add it to the IP reputation allow list.
Malicious IP
This field displays the IPv4 address with bad reputation.
This field displays the IP address of the infected host.
Threat Category
This field displays the category of the entry.
Threat Level
This field displays the threat level of the entry.
Occurrence
This field displays how many times the Zyxel Device has detected the event described in the entry.
DNS Threat Filter
This screen displays DNS threat filter statistics. DNS threat filtering inspects DNS queries made by clients on your network and compares the queries against a database of blocked or allowed Fully Qualified Domain Names (FQDNs).
Security Statistics > Reputation Filter > DNS Threat Filter
Label
Description
Pie Chart
Top Entries By
Use this field to have the following (read-only) table display the top DNS threat filter log entries by Category, Source IP or DNS Name. This table displays the most common, recent DNS threat filter logs. See the log screen for less common DNS threat filter logs or use a syslog server to record all DNS threat filter logs.
Select Source IP to list the most common source IP addresses of traffic.
Select DNS Name to list the most common FQDNs of the infected websites.
Refresh
Flush Data
DNS Threat Filter Events
Time
+ Allow List
Select an entry and click this to add it to the DNS filtering allow list.
DNS Name
This field displays the FQDN of an infected website.
Category
Source IP
This field displays the source IP address of traffic that you want to trace.
URL Threat Filter
This screen displays URL threat filter statistics. URL threat filtering compares access to specific URLs against a database of blocked or allowed sites.
Security Statistics > Reputation Filter > URL Threat Filter
Label
Description
Pie Chart
Top Entries By
Use this field to have the following (read-only) table display the top URL threat filter log entries by Category, URL or Source IP. This table displays the most common, recent URL threat filter logs. See the log screen for less common URL threat filter logs or use a syslog server to record all URL threat filter logs.
Select URL to list the most common URLs of the infected websites.
Refresh
Flush Data
URL Threat Filter Events
Time
+ Allow List
Select an entry and click this to add it to the URL Threat filtering allow list.
URL
This field displays the URL of an infected website.
Category
Source IP
Destination IP
This field displays the destination IP address of traffic.
The IPS Screen
This screen displays IPS (Intrusion Prevention System) statistics. An IPS system can detect malicious or suspicious packets and respond instantaneously by rejecting or dropping the packets. The Zyxel Device IPS protects your network against network-based intrusions.
Label
Description
Pie Chart
Top Entries By
Use this field to have the following (read-only) table display the top IPS log entries by Signature Name, Source IP or Destination IP. This table displays the most common, recent IPS logs. See the log screen for less common IPS logs or use a syslog server to record all IPS logs.
Select Signature Name to list the most common signatures that the Zyxel Device has detected.
Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most intrusion attempts.
Select Destination IP to list the most common destination IP addresses for intrusion attempts that the Zyxel Device has detected.
Refresh
Flush Data
Time
This column displays the date and time IPS blocked this IP address.
+ Allow List
Select an entry and click this to add the signature to the IPS allow list.
Signature ID
This column displays when you display the unique value given to each intrusion detected.
Signature Name
This column displays the name to identify the type of intrusion pattern.
Type
This column displays the categories of intrusions.
Severity
This column displays the level of threat that the intrusions may pose.
Source IP
This column displays the source IP address of the intrusion attempts.
Destination IP
This column displays the destination IP address at which intrusion attempts were targeted.
This screen displays anti-malware statistics.
Label
Description
Pie Chart
Top Entries By
Use this field to have the following (read-only) table display the top anti-malware log entries by Virus Name, Source IP, and Destination IP. This table displays the most common, recent anti-malware logs. See the log screen for less common anti-malware logs or use a syslog server to record all anti-malware logs.
Select Virus Name to list the most common viruses that the Zyxel Device has detected.
Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most virus-infected files.
Select Destination IP to list the most common destination IP addresses for virus-infected files that Zyxel Device has detected.
Refresh
Flush Data
Anti-Malware Statistics Events
Time
Allow List
Select an entry and click this to add it to the anti-malware allow list.
Virus name
This column displays when you display the entries by Virus Name. This displays the name of a detected virus.
Hash
This column displays a hash value, SHA-256 (Secure Hash Algorithm) or MD5 (Message Digest 5) of the detected virus file.
SHA-256 and MD5 are hash algorithms used to authenticate packet data.
Source IP
This column displays when you display the entries by Source IP. It shows the source IP address of virus-infected files that the Zyxel Device has detected.
Destination IP
This column displays when you display the entries by Destination IP. It shows the destination IP address of virus-infected files that the Zyxel Device has detected.
The Sandbox Screen
This screen displays sandbox statistics.
Label
Description
Pie Chart
Top Entries By
Use this field to have the following (read-only) table display the top sandbox log entries by Destination IP, Source IP and Type. This table displays the most common, recent sandbox logs. See the log screen for less common sandbox logs or use a syslog server to record all sandbox logs.
Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most files with unknown or untrusted programs and codes.
Select Destination IP to list the most common destination IP addresses for files with unknown or untrusted programs and codes that Zyxel Device has detected.
Select Type to display if the file type of the detected file with unknown or untrusted programs and codes.
Refresh
Flush Data
When the statistics stored reach the limit, new statistics automatically overwrite existing statistics, starting with the oldest statistics first.
Sandbox Events
Time
This field displays the time the file is scanned by the Zyxel Device.
Type
This field displays the file type of the detected file with unknown or untrusted programs and codes.
File Name
This column displays the file name of the detected virus file.
Hash
This column displays a hash value, MD5 (Message Digest 5, of the detected file with unknown or untrusted programs and codes.
MD5 is a hash algorithm used to authenticate packet data.
Source IP
This column displays the source IP address of the file the Zyxel Device has checked.
Destination IP
This column displays the destination IP address at which the traffic of the file the Zyxel Device has checked is sent.
The Zyxel Device uses SSL Inspection to decrypt SSL traffic, then sends it to Security Service engines for inspection, and then finally encrypts traffic that passes inspection and forwards it.
The Summary Screen
This screen shows the number of SSL sessions inspected, blocked and passed.
Security Statistics > SSL Inspection > Summary
Label
Description
General Settings
Refresh
Flush Data
Status
Concurrent Sessions
This shows the actual number of simultaneous SSL Inspection sessions in progress. This number displays in red when you have reached the maximum number of simultaneous SSL Inspection sessions allowed for your Zyxel Device model. See the Product Features appendix in the User’s Guide to see the maximum allowed for each model.
Summary
Total
This is the total of SSL sessions inspected and number of sessions blocked and number of sessions passed since data was last flushed or the Zyxel Device last rebooted after Collect Statistics was enabled.
Inspected
This shows the total number of SSL sessions inspected since data was last flushed or the Zyxel Device last rebooted after Collect Statistics was enabled
Decrypted (Kbytes)
This shows the number of kilobytes (KB) of data that was decrypted for Security Service inspection.
Encrypted (Kbytes)
This shows the number of kilobytes (KB) of data that was re-encrypted after Security Service inspection and then forwarded.
Blocked
This shows the number of SSL sessions blocked.
Passed
This shows the number of SSL sessions passed.
The Certificate Cache List Screen
A certificate identifies the source of SSL traffic. Use this screen to decide which sources can be excluded from SSL inspection. Traffic in an Exclude List is not intercepted by SSL inspection.
Security Statistics > SSL Inspection > Certificate Cache List
Label
Description
Time
This is the latest date (yyyy-mm-dd) and time (hh-mm-ss) that the record in the certificate cache list was met.
Add to Exclude list
Select and item in the list and click this icon to add the common name (CN) to the Exclude List.
Common Name
This displays the common name in the certificate of the SSL traffic destination server.
Server Name Indication (SNI) is the domain name entered in the browser, FTP client, etc. to begin the SSL session with the server. It allows multiple SSL sessions to the same IP address and port number with different certificates from different SNI. This field displays the SNI for this SSL session.
SSL Version
This field shows the SSL version. TLS1.0/1.1/1.2 are currently supported.
Destination
This displays the IP address and port number of the SSL traffic destination server.
Valid Time
This displays the cache item expiry time in seconds. The cache item is deleted when the remaining time expires.
The Interface Screen
This screen lists all of the Zyxel Device’s interfaces and their information.
Label
Description
Refresh
Click this to update the information in this screen.
Name
This field displays the name of each interface.
Members
This field displays the physical port number that is binded to the interface. An interface is binded to a port when the interface is bounded to the physical port.
When you create a bridge interface, the Zyxel Device removes the members' entries from the routing table and adds the bridge interface's entries to the routing table. This field displays the bridge interface's members.
Type
This field displays the type of connection the interface is using.
Status
This field displays the current status of each interface. The possible values depend on what type of interface it is.
For Ethernet interfaces:
• Inactive - The Ethernet interface is disabled.
• Down - The Ethernet interface does not have any physical ports associated with it or the Ethernet interface is enabled but not connected.
• Speed / Duplex - The Ethernet interface is enabled and connected. This field displays the port speed and duplex setting (Full or Half).
For the auxiliary interface:
• Inactive - The auxiliary interface is disabled.
• Connected - The auxiliary interface is enabled and connected.
• Disconnected - The auxiliary interface is not connected.
For virtual interfaces, this field always displays Up. If the virtual interface is disabled, it does not appear in the list.
For VLAN and bridge interfaces, this field always displays Up. If the VLAN or bridge interface is disabled, it does not appear in the list.
For PPP interfaces:
• Connected - The PPP interface is connected.
• Disconnected - The PPP interface is not connected.
If the PPP interface is disabled, it does not appear in the list.
Zone
This field displays the zone to which the interface is assigned.
IP Addr/Netmask
This field displays the current IP address and subnet mask assigned to the interface. If the IP address and subnet mask are 0.0.0.0, the interface is disabled or did not receive an IP address and subnet mask via DHCP.
If this interface is a member of an active virtual router, this field displays the IP address it is currently using. This is either the static IP address of the interface (if it is the master) or the management IP address (if it is a backup).
VLAN ID
This field displays the VLAN ID which is a 12-bit number that uniquely identifies each VLAN.
IP Assignment
This field displays how the interface gets its IP address.
• Static - This interface has a static IP address.
• DHCP Client - This interface gets its IP address from a DHCP server.
Service
This field lists which services the interface provides to the network. Examples include DHCP relay, DHCP server and DDNS. This field displays n/a if the interface does not provide any services to the network.
Action
Use this field to get or to update the IP address for the interface. Click Renew to send a new DHCP request to a DHCP server.
VPN Rule
This field displays the scenario rule the VPN tunnel interface is using.
Use Device Insight to collect status and specific information of the clients connected to the Zyxel Device.
Client Identification Methods
The Zyxel Device identifies basic client information directly, such as Status, MAC Address, and IP Address. The Zyxel Device uses three additional methods to identify more detailed client information, such as Device Type, Operating System (OS), OS Version, and Category.
*When a client device has both Astra and Bitdefender installed, the Zyxel Device prioritizes the information to display in the order Astra, Bitdefender, then Zyxel Cloud Fingerprint Service.
Astra
Astra is Zyxel's cloud-based endpoint security service that protects the client network. These services include Content Filtering/URL Blocking, IP Reputation, and URL Threat Filtering, among others. An admin manages and configures these services for client devices (members) through the Astra portal. See the Astra User's Guide for details. Client devices should have the Astra app installed. When a client device connects to your network, the Zyxel Device gets the client device's information.
Bitdefender: GravityZone
Bitdefender is cybersecurity software that provides antivirus, anti-malware, and Internet security solutions. You should first integrate the Zyxel Device with Bitdefender GravityZone Cybersecurity Platform on the System > External Integrations > Bitdefender screen. Refer to Bitdefender for details. Client devices have the Bitdefender installation package installed. When a client device connects to your network, the Zyxel Device gets the client device's information.
*The Bitdefender installation package can only be installed on a computer.
Zyxel Cloud Fingerprint Service is a cloud fingerprint database. Unlike Astra and Bitdefender, using Zyxel Cloud Fingerprint Service does not require installing any software on the client device. The Zyxel Device collects signatures, such as DHCP fingerprints, from client traffic and matches them against the fingerprint database to identify client information.
All devices shown are connected to the Zyxel Device, for example:
• Using wired connections directly to the Zyxel Device.
• Using wired connections through managed APs.
• Using WiFi connections through managed APs.
• Using SecuExtender (IPSec VPN clients).
In the graphic below, the mobile device (A) with the Astra app installed connects to the Zyxel Device through an AP using a WiFi connection. The personal computer (B) with Bitdefender installed connects to the Zyxel Device using a wired connection. Another personal computer (C) connects to the Zyxel Device through an AP using a WiFi connection, without Astra or Bitdefender installed.
The Zyxel Device monitors A, B, and C's information and attempts to determine it through Zyxel Cloud Fingerprint Service (F) to obtain detailed client information. The Zyxel Device obtains A's and B's information directly from Astra and Bitdefender.
Device Insight Example
*To collect clients’ information using Device Insight, the clients must be in the same IP subnet in the LAN/VLAN/DMZ networks behind the Zyxel Device. Information from clients that are in different IP subnets in the LAN/VLAN/DMZ networks might not be collected correctly as traffic must pass through another router or a layer-3 switch to the Zyxel Device.
label
description
Edit
Double-click an entry or select it and click Edit to modify the entry’s settings in the Description field.
Remove
Select an entry and click Remove to remove a client from the table that’s no longer connected to your network.
For example, guest A visited your company over a month ago. Guest A used his cellphone to connect to your Zyxel Device networks. His cellphone was identified and shown in the Device Insight table. Guest A has left for over a month and you’re sure he will not return in the near future. You can use the Remove button to remove his device from this table. Guest A’s device will be identified and shown in the table again if he connects to your Zyxel Device networks in the future.
Please note that clients that are blocked cannot be removed. Make sure to unblock clients before you remove them.
Add to block list
Select an entry and click Add to block list to stop the selected client from connecting to the Zyxel Device.
Remove from block list
Select an entry and click Remove from block list to allow the selected client to connect to the Zyxel Device.
Feedback
Select an entry and click Feedback to report on a client that is wrongly identified regarding its Category, Operating System or Type.
Status
This field displays the status of the clients.
Online ()- The connection between the client and the Zyxel Device is up.
Offline ()- The connection between the client and the Zyxel Device is down.
Block ()- The client is blocked from the connection to the Zyxel Device.
MAC Address
This field displays the MAC address of the client.
MAC Vendor
This displays the MAC address Organizationally Unique Identifier (OUI). The OUI is the first three octets in a MAC address and uniquely identifies the manufacturer of a network device.
IP Address
This field displays the IP address of the client.
Hostname
This field displays the name used to identify this device on the network.
Description
This field displays the descriptive name of the client.
Connected to
This field displays the interface to which a client is connected directly to on the Zyxel Device.
Category
This field displays the device category of the client, such Switch, Router, Firewall, Computer, Gaming Console, IP Phone, IP Camera, Smart TV, Projector, Printer, Network Storage, Mobile Phone/Tablet, IoT, or Media Player.
This field displays the operating system of the client, such as Windows, iOS, macOS, Android, or Linux.
OS Version
This field displays the version of the operating system of the client.
Type
This field displays the model name of the client.
First-seen
This field displays the time when the client first sends traffic to the Zyxel Device since the Zyxel Device last reboot.
Last-seen
This field displays the time when the client last sends traffic to the Zyxel Device.
User
This field displays the type of user account the client uses. See What You Need To Know for more information the user account types.
Auth method
This field displays the authentication method that is used to authenticate the client.
Astra Group & Role
This field displays the group name and role (admin or member) of the client on Astra.
• admin: The Astra web portal is a platform that provides security services to computer or mobile devices. It is managed by an admin.
• member: A member is a person whose computer or mobile device the admin wishes to protect using Astra. You can add your mobile device or a member’s mobile device using this Astra web portal account.
Astra Agent Version
This field displays the version of Astra.
Client Firewall Status
This field displays the firewall status on the client’s computer or mobile device, such as a smartphone. The field is blank is if there is no firewall on the client.
• Enabled: The firewall is enabled on the client.
• Disabled: The firewall is disabled on the client.
Astra License Status
This field displays the current Astra license status of the client.
The following displays for a license you subscribed to from the Astra Portal.
• Activated: The Astra license is enabled.
• Inactive: The Astra license is not enabled.
• Overdue: The payment for the Astra license has failed, and the license will be canceled 15 days after the overdue date. During this period, attempts will be made to process the credit card payment.
• Cancel: The Astra license will be canceled after the expiration date.
• None: A standard or trial license has not been enabled.
The following displays for a license you purchased offline. You’ll need to use the license key to activate the license online.
• Grace period: After a license expires, you have 15 days grace period during which you can extend your current license.
• Expired: The Astra license has expired.
Endpoint Security Vendor
This field displays the security vendor currently used by the client.
Use this screen to see a list of users currently logged into the Zyxel Device.The following table describes the labels in this screen.
Label
Description
Force Logout
Select a user row and click this icon to end a user’s session.
This field is a sequential value and is not associated with any entry.
Auth Source
This field displays the authentication system that verified the logged in user, so as to identify where the user was authenticated for this session.
• A user can log into the Zyxel Device's management interfaces (HTTP, HTTPS, SSH, FTP) using a local admin or viewer account (the account stored locally on the Zyxel Device).
• A user can log into the network via Captive Portal or SSL VPN using an account authenticated by local, AD (Active Directory), LDAP, RADIUS, Nebula Cloud Authentication (cloud-auth), OIDC, or NID FS (nidfs).
The name displayed for users who logged in using AD, LDAP, RADIUS or OIDC is the name configured for the AAA server in User & Authentication > User Authentication > AAA Server.
The name displayed for users who logged in using Nebula Cloud Authentication is cloud-auth. You do not configure this name on the Zyxel Device.
The name displayed here for users who logged in using NID FS is nidfs. The actual NID FS name is the IdP (Identity Provider) name taken from the ID token claim and is different for each user. You do not configure this name on the Zyxel Device.
User ID
This field displays the user name of each user who is currently logged in to the Zyxel Device.
Role
This field displays the types of user accounts the Zyxel Device uses. See User/Group User Summary Screen for more information on the user accounts.
From
This field displays the IP address of the computer used to log in to the Zyxel Device.
Login Time
This field displays how long a user account has logged into the Zyxel Device.
Type
This field displays the way the user logged into the Zyxel Device. The user can log into the Zyxel Device using HTTP, HTTPS, SSH, FTP and console.
Tunnel IP
This field displays the IP address of the VPN tunnel a user account is using to access the Zyxel Device.
This field displays 0.0.0.0 if a user account is not accessing the Zyxel Device through a VPN tunnel.
Reauth/Lease Time
This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each user. See User Add/Edit Screen for more information on the reauthentication time and lease time.
Use this screen to view and unlock IP addresses blocked from logging in to the Zyxel Device. The Zyxel Device locks the source IP address in two cases.
• Failed logins from one source IP address have reached the specified limit.
• Login attempts and logins from one source IP address have reached the specified rate.
*These limits do not apply to logins through the console port or IPSec VPN.
Go to User & Authentication > User/Group > Setting to configure these user account lockout settings. See User/Group Setting Screen for more information.
*The Zyxel Device blocks the source IP address, not the user account. The same account can still log in from a different, non-blocked IP address.
Network Status > Login Users > Lockout IPs
Label
Description
Unlock
Select an IP address and click Unlock to allow the user from that IP address to log into the Zyxel Device.
This field is a sequential value and is associated with the lockout IP address entries.
IP
This displays the IP address that exceeded the login attempt limit.
Type
This displays the reason the IP address is locked.
• Lockout: Failed logins from the IP address reach the specified limit.
• Authentication Rate Limiting: Logins and login attempts from the IP address reach the specified limit.
Last User ID
This displays the last user name attempted from this IP address.
Role
This displays the type of user account that attempted to log into the Zyxel Device, such as:
• Admin: This user can configure the Zyxel Device settings using the web configurator or CLI.
• Viewer: This user can only view the Zyxel Device settings using the web configurator and perform basic diagnostics for troubleshooting using the command line interface (CLI).
• User: This user has access to the Zyxel Device’s services, such as VPN, and can also browse. This user cannot configure or view the Zyxel Device settings using the web configurator or CLI.
• External User: This user account is maintained on a remote server, such as RADIUS or LDAP. This user has access to the Zyxel Device’s services, such as VPN, and can also browse but cannot configure or view the Zyxel Device settings using the web configurator or CLI.
Lockout Time
This displays the remaining time before the IP address is unlocked. This timer restarts if further attempts occur during the lockout period.
Use this screen to look at a list of interfaces and their DHCP-assigned IP addresses.
Label
Description
Current DHCP List
Interface
Select a Zyxel Device interface that has DHCP enabled to show to which devices it has assigned DHCP IP addresses.
Add
Click this to add an entry that maps a static IP to a MAC address.
• A host name cannot exceed 255 characters. Valid characters are [0-9][a-z][A-Z][-]. You can use duplicate host names, but they cannot start with a space or hyphen.
• You must use a valid IPv4 address that is in the DHCP pool.
• The MAC address must be formatted with colons or hyphens as shown in the screen.
Release
Select an entry and click on this button to let other devices use the dynamic DHCP that is currently assigned to the selected entry.
Reserved
Select an entry and click on this button to make the entry a static DHCP entry, meaning the DHCP client is always assigned the same IP address from the DHCP server.
Unreserve
Select an entry and click on this button to change the entry from a static DHCP entry to a dynamic DHCP entry, meaning the DHCP client may get a different IP address from the DHCP server when the IP address is renewed.
Import
A reserved DHCP IP address is an IP address sent from a DHCP server that is aways assigned to the same MAC address. This ensures that the DHCP client always receives the same IP address. This allows you to manage DHCP clients centrally without having to configure static IP addresses on each DHCP client.
First create a list of reserved DHCP IP address in a file in CSV (comma separated values) format. Download the sample file (StaticDHCP_samplefile.csv) and follow that format exactly.
• The file size must be less than 1MB.
• The first row must have the column titles exactly as shown in the sample file: Interface, IP Address, Host Name, MAC Address, Description, Status.
• The Host Name must be as follows. The first character must be a digit (0–9), or a lowercase letter (a–z), or an uppercase letter (A–Z). Hyphens are not allowed as the first character. After the first character, you may have 0 to 254 more characters. Allowed characters in this part are digits (0–9), lowercase letters (a–z), uppercase letters (A–Z), hyphen (-). The minimum length is 1 character and the maximum length is 255 characters (1 + 254). Valid Examples are a, Z1, abc-123, A0-xyz-9. Invalid Examples are -abc (starts with a hyphen), abc! (contains !), ab@cd (contains @).
• The Host Name does not need to be unique for each subnet.
• Host Names of static DHCP clients cannot be empty.
• If the Host Name of a reserved DHCP client is empty, the Zyxel Device will replace the hostname with the MAC address of the DHCP client. It will use uppercase letters (for hex A to E), and separate octet pairs with hyphens.
• Use the standard format for IP Address and MAC Address.
• The reserved IP addresses must be in the same subnet as the associated interface in the CSV file and the DHCP server. For example, if you have a DHCP server with IP address 192.168.170.200 on the ge3 interface, then please note the following for entries in the CSV file.
ge3 192.168.168.33 aa:aa:aa:aa:aa:aa -> this won’t be imported as the IP address is not in the DHCP server subnet.
ge4 192.168.170.33 aa:aa:aa:aa:aa:ab -> this won’t be imported as the interface is wrong
ge3 192.168.170.33 aa:aa:aa:aa:aa:ac -> this will be imported
• If you use an external DHCP server, by default the DHCP server must have an IP address in the same subnet as the IP address of the Interface on the Zyxel Device. Use the command usgflex500h running config# vrf main dhcp server subnet if you want to change the IP address of the DHCP server to be in a different subnet to that of the Zyxel Device interface. For example, you can bind the above DHCP server to the g4 interface with IP subnet 192.168.168.1/24.
• Status must always be Reserved.
After you have created the file, click this button to import the file into the Zyxel Device so that the DHCP server can assign these IP addresses to the associated MAC addresses in the list.
If an import fails, please check the points above or check dhcp-import-failed.log in Maintenance > Diagnostics.
Export
Click this button to download all entries in the DHCP table to your computer in csv format with file name containing the current date.
Refresh
Click this button to update the mapping between IP addresses and MAC addresses.
Column header
Click a column’s heading cell to sort the table entries by the column entry. Click the heading cell again to reverse the sort order.
Interface
This field identifies the interface that assigned an IP address to a DHCP client.
IP Address
This field displays the IP address currently assigned to a DHCP client or reserved for a specific MAC address. Click the column’s heading cell to sort the table entries by IP address. Click the heading cell again to reverse the sort order.
Host Name
This field displays the name used to identify this device on the network (the computer name). The Zyxel Device learns these from the DHCP client requests.
• The Zyxel Device supports the display of host names in languages other than English.
• If the DHCP client does not have a hostname, the Zyxel Device uses its MAC address (in uppercase).
• None shows here for a static DHCP entry.
*You can have duplicate host names for static (reserved) IP addresses.
MAC Address
This field displays the MAC address to which the IP address is currently assigned or for which the IP address is reserved. The MAC address format can be "xx:xx:xx:xx:xx:xx" or "xx-xx-xx-xx-xx-xx"
VLAN ID
This field displays the VLAN to which the IP address belongs, if any.
Expire Time
This displays the date and time the DHCP-assigned address will be renewed.
Description
This field displays a description of the DHCP client to identify it. The description cannot exceed 64 characters. Valid characters are [0-9][a-z][A-Z][_ -].
*You can only edit the description for clients with static (reserved) IP addresses.
Status
This field displays the connection status of the DHCP client. Reserved means a static DHCP entry. - means a dynamic DHCP entry.
The IPSec VPN Screen
Click a column’s heading cell to sort the table entries by that column’s criteria. Click the heading cell again to reverse the sort order.
Use this screen to display and to manage active IPSec policies.
Each field is described in the following table.
Label
Description
Disconnect
Select an IPSec policy and click this button to disconnect it.
Refresh
Select an IPSec policy and click this button to update its status.
Connectivity Check
Select an IPSec policy and click this button to check the connection to a remote client through this VPN tunnel. Enter an IP address in the remote policy subnet range. The Zyxel Device interface must comply with the local policy subnet range. The check will time out after 5 seconds if there is no reply to the ICMP check (Ping).
This field is a sequential value, and it is not associated with a specific SA.
Name
This field only displays the client names if they’re using EAP or X-auth for authentication.
If a client is connected to the Zyxel Device without using Extended Authentication Protocol (EAP) or X-Auth, this field will be empty.
Remote Gateway
This field displays the IP address of the remote gateway.
Remote ID
This field displays the ID of the remote gateway.
My Address
This field displays the IP address of the Zyxel Device.
Policy Route
This field displays the content of the local and remote policies for this IPSec policy. The IP addresses, not the address objects, are displayed.
Uptime
This field displays how many seconds the IPSec policy has been active. This field displays N/A if the IPSec policy uses manual keys.
Rekey
This field displays how many seconds remain in the SA life time, before the Zyxel Device automatically disconnects the IPSec policy. This field displays N/A if the IPSec policy uses manual keys.
Inbound (Bytes)
This field displays the amount of traffic that has gone through the IPSec policy from the remote IPSec router to the Zyxel Device since the IPSec policy was established.
Outbound (Bytes)
This field displays the amount of traffic that has gone through the IPSec policy from the Zyxel Device to the remote IPSec router since the IPSec policy was established.
Total (Bytes)
This field displays the total traffic that has passed through the IPSec policy (Inbound + Outbound) since the IPSec policy was established.
Usage (%)
This field displays the percentage of usage for this IPSec policy among all IPSec policies.
Total Usage for All Tunnels
This displays the total usage of all IPSec policies, including both inbound and outbound usage.
Use this screen to display or disconnect remote access VPN clients that are connected to the Zyxel Device. The remote access VPN clients must have SecuExtender or use supported computer or mobile operating systems; see The Remote Access VPN Screen for more information.
Label
Description
Disconnect
Select a remote access VPN client and click this button to disconnect it.
Refresh
Click Refresh to update this screen.
This field is a sequential value, and it is not associated with a specific remote access VPN client.
Username
This field displays the name of the remote access VPN client.
Assigned IP
This field displays the IP address the user used to establish this remote access VPN connection.
Remote IP
This field displays the IP address of the remote IPSec router the remote access VPN client is connected to.
Up Time
This field displays how many seconds the remote access VPN client has been active. This field displays N/A if the remote access VPN client uses manual keys.
Reauth/Lease Time
This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each remote access VPN client.
Inbound (Bytes)
This field displays the number of bytes received by the Zyxel Device on this connection.
Outbound (Bytes)
This field displays the number of bytes transmitted by the Zyxel Device on this connection.
The SSL VPN Screen
The Zyxel Device keeps track of the SSL VPN clients who are currently logged into the Zyxel Device. Use this screen to:
• View a list of active SSL VPN connections.
• Log out individual users and delete related session information.
Once a user logs out, the corresponding entry is removed from the screen.
The SSL VPN clients must have SecuExtender or use supported computer or mobile operating systems; see The SSL VPN Screen for more information.
label
description
Disconnect
Select a connection and click this button to terminate the user’s connection and delete corresponding session information from the Zyxel Device.
Refresh
This field is a sequential value, and it is not associated with a specific SSL.
Username
This field displays the account user name used to establish this SSL VPN connection.
Assigned IP
This field displays the IP address the user used to establish this SSL VPN connection.
Remote IP
This field displays the remote SSL VPN router the SSL VPN is connected to.
Up Time
This field displays how many seconds the SSL VPN client has been active. This field displays N/A if the SSL VPN client uses manual keys.
Reauth/Lease Time
This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each SSL VPN client.
Inbound (Bytes)
Outbound (Bytes)
Regular Expressions in Searching IPSec Policies
A question mark (?) lets a single character in the VPN connection or policy name vary. For example, use “a?c” (without the quotation marks) to specify abc, acc and so on.
Wildcards (*) let multiple VPN connection or policy names match the pattern. For example, use “*abc” (without the quotation marks) to specify any VPN connection or policy name that ends with “abc”. A VPN connection named “testabc” would match. There could be any number (of any type) of characters in front of the “abc” at the end and the VPN connection or policy name would still match. A VPN connection or policy name named “testacc” for example would not match.
A * in the middle of a VPN connection or policy name has the Zyxel Device check the beginning and end and ignore the middle. For example, with “abc*123”, any VPN connection or policy name starting with “abc” and ending in “123” matches, no matter how many characters are in between.
The whole VPN connection or policy name has to match if you do not use a question mark or asterisk.
The Zyxel Device supports Tailscale, a mesh VPN (Virtual Private Network) service that connects client devices (such as computers, smartphones, routers, and firewalls) across different networks. Use this screen to view the Tailscale connection status.
Click VPN Status > Tailscale to display the following screen.
label
description
Refresh
This field is a sequential value, and it is not associated with a specific VPN connection.
Machine Name
This field displays the domain name of the Tailscale server.
Tailscale IP
This field displays the IP address assigned to the Zyxel Device by the Tailscale server.
Owner
The Tailscale account name that establishes the VPN connection.
Status
This displays the status of the VPN connection.
• active: The VPN connection is established and data is being transmitted.
• idle: The VPN connection is established and ready to be used, but no data is being transmitted.
• offline: The Zyxel Device is currently not connected to the Tailscale network.
• -: No data has ever been sent to or received from the Zyxel Device.
Inbound (Bytes)
This field displays the number of bytes received by the Zyxel Device on this VPN connection.
Outbound (Bytes)
This field displays the number of bytes transmitted by the Zyxel Device on this VPN connection.
The Zyxel Device supports Remote AP feature. A Remote AP connects to the Zyxel Device through an IPSec VPN. Use this screen to view the connection status. See Remote AP for details about Remote AP.
label
description
Disconnect
Select a remote AP and click Disconnect to disconnect it from the Zyxel Device.
Refresh
RAP Description
This field displays the name configured for the remote AP in Wireless > Access Points > AP List > Edit.
Assigned IP
This field displays the IP address that the remote AP uses within the IPSec VPN tunnel after the tunnel connection is established.
Remote IP
This field displays the IP address that the Zyxel Device assigns to the remote AP. The remote AP uses this IP address to establish the IPSec VPN tunnel with the Zyxel Device.
Up Time
This field displays how long the remote AP has been connected to the Zyxel Device.
Reauth/Lease Time
This field displays the amount of reauthentication time remaining and the amount of lease time remaining for the remote AP.
Reauth Time: How often the remote AP has to reauthenticate with the Zyxel Device. The default time is 28800 seconds.
Lease Time: How long the remote AP can maintain the connection with the Zyxel Device. The countdown is reset after a successful authentication.
Inbound (Bytes)
Outbound (Bytes)
Use this screen to view the wireless traffic usage and the number of connected stations (wireless clients) for the managed APs.
Each model supports display of data for the following number of historical days.
Historical Data Display by Model
Model
Last X Day(s)
USG FLEX 50H
USG FLEX 50HP
USG FLEX 100H
USG FLEX 100HP
USG FLEX 200H
2
USG FLEX 200HP
2
USG FLEX 500H
8
USG FLEX 700H
8
The Top N APs Screen
Use this screen to view the wireless traffic usage and associated wireless stations of the top five or top ten managed APs.
Wireless Status > Access Points > Top N APs
label
description
Date
Select a date to view the preceding 24 hours of data, or select Last X Days to view data for the preceding supported days.
Ranking
Select the top five or top ten managed APs by traffic usage or number of connected stations to sort data for display.
AP Radio
If you view data by usage, select the frequency band to display on the graph.
Refresh
The displayed data is updated hourly. Click Refresh to get the latest data for the current hour.
Traffic Usage
This graph displays the wireless traffic transmitted to and from the managed APs over time or by date.
Total
This shows the total traffic used by all managed APs on the selected date or over the selected date range.
y-axis
This represents the amount of traffic in MB (megabytes), GB (gigabytes), TB (terabytes), or PB (petabytes).
x-axis
This represents the time or date.
Station Count
This graph displays the number of wireless stations connected to the managed APs over time or by date.
y-axis
This represents the number of connected wireless stations.
x-axis
The Single AP Screen
Use this screen to view wireless traffic usage and wireless stations for a managed AP.
Wireless Status > Access Points > Single AP
label
description
Date
Select a date to view the preceding 24 hours of data, or select Last X days to view data for the preceding supported days.
AP
Select a managed AP to view its wireless data.
Refresh
Traffic Usage
This graph displays the traffic usage of the managed AP over time or by date.
Total
This shows the total traffic used by the managed AP on the selected date or over the selected date range.
y-axis
x-axis
TThis represents the time or date.
Station Count
This graph displays the number of wireless stations connected to the managed AP over time or by date.
y-axis
x-axis
Use this screen to view the wireless traffic usage of the managed APs’ wireless clients.
Refer to Historical Data Display by Model for the number of historical days each model supports for display.
The Top N Stations Screen
Use this screen to view the traffic usage of the top five or top ten wireless clients.
Wireless Status > WLAN Clients > Top N Stations
label
description
Date
Ranking
Select the top five or top ten wireless clients by traffic usage to sort data for display.
Refresh
Traffic Usage
This graph displays the wireless traffic transmitted to and from the wireless clients over time or by date.
Total
This shows the total traffic used by all wireless clients on the selected date or over the selected date range.
y-axis
x-axis
The Single Station Screen
Use this screen to view the traffic usage of a wireless client.
Wireless Status > WLAN Clients > Single Station
label
description
Date
Station
Select a wireless client to view its wireless data.
Refresh
Traffic Usage
This graph displays the wireless traffic transmitted to and from the wireless client over time or by date.
Total
This shows the total traffic used by the wireless client on the selected date or over the selected date range.
y-axis
x-axis
