Anti-Spam
The anti-spam feature can mark or discard spam (unsolicited commercial or junk e-mail). Use the Allow List to identify legitimate e-mail. Use the Block List to identify spam e-mail. The Zyxel Device can also check e-mail against a DNS black list (DNSBL) of IP addresses of servers that are suspected of being used by spammers.
Use the General screens (Anti-Spam Profile) to turn anti-spam on or off and manage anti-spam policies.
Use the Mail Scan screen (The Mail Scan Screen) to enable and configure the mail scan functions.
Use the Block/Allow List screens (The Anti-Spam Block List Screen) to set up a block list to identify spam and an allow list to identify legitimate e-mail.
Use the DNSBL screens (The DNSBL Screen) to have the Zyxel Device check e-mail against DNS Black Lists.
Allow List
Configure allow list entries to identify legitimate e-mail. The allow list entries have the Zyxel Device classify any e-mail that is from a specified sender or uses a specified header field and header value as being legitimate (see E-mail Headers for more on mail headers). The anti-spam feature checks an e-mail against the allow list entries before doing any other anti-spam checking. If the e-mail matches an allow list entry, the Zyxel Device classifies the e-mail as legitimate and does not perform any more anti-spam checking on that individual e-mail. A properly configured allow list helps keep important e-mail from being incorrectly classified as spam. The allow list can also increases the Zyxel Device’s anti-spam speed and efficiency by not having the Zyxel Device perform the full anti-spam checking process on legitimate e-mail.
Block List
Configure block list entries to identify spam. The block list entries have the Zyxel Device classify any e-mail that is from or forwarded by a specified IP address or uses a specified header field and header value as being spam. If an e-mail does not match any of the allow list entries, the Zyxel Device checks it against the block list entries. The Zyxel Device classifies an e-mail that matches a block list entry as spam and immediately takes the configured action for dealing with spam. If an e-mail matches a block list entry, the Zyxel Device does not perform any more anti-spam checking on that individual e-mail. A properly configured block list helps catch spam e-mail and increases the Zyxel Device’s anti-spam speed and efficiency.
SMTP and POP3
Simple Mail Transfer Protocol (SMTP) is the Internet’s message transport standard. It controls the sending of e-mail messages between servers. E-mail clients (also called e-mail applications) then use mail server protocols such as POP (Post Office Protocol) or IMAP (Internet Message Access Protocol) to retrieve e-mail. E-mail clients also generally use SMTP to send messages to a mail server. The older POP2 requires SMTP for sending messages while the newer POP3 can be used with or without it. This is why many e-mail applications require you to specify both the SMTP server and the POP or IMAP server (even though they may actually be the same server).
The Zyxel Device’s anti-spam feature checks SMTP (TCP port 25) and POP3 (TCP port 110) e-mails by default. You can also specify custom SMTP and POP3 ports for the Zyxel Device to check.
E-mail Headers
Every email has a header and a body. The header is structured into fields and includes the addresses of the recipient and sender, the subject, and other information about the e-mail and its journey. The body is the actual message text and any attachments. You can have the Zyxel Device check for specific header fields with specific values.
E-mail programs usually only show you the To:, From:, Subject:, and Date: header fields but there are others such as Received: and Content-Type:. To see all of an e-mail’s header, you can select an e-mail in your e-mail program and look at its properties or details. For example, in Microsoft’s Outlook Express, select a mail and click File > Properties > Details. This displays the e-mail’s header. Click Message Source to see the source for the entire mail including both the header and the body.
E-mail Header Buffer Size
The Zyxel Device has a 5 K buffer for an individual e-mail header. If an e-mail’s header is longer than 5 K, the Zyxel Device only checks up to the first 5 K.
DNSBL
A DNS Black List (DNSBL) is a server that hosts a list of IP addresses known or suspected of having sent or forwarded spam. A DNSBL is also known as a DNS spam blocking list. The Zyxel Device can check the routing addresses of e-mail against DNSBLs and classify an e-mail as spam if it was sent or forwarded by a computer with an IP address in the DNSBL.
Before You Begin
Before using the Anti-Spam features (IP Reputation, Mail Content Analysis and Virus Outbreak Detection) you must activate your Anti-Spam Service license.
Configure your zones before you configure anti-spam.
Anti-Spam Profile
Use this screen to turn the anti-spam feature on or off and manage anti-spam policies. You can also select the action the Zyxel Device takes when the mail sessions threshold is reached.
Click on the icons to go to the OneSecurity website where there is guidance on configuration walkthroughs, troubleshooting and other information.
Configuration > Security Service > Anti-Spam > Profile
Label
Description
General Settings
Action taken when mail sessions threshold is reached
An e-mail session is when an e-mail client and e-mail server (or two e-mail servers) connect through the Zyxel Device. Select how to handle concurrent e-mail sessions that exceed the maximum number of concurrent e-mail sessions that the anti-spam feature can handle. See the chapter of product specifications for the threshold.
Select Forward Session to have the Zyxel Device allow the excess e-mail sessions without any spam filtering.
Select Drop Session to have the Zyxel Device drop mail connections to stop the excess e-mail sessions. The e-mail client or server will have to re-attempt to send or receive e-mail later when the number of e-mail sessions is under the threshold.
Add
Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
References
Select an entry and click References to open a screen that shows which settings use the entry.Click Refresh to update information in this screen.
Priority
This is the index number of the anti-spam rule. Antis-spam rules are applied in turn.
Name
The name identifies the anti-spam rule.
Description
This is some optional extra information on the rule.
Scan Options
This shows which types (protocols) of traffic to scan for spam.
Reference
This shows how many objects are referenced in the rule.
Service
Service Status
This field displays whether a service license is enabled at myZyxel (Activated) or not (Not Activated) or expired (Expired). It displays the remaining Grace Period if your license has Expired. It displays Not Licensed if there isn’t a license to be activated for this service.
If you need a license or a trial license has expired, click Buy to buy a new one. If a Standard license has expired, click Renew to extend the license.
Then, click Activate to connect with the myZyxel server to activate the new license.
Service Type
This read-only field displays what kind of service registration you have for the anti-spam scanning.
None displays if you have not successfully registered and activated the service.
Standard displays if you have successfully registered the Zyxel Device and activated the service with your iCard’s PIN number.
Trial displays if you have successfully registered the Zyxel Device and activated the trial service subscription.
Expiration Date
This field displays the date your service license expires.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
The Anti-Spam Profile Add or Edit Screen
Use this screen to configure an anti-spam policy that controls scan options, and the action to take on spam traffic.
Configuration > Security Service > Anti-Spam > Profile > Add
label
description
General Settings
Name
Enter a descriptive name for this anti-spam rule. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
Description
Enter a description for the anti-spam rule to help identify the purpose of rule. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
This field is optional.
Log
Select how the Zyxel Device is to log the event when the DNSBL times out or an e-mail matches the allow list, block list, or DNSBL.
no: Do not create a log.
log: Create a log on the Zyxel Device.
log alert: An alert is an e-mailed log for more serious events that may need more immediate attention. Select this option to have the Zyxel Device send an alert.
Scan Options
Check Allow List
Select this checkbox to check e-mail against the allow list. The Zyxel Device classifies e-mail that matches an allow list entry as legitimate (not spam).
Check Block List
Select this checkbox to check e-mail against the block list. The Zyxel Device classifies e-mail that matches a block list entry as spam.
Check Malicious Mail
Check DNSBL
Select this checkbox to check e-mail against the Zyxel Device’s configured DNSBL domains. The Zyxel Device classifies e-mail that matches a DNS black list as spam.
Actions for Spam Mail
Use this section to set how the Zyxel Device is to handle spam mail.
SMTP
Select how the Zyxel Device is to handle spam SMTP mail.
Select drop to discard spam SMTP mail.
Select forward to allow spam SMTP mail to go through.
Select forward with tag to add a spam tag to an SMTP spam mail’s mail subject and send it on to the destination.
POP3
Select how the Zyxel Device is to handle spam POP3 mail.
Select forward to allow spam POP3 mail to go through.
Select forward with tag to add a spam tag to an POP3 spam mail’s mail subject and send it on to the destination.
OK
Click OK to save your changes.
Cancel
Click Cancel to exit this screen without saving your changes.
Use this screen to enable and configure the Mail Scan functions. You must first enable the mail scan functions on this screen before selecting them in the Configuration > Security Service > Anti-Spam > Profile > Add/Edit screen.
Configuration > Security Service > Anti-Spam > Mail Scan
Label
Description
General Settings
Enable Malicious Mail Checking
Select this to identify spam email by content, such as malicious content.
Malicious Mail Tag
Enter a message or label (up to 15 ASCII characters) to add to the beginning of the mail subject of emails that are determined to spam based on the mail content analysis.
This tag is only added if the email security policy is configured to forward spam mail with a spam tag.
Malicious X-Header
Specify the name and value for the X-Header to be added to e-mails that are determined as spam email.
Query Timeout Settings
SMTP
Select how the Zyxel Device is to handle SMTP mail query timeout.
Select drop to discard SMTP mail.
Select forward to allow SMTP mail to go through.
Select forward with tag to add a tag to an SMTP query timeout mail’s mail subject and send it on to the destination.
POP3
Select how the Zyxel Device is to handle POP3 mail query timeout.
Select forward to allow POP3 mail to go through.
Select forward with tag to add a tag to an POP3 query timeout mail’s mail subject and send it on to the destination.
Timeout Value
Set how long the Zyxel Device waits for a reply from the mail scan server. If there is no reply before this time period expires, the Zyxel Device takes the action defined in the relevant Actions when Query Timeout field.
Timeout Tag
Enter a message or label (up to 15 ASCII characters) to add to the mail subject of e-mails that the Zyxel Device forwards if queries to the mail scan servers time out.
Timeout X-Header
Specify the name and value for the X-Header to be added when queries to the mail scan servers time out.
Apply
Reset
Configure the block list to identify spam e-mail. You can create block list entries based on the sender’s or relay server’s IP address or e-mail address. You can also create entries that check for particular e-mail header fields with specific values or specific subject text. Click a column’s heading cell to sort the table entries by that column’s criteria. Click the heading cell again to reverse the sort order.
Configuration > Security Service > Anti-Spam > Block/Allow List > Block List
Label
Description
General Settings
Enable Block List Checking
Select this checkbox to have the Zyxel Device treat e-mail that matches (an active) block list entry as spam.
Block List Spam Tag
Enter a message or label (up to 15 ASCII characters) to add to the mail subject of e-mails that match the Zyxel Device’s spam black list.
Block List X-Header
Specify the name and value for the X-Header to be added to e-mails that match the Zyxel Device’s spam black list.
Rule Summary
Add
Edit
Remove
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Status
The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive.
This is the entry’s index number in the list.
Type
This field displays whether the entry is based on the e-mail’s subject, source or relay IP address, source e-mail address, or header.
Content
This field displays the subject content, source or relay IP address, source e-mail address, or header value for which the entry checks.
Apply
Reset
The Anti-Spam Block or Allow List Add/Edit Screen
Use this screen to configure an anti-spam block list entry to identify spam e-mail. You can create entries based on specific subject text, or the sender’s or relay’s IP address or e-mail address. You can also create entries that check for particular header fields and values.
Configuration > Security Service > Anti-Spam > Block/Allow List > Block/Allow List > Add
Label
Description
Enable Rule
Select this to have the Zyxel Device use this entry as part of the block or allow list.
To actually use the entry, you must also turn on the use of the list in the corresponding list screen, enable the anti-spam feature in the anti-spam general screen, and configure an anti-spam policy to use the list.
Type
Use this field to base the entry on the e-mail’s subject, source or relay IP address, source e-mail address, or header.
Select Subject to have the Zyxel Device check e-mail for specific content in the subject line.
Select IP Address to have the Zyxel Device check e-mail for a specific source or relay IP address.
Select IPv6 Address to have the Zyxel Device check e-mail for a specific source or relay IPv6 address.
Select E-Mail Address to have the Zyxel Device check e-mail for a specific source e-mail address or domain name.
Select Mail Header to have the Zyxel Device check e-mail for specific header fields and values. Configure block list header entries to check for e-mail from bulk mail programs or with content commonly used in spam. Configure allow list header entries to allow certain header values that identify the e-mail as being from a trusted source.
Mail Subject Keyword
This field displays when you select the Subject type. Enter up to 63 ASCII characters of text to check for in e-mail headers. Spaces are not allowed, although you could substitute a question mark (?). See Regular Expressions in Block or Allow List Entries for more details.
Sender or Mail Relay IP Address
This field displays when you select the IP Address type. Enter an IP address in dotted decimal notation.
Sender or Mail Relay IPv6 Address
This field displays when you select the IPv6 Address type. Enter an IPv6 address with prefix.
Netmask
This field displays when you select the IP type. Enter the subnet mask here, if applicable.
Sender E-Mail Address
This field displays when you select the E-Mail type. Enter a keyword (up to 63 ASCII characters). See Regular Expressions in Block or Allow List Entries for more details.
Mail Header Field Name
This field displays when you select the Mail Header type.
Type the name part of an e-mail header (the part that comes before the colon). Use up to 63 ASCII characters.
For example, if you want the entry to check the “Received:” header for a specific mail server’s domain, enter “Received” here.
Field Value Keyword
Type the value part of an e-mail header (the part that comes after the colon). Use up to 63 ASCII characters.
For example, if you want the entry to check the “Received:” header for a specific mail server’s domain, enter the mail server’s domain here.
OK
Cancel
The following applies for a block or allow list entry based on an e-mail subject, e-mail address, or e-mail header value.
Use a question mark (?) to let a single character vary. For example, use “a?c” (without the quotation marks) to specify abc, acc and so on.
You can also use a wildcard (*). For example, if you configure *def.com, any e-mail address that ends in def.com matches. So “mail.def.com” matches.
The wildcard can be anywhere in the text string and you can use more than one wildcard. You cannot use two wildcards side by side, there must be other characters between them.
The Zyxel Device checks the first header with the name you specified in the entry. So if the e-mail has more than one “Received” header, the Zyxel Device checks the first one.
The Anti-Spam Allow List Screen
Configure the allow list to identify legitimate e-mail. You can create allow list entries based on the sender’s or relay’s IP address or e-mail address. You can also create entries that check for particular header fields and values or specific subject text.
Configuration > Security Service > Anti-Spam > Block/Allow List > Allow List
Label
Description
General Settings
Enable Allow List Checking
Select this checkbox to have the Zyxel Device forward e-mail that matches (an active) allow list entry without doing any more anti-spam checking on that individual e-mail.
Allow List X-Header
Specify the name and value for the X-Header to be added to e-mails that match the Zyxel Device’s spam allow list.
Rule Summary
Add
Click this to create a new entry. See The Anti-Spam Block or Allow List Add/Edit Screen for details.
Edit
Select an entry and click this to be able to modify it. See The Anti-Spam Block or Allow List Add/Edit Screen for details.
Remove
Activate
Inactivate
Status
Type
This field displays whether the entry is based on the e-mail’s subject, source or relay IP address, source e-mail address, or a header.
Content
Apply
Reset
The DNSBL Screen
Use this screen to configure the Zyxel Device to check the sender and relay IP addresses in e-mail headers against DNS (Domain Name Service)-based spam Black Lists (DNSBLs).
Configuration > Security Service > Anti-Spam > DNSBL
Label
Description
Show Advanced Settings / Hide Advanced Settings
Click this button to display a greater or lesser number of configuration fields.
Enable DNS Black List (DNSBL) Checking
Select this to have the Zyxel Device check the sender and relay IP addresses in e-mail headers against the DNSBL servers maintained by the DNSBL domains listed in the Zyxel Device.
DNSBL Spam Tag
Enter a message or label (up to 15 ASCII characters) to add to the beginning of the mail subject of e-mails that have a sender or relay IP address in the header that matches a block list maintained by one of the DNSBL domains listed in the Zyxel Device.
This tag is only added if the anti-spam policy is configured to forward spam mail with a spam tag.
Max. IPs Checking Per Mail
Set the maximum number of sender and relay server IP addresses in the mail header to check against the DNSBL domain servers.
IP Selection Per Mail
Select first N IPs to have the Zyxel Device start checking from the first IP address in the mail header. This is the IP of the sender or the first server that forwarded the mail.
Select last N IPs to have the Zyxel Device start checking from the last IP address in the mail header. This is the IP of the last server that forwarded the mail.
SMTP
Select how the Zyxel Device is to handle SMTP mail (mail) going to an e-mail server) if the queries to the DNSBL domains time out.
Select forward with tag to add a DNSBL timeout tag to the mail subject of an SMTP mail and send it.
POP3
Select how the Zyxel Device is to handle POP3 mail (mail coming to an e-mail client) if the queries to the DNSBL domains time out.
Select forward with tag to add a DNSBL timeout tag to the mail subject of an POP3 mail and send it.
Timeout Value
Set how long the Zyxel Device waits for a reply from the DNSBL domains listed below. If there is no reply before this time period expires, the Zyxel Device takes the action defined in the relevant Actions when Query Timeout field.
Timeout Tag
Enter a message or label (up to 15 ASCII characters) to add to the mail subject of e-mails that the Zyxel Device forwards if queries to the DNSBL domains time out.
Timeout X-Header
Specify the name and value for the X-Header to be added to e-mails that the Zyxel Device forwards if queries to the DNSBL domains time out.
DNSBL Domain List
Add
Edit
Remove
Activate
Inactivate
Status
DNSBL Domain
This is the name of a domain that maintains DNSBL servers. Enter the domain that is maintaining a DNSBL.
Apply
Reset
Anti-Spam Technical Reference
Here is more detailed anti-spam information.
DNSBL
The Zyxel Device checks only public sender and relay IP addresses, it does not check private IP addresses.
The Zyxel Device sends a separate query (DNS lookup) for each sender or relay IP address in the e-mail’s header to each of the Zyxel Device’s DNSBL domains at the same time.
The DNSBL servers send replies as to whether or not each IP address matches an entry in their list. Each IP address has a separate reply.
As long as the replies are indicating the IP addresses do not match entries on the DNSBL lists, the Zyxel Device waits until it receives at least one reply for each IP address.
If the Zyxel Device receives a DNSBL reply that one of the IP addresses is in the DNSBL list, the Zyxel Device immediately classifies the e-mail as spam and takes the anti-spam policy’s configured action for spam. The Zyxel Device does not wait for any more DNSBL replies.
If the Zyxel Device receives at least one non-spam reply for each of an e-mail’s routing IP addresses, the Zyxel Device immediately classifies the e-mail as legitimate and forwards it.
Any further DNSBL replies that come after the Zyxel Device classifies an e-mail as spam or legitimate have no effect.
The Zyxel Device records DNSBL responses for IP addresses in a cache for up to 72 hours. The Zyxel Device checks an e-mail’s sender and relay IP addresses against the cache first and only sends DNSBL queries for IP addresses that are not in the cache.
Here is an example of an e-mail classified as spam based on DNSBL replies.
1 The Zyxel Device receives an e-mail that was sent from IP address a.a.a.a and relayed by an e-mail server at IP address b.b.b.b. The Zyxel Device sends a separate query to each of its DNSBL domains for IP address a.a.a.a. The Zyxel Device sends another separate query to each of its DNSBL domains for IP address b.b.b.b.
2 DNSBL A replies that IP address a.a.a.a does not match any entries in its list (not spam).
3 DNSBL C replies that IP address b.b.b.b matches an entry in its list.
4 The Zyxel Device immediately classifies the e-mail as spam and takes the action for spam that you defined in the anti-spam policy. In this example it was an SMTP mail and the defined action was to drop the mail. The Zyxel Device does not wait for any more DNSBL replies.
Here is an example of an e-mail classified as legitimate based on DNSBL replies.
1 The Zyxel Device receives an e-mail that was sent from IP address c.c.c.c and relayed by an e-mail server at IP address d.d.d.d. The Zyxel Device sends a separate query to each of its DNSBL domains for IP address c.c.c.c. The Zyxel Device sends another separate query to each of its DNSBL domains for IP address d.d.d.d.
2 DNSBL B replies that IP address d.d.d.d does not match any entries in its list (not spam).
3 DNSBL C replies that IP address c.c.c.c does not match any entries in its list (not spam).
4 Now that the Zyxel Device has received at least one non-spam reply for each of the e-mail’s routing IP addresses, the Zyxel Device immediately classifies the e-mail as legitimate and forwards it. The Zyxel Device does not wait for any more DNSBL replies.
If the Zyxel Device receives conflicting DNSBL replies for an e-mail routing IP address, the Zyxel Device classifies the e-mail as spam. Here is an example.
1 The Zyxel Device receives an e-mail that was sent from IP address a.b.c.d and relayed by an e-mail server at IP address w.x.y.z. The Zyxel Device sends a separate query to each of its DNSBL domains for IP address a.b.c.d. The Zyxel Device sends another separate query to each of its DNSBL domains for IP address w.x.y.z.
2 DNSBL A replies that IP address a.b.c.d does not match any entries in its list (not spam).
3 While waiting for a DNSBL reply about IP address w.x.y.z, the Zyxel Device receives a reply from DNSBL B saying IP address a.b.c.d is in its list.
