label | description |
Last 24 Hours Summary | If you want to view more data than the past 24 hours in SecuReporter, click View More. You should already have a SecuReporter account. |
Pie Chart | Click an item in the pie chart for more detailed information. |
Refresh | Click this button to update the report display. |
Flush Data | Click this button to discard all of the screen’s statistics for inactive sessions. Flushing data only removes traffic logs from ended sessions. Active sessions remain unaffected. Click Refresh to update the report display. |
Top Usage by | Select to display usage by application or host IP address. |
Application | If you selected by application, then this is the name of the application identified. |
Category | This is the category the application belongs to. |
Usage | This is how much traffic the application has used. |
%Usage | This is the percentage of traffic the application has used. |
Client IP address | If you selected by host IP address, then this is the IP address of the host identified. |
Client Description | This is the name of the host identified. |
MAC Address | This is the MAC address of the host device. |
Usage | This is how much traffic the host has used. |
%Usage | This is the percentage of traffic the host has used. |
Model | Number of Interfaces |
USG FLEX 50H USG FLEX 50HP | 5 |
USG FLEX 100H USG FLEX 100HP USG FLEX 200H USG FLEX 200HP USG FLEX 500H USG FLEX 700H | 8 |
Monitor Port | Select one or multiple ports from the drop-down list to view port packet statistics. The maximum number of displayable ports varies by model. See Maximum Displayable Ports for the maximum number of ports you can select. A warning message will appear if you attempt to select more than the maximum. |
Poll Interval | Enter how often you want this window to be updated automatically, and click Refresh. |
TX | This line represents traffic transmitted from the Zyxel Device on the selected physical port since it was last connected. Click TX to show or hide the TX line in the chart. |
RX | This line represents the traffic received by the Zyxel Device on the selected physical port since it was last connected. Click RX to show or hide the RX line in the chart. |
USG FLEX 50H USG FLEX 50HP USG FLEX 100H USG FLEX 100HP USG FLEX 200H USG FLEX 200HP USG FLEX 500H USG FLEX 700H | 8 |
Monitor Interface | Select one or multiple interfaces from the drop-down list to view the interface packets statistics. See Maximum Displayable Interfaces for the maximum number of interfaces you can select. A warning message will appear if you attempt to select more than the maximum. |
TX | This line displays the transmission speed, in bytes per second, on the interface in the one-second interval before the screen updated. |
RX | This line displays the reception speed, in bytes per second, on the interface in the one-second interval before the screen updated. |
Label | Description |
View | Select how you want the established sessions that passed through the Zyxel Device to be displayed. Choices are: • sessions by user - display all active sessions grouped by user • sessions by services - display all active sessions grouped by service or protocol • sessions by source IP - display all active sessions grouped by source IP address • sessions by source region - display all active sessions grouped by source IP address • sessions by destination IP - display all active sessions grouped by destination IP address • sessions by destination region - display all active sessions grouped by destination IP address • all sessions - filter the active sessions by the User, Service, Source IP, and Destination IP, and display each session individually (sorted by user). |
Clear Session | Select a session, then click this button to remove the selected session. |
Clear All Sessions | Click this button to remove all sessions. |
Refresh | Click this button to update the information on the screen. The screen also refreshes automatically when you open and close the screen. |
Search | Type an item in the search box, then click this to display all sessions in the table below according to the item you typed. |
Clear All | Click this to remove all items found in the search. |
Filter | Click the Filter icon , click + to display Add Filter, pick a filter, then click Search to display specific sessions according to the filter selected. You may select multiple filters, but just one of each type, configured one at a time. |
The User, Service, Source Address, Destination Address, Source Country and Destination Country fields display if you view all sessions. | |
# | This field is the rank of each record. The names are sorted by the name of user in active session. You can use the pull down menu on the right to choose sorting method. |
User | This field displays the user in each active session. If you are looking at the sessions by users (or all sessions) report, click + or - to display or hide details about a user’s sessions. |
Services | This field displays the protocol used in each active session. If you are looking at the sessions by services report, click + or - to display or hide details about a protocol’s sessions. |
Source | This field displays the source IP address and port in each active session. If you are looking at the sessions by source IP report, click + or - to display or hide details about a source IP address’s sessions. |
Destination | This field displays the destination IP address and port in each active session. If you are looking at the sessions by destination IP report, click + or - to display or hide details about a destination IP address’s sessions. |
Rx | This field displays the amount of information received by the source in the active session. |
Tx | This field displays the amount of information transmitted by the source in the active session. |
Session Count | Select sessions by ... in the View field to group the sessions. This field displays the number of sessions. Click this number to view the details of each session. |
Duration | This field displays the length of the active session in hours, minutes, seconds format. |
BWM Rule | Hover over the BWM Rule icon for a session to see which BWM rule it is using. This field is displayed only when viewing the table of all sessions. To see it, select all sessions in the View field, or click the Session Count after selecting sessions by... in the View field. |
Top entry by | Use this field to have the following (read-only) table display the top content filter log entries by Blocked Category, Blocked Source IP, Blocked URL, Allowed Category, Allowed Source IP, or Allowed URL. This table displays the most common, recent content filter logs. See the log screen for less common content filter logs or use a syslog server to record all content filter logs. Select Blocked Category to list the web site categories the Zyxel Device has blocked. Select Blocked Source IP to list the source IP addresses of the web sites the Zyxel Device has blocked. Select Blocked URL to list the URLs of the web sites the Zyxel Device has blocked. Select Allowed Category to list the web site categories the Zyxel Device has allowed. Select Allowed Source IP to list the source IP addresses of the web sites the Zyxel Device has allowed. Select Allowed URL to list the URLs of the web sites the Zyxel Device has allowed. |
Flush Data | Click this button to discard all of the screen’s statistics. Click Refresh to update the report display. |
Time | This column displays the date and time when the users access the URL or FQDN. |
Action | This column displays whether the Zyxel Device blocks or passes the accessed URL or FQDN. |
URL/Domain | This column displays the URL or domain name of the web site accessed. |
Profile | This column displays the content filter profile the website belongs to. |
Category | This column displays the category the accessed web site belongs to. |
Source IP | This column displays the source IP address of the web site the Zyxel Device has checked. |
Destination IP | This column displays the destination IP address at which the traffic of the web site the Zyxel Device has checked is sent. |
Top Entries By | Use this field to have the following (read-only) table display the top IP reputation log entries by Category, Infected/Victim Host or Malicious IP. This table displays the most common, recent IP reputation logs. See the log screen for less common IP reputation logs or use a syslog server to record all IP reputation logs. Select Category to list the most common categories of packets that the Zyxel Device has detected. Select Infected/Victim Host to list the most common IP addresses of the infected hosts. Select Malicious IP to list the most common IPv4 addresses with bad reputation that have sent packets to the Zyxel Device. |
IP Reputation Events | |
Time | This field displays the date and time the entry was created. |
+ Allow List | Select an entry and click this to add it to the IP reputation allow list. |
Malicious IP | This field displays the IPv4 address with bad reputation. |
Infected/Victim Host | This field displays the IP address of the infected host. |
Threat Category | This field displays the category of the entry. |
Threat Level | This field displays the threat level of the entry. |
Occurrence | This field displays how many times the Zyxel Device has detected the event described in the entry. |
Top Entries By | Use this field to have the following (read-only) table display the top DNS threat filter log entries by Category, Source IP or DNS Name. This table displays the most common, recent DNS threat filter logs. See the log screen for less common DNS threat filter logs or use a syslog server to record all DNS threat filter logs. Select Category to list the most common categories of packets that the Zyxel Device has detected. Select Source IP to list the most common source IP addresses of traffic. Select DNS Name to list the most common FQDNs of the infected websites. |
DNS Threat Filter Events | |
+ Allow List | Select an entry and click this to add it to the DNS filtering allow list. |
DNS Name | This field displays the FQDN of an infected website. |
Source IP | This field displays the source IP address of traffic that you want to trace. |
Top Entries By | Use this field to have the following (read-only) table display the top URL threat filter log entries by Category, URL or Source IP. This table displays the most common, recent URL threat filter logs. See the log screen for less common URL threat filter logs or use a syslog server to record all URL threat filter logs. Select Category to list the most common categories of packets that the Zyxel Device has detected. Select URL to list the most common URLs of the infected websites. Select Source IP to list the most common source IP addresses of traffic. |
URL Threat Filter Events | |
+ Allow List | Select an entry and click this to add it to the URL Threat filtering allow list. |
URL | This field displays the URL of an infected website. |
Destination IP | This field displays the destination IP address of traffic. |
Top Entries By | Use this field to have the following (read-only) table display the top IPS log entries by Signature Name, Source IP or Destination IP. This table displays the most common, recent IPS logs. See the log screen for less common IPS logs or use a syslog server to record all IPS logs. Select Signature Name to list the most common signatures that the Zyxel Device has detected. Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most intrusion attempts. Select Destination IP to list the most common destination IP addresses for intrusion attempts that the Zyxel Device has detected. |
Time | This column displays the date and time IPS blocked this IP address. |
+ Allow List | Select an entry and click this to add the signature to the IPS allow list. |
Signature ID | This column displays when you display the unique value given to each intrusion detected. |
Signature Name | This column displays the name to identify the type of intrusion pattern. |
Type | This column displays the categories of intrusions. |
Severity | This column displays the level of threat that the intrusions may pose. |
Source IP | This column displays the source IP address of the intrusion attempts. |
Destination IP | This column displays the destination IP address at which intrusion attempts were targeted. |
Top Entries By | Use this field to have the following (read-only) table display the top anti-malware log entries by Virus Name, Source IP, and Destination IP. This table displays the most common, recent anti-malware logs. See the log screen for less common anti-malware logs or use a syslog server to record all anti-malware logs. Select Virus Name to list the most common viruses that the Zyxel Device has detected. Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most virus-infected files. Select Destination IP to list the most common destination IP addresses for virus-infected files that Zyxel Device has detected. |
Anti-Malware Statistics Events | |
Allow List | Select an entry and click this to add it to the anti-malware allow list. |
Virus name | This column displays when you display the entries by Virus Name. This displays the name of a detected virus. |
Hash | This column displays a hash value, SHA-256 (Secure Hash Algorithm) or MD5 (Message Digest 5) of the detected virus file. SHA-256 and MD5 are hash algorithms used to authenticate packet data. |
Source IP | This column displays when you display the entries by Source IP. It shows the source IP address of virus-infected files that the Zyxel Device has detected. |
Destination IP | This column displays when you display the entries by Destination IP. It shows the destination IP address of virus-infected files that the Zyxel Device has detected. |
Top Entries By | Use this field to have the following (read-only) table display the top sandbox log entries by Destination IP, Source IP and Type. This table displays the most common, recent sandbox logs. See the log screen for less common sandbox logs or use a syslog server to record all sandbox logs. Select Source IP to list the source IP addresses from which the Zyxel Device has detected the most files with unknown or untrusted programs and codes. Select Destination IP to list the most common destination IP addresses for files with unknown or untrusted programs and codes that Zyxel Device has detected. Select Type to display if the file type of the detected file with unknown or untrusted programs and codes. |
Flush Data | Click this button to discard all of the screen’s statistics. Click Refresh to update the report display. When the statistics stored reach the limit, new statistics automatically overwrite existing statistics, starting with the oldest statistics first. |
Sandbox Events | |
Time | This field displays the time the file is scanned by the Zyxel Device. |
Type | This field displays the file type of the detected file with unknown or untrusted programs and codes. |
File Name | This column displays the file name of the detected virus file. |
Hash | This column displays a hash value, MD5 (Message Digest 5, of the detected file with unknown or untrusted programs and codes. MD5 is a hash algorithm used to authenticate packet data. |
Source IP | This column displays the source IP address of the file the Zyxel Device has checked. |
Destination IP | This column displays the destination IP address at which the traffic of the file the Zyxel Device has checked is sent. |
General Settings | |
Status | |
Concurrent Sessions | This shows the actual number of simultaneous SSL Inspection sessions in progress. This number displays in red when you have reached the maximum number of simultaneous SSL Inspection sessions allowed for your Zyxel Device model. See the Product Features appendix in the User’s Guide to see the maximum allowed for each model. |
Summary | |
Total | This is the total of SSL sessions inspected and number of sessions blocked and number of sessions passed since data was last flushed or the Zyxel Device last rebooted after Collect Statistics was enabled. |
Inspected | This shows the total number of SSL sessions inspected since data was last flushed or the Zyxel Device last rebooted after Collect Statistics was enabled |
Decrypted (Kbytes) | This shows the number of kilobytes (KB) of data that was decrypted for Security Service inspection. |
Encrypted (Kbytes) | This shows the number of kilobytes (KB) of data that was re-encrypted after Security Service inspection and then forwarded. |
Blocked | This shows the number of SSL sessions blocked. |
Passed | This shows the number of SSL sessions passed. |
Time | This is the latest date (yyyy-mm-dd) and time (hh-mm-ss) that the record in the certificate cache list was met. |
Add to Exclude list | Select and item in the list and click this icon to add the common name (CN) to the Exclude List. |
Common Name | This displays the common name in the certificate of the SSL traffic destination server. |
Server Name Indication | Server Name Indication (SNI) is the domain name entered in the browser, FTP client, etc. to begin the SSL session with the server. It allows multiple SSL sessions to the same IP address and port number with different certificates from different SNI. This field displays the SNI for this SSL session. |
SSL Version | This field shows the SSL version. TLS1.0/1.1/1.2 are currently supported. |
Destination | This displays the IP address and port number of the SSL traffic destination server. |
Valid Time | This displays the cache item expiry time in seconds. The cache item is deleted when the remaining time expires. |
Refresh | Click this to update the information in this screen. |
Name | This field displays the name of each interface. |
Members | This field displays the physical port number that is binded to the interface. An interface is binded to a port when the interface is bounded to the physical port. When you create a bridge interface, the Zyxel Device removes the members' entries from the routing table and adds the bridge interface's entries to the routing table. This field displays the bridge interface's members. |
Type | This field displays the type of connection the interface is using. |
Status | This field displays the current status of each interface. The possible values depend on what type of interface it is. For Ethernet interfaces: • Inactive - The Ethernet interface is disabled. • Down - The Ethernet interface does not have any physical ports associated with it or the Ethernet interface is enabled but not connected. • Speed / Duplex - The Ethernet interface is enabled and connected. This field displays the port speed and duplex setting (Full or Half). For the auxiliary interface: • Inactive - The auxiliary interface is disabled. • Connected - The auxiliary interface is enabled and connected. • Disconnected - The auxiliary interface is not connected. For virtual interfaces, this field always displays Up. If the virtual interface is disabled, it does not appear in the list. For VLAN and bridge interfaces, this field always displays Up. If the VLAN or bridge interface is disabled, it does not appear in the list. For PPP interfaces: • Connected - The PPP interface is connected. • Disconnected - The PPP interface is not connected. If the PPP interface is disabled, it does not appear in the list. |
Zone | This field displays the zone to which the interface is assigned. |
IP Addr/Netmask | This field displays the current IP address and subnet mask assigned to the interface. If the IP address and subnet mask are 0.0.0.0, the interface is disabled or did not receive an IP address and subnet mask via DHCP. If this interface is a member of an active virtual router, this field displays the IP address it is currently using. This is either the static IP address of the interface (if it is the master) or the management IP address (if it is a backup). |
VLAN ID | This field displays the VLAN ID which is a 12-bit number that uniquely identifies each VLAN. |
IP Assignment | This field displays how the interface gets its IP address. • Static - This interface has a static IP address. • DHCP Client - This interface gets its IP address from a DHCP server. |
Service | This field lists which services the interface provides to the network. Examples include DHCP relay, DHCP server and DDNS. This field displays n/a if the interface does not provide any services to the network. |
Action | Use this field to get or to update the IP address for the interface. Click Renew to send a new DHCP request to a DHCP server. |
VPN Rule | This field displays the scenario rule the VPN tunnel interface is using. |
Edit | Double-click an entry or select it and click Edit to modify the entry’s settings in the Description field. |
Remove | Select an entry and click Remove to remove a client from the table that’s no longer connected to your network. For example, guest A visited your company over a month ago. Guest A used his cellphone to connect to your Zyxel Device networks. His cellphone was identified and shown in the Device Insight table. Guest A has left for over a month and you’re sure he will not return in the near future. You can use the Remove button to remove his device from this table. Guest A’s device will be identified and shown in the table again if he connects to your Zyxel Device networks in the future. Please note that clients that are blocked cannot be removed. Make sure to unblock clients before you remove them. |
Add to block list | Select an entry and click Add to block list to stop the selected client from connecting to the Zyxel Device. |
Remove from block list | Select an entry and click Remove from block list to allow the selected client to connect to the Zyxel Device. |
Feedback | Select an entry and click Feedback to report on a client that is wrongly identified regarding its Category, Operating System or Type. |
Status | This field displays the status of the clients. Online ( )- The connection between the client and the Zyxel Device is up.Offline ( )- The connection between the client and the Zyxel Device is down.Block ( )- The client is blocked from the connection to the Zyxel Device. |
MAC Address | This field displays the MAC address of the client. |
MAC Vendor | This displays the MAC address Organizationally Unique Identifier (OUI). The OUI is the first three octets in a MAC address and uniquely identifies the manufacturer of a network device. |
IP Address | This field displays the IP address of the client. |
Hostname | This field displays the name used to identify this device on the network. |
Description | This field displays the descriptive name of the client. |
Connected to | This field displays the interface to which a client is connected directly to on the Zyxel Device. |
Category | This field displays the device category of the client, such Switch, Router, Firewall, Computer, Gaming Console, IP Phone, IP Camera, Smart TV, Projector, Printer, Network Storage, Mobile Phone/Tablet, IoT, or Media Player. |
Operating System (OS) | This field displays the operating system of the client, such as Windows, iOS, macOS, Android, or Linux. |
OS Version | This field displays the version of the operating system of the client. |
Type | This field displays the model name of the client. |
First-seen | This field displays the time when the client first sends traffic to the Zyxel Device since the Zyxel Device last reboot. |
Last-seen | This field displays the time when the client last sends traffic to the Zyxel Device. |
User | This field displays the type of user account the client uses. See What You Need To Know for more information the user account types. |
Auth method | This field displays the authentication method that is used to authenticate the client. |
Astra Group & Role | This field displays the group name and role (admin or member) of the client on Astra. • admin: The Astra web portal is a platform that provides security services to computer or mobile devices. It is managed by an admin. • member: A member is a person whose computer or mobile device the admin wishes to protect using Astra. You can add your mobile device or a member’s mobile device using this Astra web portal account. |
Astra Agent Version | This field displays the version of Astra. |
Client Firewall Status | This field displays the firewall status on the client’s computer or mobile device, such as a smartphone. The field is blank is if there is no firewall on the client. • Enabled: The firewall is enabled on the client. • Disabled: The firewall is disabled on the client. |
Astra License Status | This field displays the current Astra license status of the client. The following displays for a license you subscribed to from the Astra Portal. • Activated: The Astra license is enabled. • Inactive: The Astra license is not enabled. • Overdue: The payment for the Astra license has failed, and the license will be canceled 15 days after the overdue date. During this period, attempts will be made to process the credit card payment. • Cancel: The Astra license will be canceled after the expiration date. • None: A standard or trial license has not been enabled. The following displays for a license you purchased offline. You’ll need to use the license key to activate the license online. • Activated: The Astra license is enabled. • Grace period: After a license expires, you have 15 days grace period during which you can extend your current license. • Expired: The Astra license has expired. • None: A standard or trial license has not been enabled. |
Endpoint Security Vendor | This field displays the security vendor currently used by the client. |
Force Logout | Select a user row and click this icon to end a user’s session. |
# | This field is a sequential value and is not associated with any entry. |
Auth Source | This field displays the authentication system that verified the logged in user, so as to identify where the user was authenticated for this session. • A user can log into the Zyxel Device's management interfaces (HTTP, HTTPS, SSH, FTP) using a local admin or viewer account (the account stored locally on the Zyxel Device). • A user can log into the network via Captive Portal or SSL VPN using an account authenticated by local, AD (Active Directory), LDAP, RADIUS, Nebula Cloud Authentication (cloud-auth), OIDC, or NID FS (nidfs). The name displayed for users who logged in using AD, LDAP, RADIUS or OIDC is the name configured for the AAA server in User & Authentication > User Authentication > AAA Server. The name displayed for users who logged in using Nebula Cloud Authentication is cloud-auth. You do not configure this name on the Zyxel Device. The name displayed here for users who logged in using NID FS is nidfs. The actual NID FS name is the IdP (Identity Provider) name taken from the ID token claim and is different for each user. You do not configure this name on the Zyxel Device. |
User ID | This field displays the user name of each user who is currently logged in to the Zyxel Device. |
Role | This field displays the types of user accounts the Zyxel Device uses. See User/Group User Summary Screen for more information on the user accounts. |
From | This field displays the IP address of the computer used to log in to the Zyxel Device. |
Login Time | This field displays how long a user account has logged into the Zyxel Device. |
Type | This field displays the way the user logged into the Zyxel Device. The user can log into the Zyxel Device using HTTP, HTTPS, SSH, FTP and console. |
Tunnel IP | This field displays the IP address of the VPN tunnel a user account is using to access the Zyxel Device. This field displays 0.0.0.0 if a user account is not accessing the Zyxel Device through a VPN tunnel. |
Reauth/Lease Time | This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each user. See User Add/Edit Screen for more information on the reauthentication time and lease time. |
Unlock | Select an IP address and click Unlock to allow the user from that IP address to log into the Zyxel Device. |
# | This field is a sequential value and is associated with the lockout IP address entries. |
IP | This displays the IP address that exceeded the login attempt limit. |
Type | This displays the reason the IP address is locked. • Lockout: Failed logins from the IP address reach the specified limit. • Authentication Rate Limiting: Logins and login attempts from the IP address reach the specified limit. |
Last User ID | This displays the last user name attempted from this IP address. |
Role | This displays the type of user account that attempted to log into the Zyxel Device, such as: • Admin: This user can configure the Zyxel Device settings using the web configurator or CLI. • Viewer: This user can only view the Zyxel Device settings using the web configurator and perform basic diagnostics for troubleshooting using the command line interface (CLI). • User: This user has access to the Zyxel Device’s services, such as VPN, and can also browse. This user cannot configure or view the Zyxel Device settings using the web configurator or CLI. • External User: This user account is maintained on a remote server, such as RADIUS or LDAP. This user has access to the Zyxel Device’s services, such as VPN, and can also browse but cannot configure or view the Zyxel Device settings using the web configurator or CLI. |
Lockout Time | This displays the remaining time before the IP address is unlocked. This timer restarts if further attempts occur during the lockout period. |
Current DHCP List | |
Interface | Select a Zyxel Device interface that has DHCP enabled to show to which devices it has assigned DHCP IP addresses. |
Add | Click this to add an entry that maps a static IP to a MAC address. • A host name cannot exceed 255 characters. Valid characters are [0-9][a-z][A-Z][-]. You can use duplicate host names, but they cannot start with a space or hyphen. • You must use a valid IPv4 address that is in the DHCP pool. • The MAC address must be formatted with colons or hyphens as shown in the screen. ![]() |
Release | Select an entry and click on this button to let other devices use the dynamic DHCP that is currently assigned to the selected entry. |
Reserved | Select an entry and click on this button to make the entry a static DHCP entry, meaning the DHCP client is always assigned the same IP address from the DHCP server. |
Unreserve | Select an entry and click on this button to change the entry from a static DHCP entry to a dynamic DHCP entry, meaning the DHCP client may get a different IP address from the DHCP server when the IP address is renewed. |
Import | A reserved DHCP IP address is an IP address sent from a DHCP server that is aways assigned to the same MAC address. This ensures that the DHCP client always receives the same IP address. This allows you to manage DHCP clients centrally without having to configure static IP addresses on each DHCP client. First create a list of reserved DHCP IP address in a file in CSV (comma separated values) format. Download the sample file (StaticDHCP_samplefile.csv) and follow that format exactly. • The file size must be less than 1MB. • The first row must have the column titles exactly as shown in the sample file: Interface, IP Address, Host Name, MAC Address, Description, Status. • The Host Name must be as follows. The first character must be a digit (0–9), or a lowercase letter (a–z), or an uppercase letter (A–Z). Hyphens are not allowed as the first character. After the first character, you may have 0 to 254 more characters. Allowed characters in this part are digits (0–9), lowercase letters (a–z), uppercase letters (A–Z), hyphen (-). The minimum length is 1 character and the maximum length is 255 characters (1 + 254). Valid Examples are a, Z1, abc-123, A0-xyz-9. Invalid Examples are -abc (starts with a hyphen), abc! (contains !), ab@cd (contains @). • The Host Name does not need to be unique for each subnet. • Host Names of static DHCP clients cannot be empty. • If the Host Name of a reserved DHCP client is empty, the Zyxel Device will replace the hostname with the MAC address of the DHCP client. It will use uppercase letters (for hex A to E), and separate octet pairs with hyphens. • Use the standard format for IP Address and MAC Address. • The reserved IP addresses must be in the same subnet as the associated interface in the CSV file and the DHCP server. For example, if you have a DHCP server with IP address 192.168.170.200 on the ge3 interface, then please note the following for entries in the CSV file. ge3 192.168.168.33 aa:aa:aa:aa:aa:aa -> this won’t be imported as the IP address is not in the DHCP server subnet. ge4 192.168.170.33 aa:aa:aa:aa:aa:ab -> this won’t be imported as the interface is wrong ge3 192.168.170.33 aa:aa:aa:aa:aa:ac -> this will be imported • If you use an external DHCP server, by default the DHCP server must have an IP address in the same subnet as the IP address of the Interface on the Zyxel Device. Use the command usgflex500h running config# vrf main dhcp server subnet if you want to change the IP address of the DHCP server to be in a different subnet to that of the Zyxel Device interface. For example, you can bind the above DHCP server to the g4 interface with IP subnet 192.168.168.1/24. • Status must always be Reserved. After you have created the file, click this button to import the file into the Zyxel Device so that the DHCP server can assign these IP addresses to the associated MAC addresses in the list. If an import fails, please check the points above or check dhcp-import-failed.log in Maintenance > Diagnostics. |
Export | Click this button to download all entries in the DHCP table to your computer in csv format with file name containing the current date. |
Refresh | Click this button to update the mapping between IP addresses and MAC addresses. |
Column header | Click a column’s heading cell to sort the table entries by the column entry. Click the heading cell again to reverse the sort order. |
Interface | This field identifies the interface that assigned an IP address to a DHCP client. |
IP Address | This field displays the IP address currently assigned to a DHCP client or reserved for a specific MAC address. Click the column’s heading cell to sort the table entries by IP address. Click the heading cell again to reverse the sort order. |
Host Name | This field displays the name used to identify this device on the network (the computer name). The Zyxel Device learns these from the DHCP client requests. • The Zyxel Device supports the display of host names in languages other than English. • If the DHCP client does not have a hostname, the Zyxel Device uses its MAC address (in uppercase). • None shows here for a static DHCP entry. |
MAC Address | This field displays the MAC address to which the IP address is currently assigned or for which the IP address is reserved. The MAC address format can be "xx:xx:xx:xx:xx:xx" or "xx-xx-xx-xx-xx-xx" |
VLAN ID | This field displays the VLAN to which the IP address belongs, if any. |
Expire Time | This displays the date and time the DHCP-assigned address will be renewed. |
Description | This field displays a description of the DHCP client to identify it. The description cannot exceed 64 characters. Valid characters are [0-9][a-z][A-Z][_ -]. |
Status | This field displays the connection status of the DHCP client. Reserved means a static DHCP entry. - means a dynamic DHCP entry. |
Disconnect | Select an IPSec policy and click this button to disconnect it. |
Refresh | Select an IPSec policy and click this button to update its status. |
Connectivity Check | Select an IPSec policy and click this button to check the connection to a remote client through this VPN tunnel. Enter an IP address in the remote policy subnet range. The Zyxel Device interface must comply with the local policy subnet range. The check will time out after 5 seconds if there is no reply to the ICMP check (Ping). ![]() |
# | This field is a sequential value, and it is not associated with a specific SA. |
Name | This field only displays the client names if they’re using EAP or X-auth for authentication. If a client is connected to the Zyxel Device without using Extended Authentication Protocol (EAP) or X-Auth, this field will be empty. |
Remote Gateway | This field displays the IP address of the remote gateway. |
Remote ID | This field displays the ID of the remote gateway. |
My Address | This field displays the IP address of the Zyxel Device. |
Policy Route | This field displays the content of the local and remote policies for this IPSec policy. The IP addresses, not the address objects, are displayed. |
Uptime | This field displays how many seconds the IPSec policy has been active. This field displays N/A if the IPSec policy uses manual keys. |
Rekey | This field displays how many seconds remain in the SA life time, before the Zyxel Device automatically disconnects the IPSec policy. This field displays N/A if the IPSec policy uses manual keys. |
Inbound (Bytes) | This field displays the amount of traffic that has gone through the IPSec policy from the remote IPSec router to the Zyxel Device since the IPSec policy was established. |
Outbound (Bytes) | This field displays the amount of traffic that has gone through the IPSec policy from the Zyxel Device to the remote IPSec router since the IPSec policy was established. |
Total (Bytes) | This field displays the total traffic that has passed through the IPSec policy (Inbound + Outbound) since the IPSec policy was established. |
Usage (%) | This field displays the percentage of usage for this IPSec policy among all IPSec policies. |
Total Usage for All Tunnels | This displays the total usage of all IPSec policies, including both inbound and outbound usage. |
Disconnect | Select a remote access VPN client and click this button to disconnect it. |
Refresh | Click Refresh to update this screen. |
# | This field is a sequential value, and it is not associated with a specific remote access VPN client. |
Username | This field displays the name of the remote access VPN client. |
Assigned IP | This field displays the IP address the user used to establish this remote access VPN connection. |
Remote IP | This field displays the IP address of the remote IPSec router the remote access VPN client is connected to. |
Up Time | This field displays how many seconds the remote access VPN client has been active. This field displays N/A if the remote access VPN client uses manual keys. |
Reauth/Lease Time | This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each remote access VPN client. |
Inbound (Bytes) | This field displays the number of bytes received by the Zyxel Device on this connection. |
Outbound (Bytes) | This field displays the number of bytes transmitted by the Zyxel Device on this connection. |
Disconnect | Select a connection and click this button to terminate the user’s connection and delete corresponding session information from the Zyxel Device. |
# | This field is a sequential value, and it is not associated with a specific SSL. |
Username | This field displays the account user name used to establish this SSL VPN connection. |
Assigned IP | This field displays the IP address the user used to establish this SSL VPN connection. |
Remote IP | This field displays the remote SSL VPN router the SSL VPN is connected to. |
Up Time | This field displays how many seconds the SSL VPN client has been active. This field displays N/A if the SSL VPN client uses manual keys. |
Reauth/Lease Time | This field displays the amount of reauthentication time remaining and the amount of lease time remaining for each SSL VPN client. |
# | This field is a sequential value, and it is not associated with a specific VPN connection. |
Machine Name | This field displays the domain name of the Tailscale server. |
Tailscale IP | This field displays the IP address assigned to the Zyxel Device by the Tailscale server. |
Owner | The Tailscale account name that establishes the VPN connection. |
Status | This displays the status of the VPN connection. • active: The VPN connection is established and data is being transmitted. • idle: The VPN connection is established and ready to be used, but no data is being transmitted. • offline: The Zyxel Device is currently not connected to the Tailscale network. • -: No data has ever been sent to or received from the Zyxel Device. |
Inbound (Bytes) | This field displays the number of bytes received by the Zyxel Device on this VPN connection. |
Outbound (Bytes) | This field displays the number of bytes transmitted by the Zyxel Device on this VPN connection. |
Disconnect | Select a remote AP and click Disconnect to disconnect it from the Zyxel Device. |
RAP Description | This field displays the name configured for the remote AP in Wireless > Access Points > AP List > Edit. |
Assigned IP | This field displays the IP address that the remote AP uses within the IPSec VPN tunnel after the tunnel connection is established. |
Remote IP | This field displays the IP address that the Zyxel Device assigns to the remote AP. The remote AP uses this IP address to establish the IPSec VPN tunnel with the Zyxel Device. |
Up Time | This field displays how long the remote AP has been connected to the Zyxel Device. |
Reauth/Lease Time | This field displays the amount of reauthentication time remaining and the amount of lease time remaining for the remote AP. Reauth Time: How often the remote AP has to reauthenticate with the Zyxel Device. The default time is 28800 seconds. Lease Time: How long the remote AP can maintain the connection with the Zyxel Device. The countdown is reset after a successful authentication. |
Model | Last X Day(s) |
USG FLEX 50H | 1 |
USG FLEX 50HP | 1 |
USG FLEX 100H | 1 |
USG FLEX 100HP | 1 |
USG FLEX 200H | 2 |
USG FLEX 200HP | 2 |
USG FLEX 500H | 8 |
USG FLEX 700H | 8 |
Date | Select a date to view the preceding 24 hours of data, or select Last X Days to view data for the preceding supported days. |
Ranking | Select the top five or top ten managed APs by traffic usage or number of connected stations to sort data for display. |
AP Radio | If you view data by usage, select the frequency band to display on the graph. |
Refresh | The displayed data is updated hourly. Click Refresh to get the latest data for the current hour. |
Traffic Usage | This graph displays the wireless traffic transmitted to and from the managed APs over time or by date. |
Total | This shows the total traffic used by all managed APs on the selected date or over the selected date range. |
y-axis | This represents the amount of traffic in MB (megabytes), GB (gigabytes), TB (terabytes), or PB (petabytes). |
x-axis | This represents the time or date. |
Station Count | This graph displays the number of wireless stations connected to the managed APs over time or by date. |
y-axis | This represents the number of connected wireless stations. |
Date | Select a date to view the preceding 24 hours of data, or select Last X days to view data for the preceding supported days. |
AP | Select a managed AP to view its wireless data. |
Traffic Usage | This graph displays the traffic usage of the managed AP over time or by date. |
Total | This shows the total traffic used by the managed AP on the selected date or over the selected date range. |
x-axis | TThis represents the time or date. |
Station Count | This graph displays the number of wireless stations connected to the managed AP over time or by date. |
Ranking | Select the top five or top ten wireless clients by traffic usage to sort data for display. |
Traffic Usage | This graph displays the wireless traffic transmitted to and from the wireless clients over time or by date. |
Total | This shows the total traffic used by all wireless clients on the selected date or over the selected date range. |
Station | Select a wireless client to view its wireless data. |
Traffic Usage | This graph displays the wireless traffic transmitted to and from the wireless client over time or by date. |
Total | This shows the total traffic used by the wireless client on the selected date or over the selected date range. |
