IPS
Overview
An IPS system can detect malicious or suspicious packets and respond instantaneously. IPS on the Zyxel Device protects against network-based intrusions.
Use the Security Service > IPS screen (The IPS Screen) to view registration and signature information.
Use the Security Service > IPS > Custom Signature > Add screens (IPS Custom Signatures) to create a new custom signature, edit an existing signature, delete existing signatures or save signatures to your computer.
Use the Security Service > IPS > Allow List screen (The Allow List Screen) to list signatures that will be exempted from IPS inspection.
What You Need To Know
Packet Inspection Signatures
A signature is a pattern of malicious or suspicious packet activity. You can specify an action to be taken if the system matches a stream of data to a malicious signature. You can change the action in the profile screens. Packet inspection examine OSI (Open System Interconnection) layer-4 to layer-7 packet contents for malicious data. Generally, packet inspection signatures are created for known attacks while anomaly detection looks for abnormal behavior.
Rate Based Signatures
Rate based signatures are IPS signatures that allow the Zyxel Device to just respond when a certain number of malicious packets are identified within a specific time, by the IPS signatures specified in the Rate Based Signature table.
Applying Your IPS Configuration
Changes to the Zyxel Device’s IPS settings affect new sessions, but not the sessions that already existed before you applied the new settings.
Before You Begin
Register for a trial IPS subscription in the Registration screen. This gives you access to free signature updates. This is important as new signatures are created as new attacks evolve. When the trial subscription expires, purchase and enter a license key using the same screens to continue the subscription.
The IPS Screen
An IPS profile is a set of packet inspection signatures.
Use this screen to view registration and signature information.
*You must register in order to update packet inspection signatures. See the Registration screens.
If you try to enable IPS when the IPS service has not yet been registered, a warning screen displays and IPS is not enabled.
Click the IPS icon for more information on the Zyxel Device’s security features.
The following table describes the fields in this screen.
Configuration > Security Service > IPS
label
Description
General Settings
Enable
Select this checkbox to activate the IPS feature which detects and prevents malicious or suspicious packets and responds instantaneously.
Scan Mode
Prevention
Select this to have the Zyxel Device perform a user-specified action when a stream of data matches a malicious signature.
Detection
Select this to have the Zyxel Device only create a log message when a stream of data matches a malicious signature.
Query Signatures
Name
Type the name or part of the name of the signature(s) you want to find.
Signature ID
Type the ID or part of the ID of the signature(s) you want to find.
Search all custom signatures
Select this checkbox to include signatures you created or imported in the Custom Signatures screen in the search. You can search for specific signatures by name or ID. If the name and ID fields are left blank, then all signatures are searched according to the criteria you select.
Severity
Search for signatures by severity level(s). Hold down the [Ctrl] key if you want to make multiple selections.
These are the severities as defined in the Zyxel Device. The number in brackets is the number you use if using commands.
Severe (5): These denote attacks that try to run arbitrary code or gain system privileges.
High (4): These denote known serious vulnerabilities or attacks that are probably not false alarms.
Medium (3): These denote medium threats, access control attacks or attacks that could be false alarms.
Low (2): These denote mild threats or attacks that could be false alarms.
Very-Low (1): These denote possible attacks caused by traffic such as Ping, trace route, ICMP queries etc.
Classification Type
Search for signatures by attack type(s). Attack types are known as policy types in the group view screen. Hold down the [Ctrl] key if you want to make multiple selections.
Platform
Search for signatures created to prevent intrusions targeting specific operating system(s). Hold down the [Ctrl] key if you want to make multiple selections.
Service
Search for signatures by IPS service group(s). Hold down the [Ctrl] key if you want to make multiple selections.
Action
Search for signatures by the response the Zyxel Device takes when a packet matches a signature.Hold down the [Ctrl] key if you want to make multiple selections.
Activation
Search for activated and/or inactivated signatures here.
Log
Search for signatures by log option here.
Query Result
The results are displayed in a table showing the SID, Name, Severity, Classification Type, Platform, Service, Log, and Action criteria as selected in the search. Click the SID column header to sort search results by signature ID.
Custom Signature Rules
Use this part of the screen to create, edit, delete or export (save to your computer) custom signatures.
Add
Click this to create a new entry.
Edit
Select an entry and click this to be able to modify it.
Remove
Select an entry and click this to delete it.
Export
To save an entry or entries as a file on your computer, select them and click Export. Click Save in the file download dialog box and then select a location and name for the file.
Custom signatures must end with the ‘rules’ file name extension, for example, MySig.rules.
This is the entry’s index number in the list.
SID
SID is the signature ID that uniquely identifies a signature. Click the SID header to sort signatures in ascending or descending order. It is automatically created when you click the Add icon to create a new signature. You can edit the ID, but it cannot already exist and it must be in the 9000000 to 9999999 range.
Name
This is the name of your custom signature. Duplicate names can exist, but it is advisable to use unique signature names that give some hint as to intent of the signature and the type of attack it is supposed to prevent.
Customer Signature Rule Importing
Use this part of the screen to import custom signatures (previously saved to your computer) to the Zyxel Device.
*The name of the complete custom signature file on the Zyxel Device is ‘custom.rules’. If you import a file named ‘custom.rules’, then all custom signatures on the Zyxel Device are overwritten with the new file. If this is not your intention, make sure that the files you import are not named ‘custom.rules’.
File Path
Type the file path and name of the custom signature file you want to import in the text box (or click Browse to find it on your computer) and then click Importing to transfer the file to the Zyxel Device.
New signatures then display in the Zyxel Device IPS > Custom Signatures screen.
IPS signatures identify traffic packets with suspicious malicious patterns. The Zyxel Devicecan then respond instantaneously according to the action you define.
If you do not want the Zyxel Device to respond instantaneously for each suspicious packet detected, use rate based signatures. See What You Need To Know for more information on rate based signatures.
Activate
To turn on an entry, select it and click Activate.
Inactivate
To turn off an entry, select it and click Inactivate.
Log
To edit an item’s log option, select it and use the Log icon. Select whether to have the Zyxel Device generate a log (log), log and alert (log alert) or neither (no) when a packet matches a signature.
Action
To edit what action the Zyxel Device takes when a packet matches a signature, select the entry and use the Action icon.
none: Select this action to have the Zyxel Device take no action when a packet matches a signature.
drop: Select this action to have the Zyxel Device silently drop a packet that matches a signature. Neither sender nor receiver are notified.
reject-sender: Select this action to have the Zyxel Device send a reset to the sender when a packet matches the signature. If it is a TCP attack packet, the Zyxel Device will send a packet with a ‘RST’ flag. If it is an ICMP or UDP attack packet, the Zyxel Device will send an ICMP unreachable packet.
reject-receiver: Select this action to have the Zyxel Device send a reset to the receiver when a packet matches the signature. If it is a TCP attack packet, the Zyxel Device will send a packet with an a ‘RST’ flag. If it is an ICMP or UDP attack packet, the Zyxel Device will do nothing.
reject-both: Select this action to have the Zyxel Device send a reset to both the sender and receiver when a packet matches the signature. If it is a TCP attack packet, the Zyxel Device will send a packet with a ‘RST’ flag to the receiver and sender. If it is an ICMP or UDP attack packet, the Zyxel Device will send an ICMP unreachable packet.
Status
The activate (light bulb) icon is lit when the entry is active and dimmed when the entry is inactive.
SID
Name
This is the name of your rate-based signature. The name is the type of attack the Zyxel Device can identify.
Severity
This field displays signatures by severity level(s). Hold down the [Ctrl] key if you want to make multiple selections.
Classification
This field displays signatures by attack type(s). Attack types are known as policy types in the group view screen. Hold down the [Ctrl] key if you want to make multiple selections.
Platform
This field displays signatures created to prevent intrusions targeting specific operating system(s). Hold down the [Ctrl] key if you want to make multiple selections.
Service
This field displays signatures by IPS service group(s). Hold down the [Ctrl] key if you want to make multiple selections.
Period (1-120)
Type the length of time in seconds the event should occur from a client the Count number of times to trigger an IPS Action.
For example, Count is set to 5, and Period is set to 60. If the Zyxel Device detects more than 5 occurrences of malicious traffic in less than 60 seconds, then IPS Action is triggered.
Count (1-300)
Type the number of security events that need to occur within the defined Period to trigger an IPS Action.
Block Period (0-86400)
This field displays the time period the attacker’s IP will be blocked.
Click on the number in this column to set the value from 0 to 86400 seconds. 0 means that the IP will not be blocked.
Log
This fields displays the log action the Zyxel Device takes when a packet matches a signature.
log- The Zyxel Device generates a log.
log an alert- The Zyxel Device generates a log and alerts the users.
no- The Zyxel Device will neither generate a log nor alert the users.
Action
This field displays the response the Zyxel Device takes when a packet matches a signature. Hold down the [Ctrl] key if you want to make multiple selections.
Signature Information
The following fields display information on the current signature set that the Zyxel Device is using.
Current Version
This field displays the IPS signature set version number. This number gets larger as the set is enhanced.
Signature Number
This field displays the number of IPS signatures in this set. This number usually gets larger as the set is enhanced. Older signatures and rules may be removed if they are no longer applicable or have been supplanted by newer ones.
Released Date
This field displays the date and time the set was released.
Update Signatures
Click this link to go to the screen you can use to download signatures from the update server.
Apply
Reset
Click Reset to return the screen to its last-saved settings.
Policy Types
This table describes Policy Types as categorized in the Zyxel Device.
Policy Types
Policy Type
Description
Access Control
Access control refers to procedures and controls that limit or detect access. Access control attacks try to bypass validation checks in order to access network resources such as servers, directories, and files.
Any
Any attack includes all other kinds of attacks that are not specified in the policy such as password, spoof, hijack, phishing, and close-in.
Backdoor/Trojan Horse
A backdoor (also called a trapdoor) is hidden software or a hardware mechanism that can be triggered to gain access to a program, online service or an entire computer system. A Trojan horse is a harmful program that is hidden inside apparently harmless programs or data.
Although a virus, a worm and a Trojan are different types of attacks, they can be blended into one attack. For example, W32/Blaster and W32/Sasser are blended attacks that feature a combination of a worm and a Trojan.
BotNet
A Botnet is a number of Internet computers that have been set up to forward transmissions including spam or viruses to other computers on the Internet though their owners are unaware of it. It is also a collection of Internet-connected programs communicating with other similar programs in order to perform tasks and participate in distributed Denial-Of-Service attacks.
Buffer Overflow
A buffer overflow occurs when a program or process tries to store more data in a buffer (temporary data storage area) than it was intended to hold. The excess information can overflow into adjacent buffers, corrupting or overwriting the valid data held in them.
Intruders could run codes in the overflow buffer region to obtain control of the system, install a backdoor or use the victim to launch attacks on other devices.
DoS/DDoS
The goal of Denial of Service (DoS) attacks is not to steal information, but to disable a device or network on the Internet.
A Distributed Denial of Service (DDoS) attack is one in which multiple compromised systems attack a single target, thereby causing denial of service for users of the targeted system.
Instant Messenger
IM (Instant Messenger) refers to chat applications. Chat is real-time, text-based communication between two or more users through networks-connected computers. After you enter a chat (or chat room), any room member can type a message that will appear on the monitors of all the other participants.
Mail
A Mail or email bombing attack involves sending several thousand identical messages to an electronic mailbox in order to overflow it, making it unusable.
Misc
Miscellaneous attacks takes advantage of vulnerable computer networks and web servers by forcing cache servers or web browsers into disclosing user-specific information that might be sensitive and confidential. The most common type of Misc. attacks are HTTP Response Smuggling, HTTP Response Splitting and JSON Hijacking.
P2P
Peer-to-peer (P2P) is where computing devices link directly to each other and can directly initiate communication with each other; they do not need an intermediary. A device can be both the client and the server. In the Zyxel Device, P2P refers to peer-to-peer applications such as e-Mule, e-Donkey, BitTorrent, iMesh, etc.
Scan
A scan describes the action of searching a network for an exposed service. An attack may then occur once a vulnerability has been found. Scans occur on several network levels.
A network scan occurs at layer-3. For example, an attacker looks for network devices such as a router or server running in an IP network.
A scan on a protocol is commonly referred to as a layer-4 scan. For example, once an attacker has found a live end system, he looks for open ports.
A scan on a service is commonly referred to a layer-7 scan. For example, once an attacker has found an open port, say port 80 on a server, he determines that it is a HTTP service run by some web server application. He then uses a web vulnerability scanner (for example, Nikto) to look for documented vulnerabilities.
SPAM
Spam is unsolicited “junk” email sent to large numbers of people to promote products or services.
Stream Media
A Stream Media attack occurs when a malicious network node downloads an overwhelming amount of media stream data that could potentially exhaust the entire system. This method allows users to send small requests messages that result in the streaming of large media objects, providing an opportunity for malicious users to exhaust resources in the system with little effort expended on their part.
Tunnel
A Tunneling attack involves sending IPv6 traffic over IPv4, slipping viruses, worms and spyware through the network using secret tunnels. This method infiltrates standard security measures through IPv6 tunnels, passing through IPv4 undetected. An external signal then triggers the malware to spring to life and wreak havoc from inside the network.
Virus/Worm
A computer virus is a small program designed to corrupt and/or alter the operation of other legitimate programs. A worm is a program that is designed to copy itself from one computer to another on a network. A worm’s uncontrolled replication consumes system resources, thus slowing or stopping other tasks.
Web Attack
Web attacks refer to attacks on web servers such as IIS (Internet Information Services).
IPS Service Groups
An IPS service group is a set of related packet inspection signatures.
IPS Service Groups
WEB_PHP
WEB_MISC
WEB_IIS
WEB_FRONTPAGE
WEB_CGI
WEB_ATTACKS
TFTP
TELNET
SQL
SNMP
SMTP
RSERVICES
RPC
POP3
POP2
P2P
ORACLE
NNTP
NETBIOS
MYSQL
MISC_EXPLOIT
MISC_DDOS
MISC_BACKDOOR
MISC
IMAP
IM
ICMP
FTP
FINGER
DNS
n/a
Create custom signatures for new attacks or attacks peculiar to your network. Custom signatures can also be saved to/from your computer so as to share with others.
You need some knowledge of packet headers and attack types to create your own custom signatures.
IP Packet Header
These are the fields in an Internet Protocol (IP) version 4 packet header.
IP v4 Packet Headers
Header
Description
Version
The value 4 indicates IP version 4.
IHL
IP Header Length is the number of 32 bit words forming the total length of the header (usually five).
Type of Service
The Type of Service, (also known as Differentiated Services Code Point (DSCP)) is usually set to 0, but may indicate particular quality of service needs from the network.
Total Length
This is the size of the datagram in bytes. It is the combined length of the header and the data.
Identification
This is a 16-bit number, which together with the source address, uniquely identifies this packet. It is used during reassembly of fragmented datagrams.
Flags
Flags are used to control whether routers are allowed to fragment a packet and to indicate the parts of a packet to the receiver.
Fragment Offset
This is a byte count from the start of the original sent packet.
Time To Live
This is a counter that decrements every time it passes through a router. When it reaches zero, the datagram is discarded. It is used to prevent accidental routing loops.
Protocol
The protocol indicates the type of transport packet being carried, for example, 1 = ICMP; 2= IGMP; 6 = TCP; 17= UDP.
Header Checksum
This is used to detect processing errors introduced into the packet inside a router or bridge where the packet is not protected by a link layer cyclic redundancy check. Packets with an invalid checksum are discarded by all nodes in an IP network.
Source IP Address
This is the IP address of the original sender of the packet.
Destination IP Address
This is the IP address of the final destination of the packet.
IP options is a variable-length list of IP options for a datagram that define IP Security Option, IP Stream Identifier, (security and handling restrictions for the military), Record Route (have each router record its IP address), Loose Source Routing (specifies a list of IP addresses that must be traversed by the datagram), Strict Source Routing (specifies a list of IP addresses that must ONLY be traversed by the datagram), Timestamp (have each router record its IP address and time), End of IP List and No IP Options.
Padding
Padding is used as a filler to ensure that the IP packet is a multiple of 32 bits.
The Custom Signature Rules section shows a summary of all custom signatures created. Click the SID or Name heading to sort. Click the Add icon to create a new signature or click the Edit icon to edit an existing signature. You can also delete custom signatures here or save them to your computer.
*The Zyxel Device checks all signatures and continues searching even after a match is found. If two or more rules have conflicting actions for the same packet, then the Zyxel Device applies the more restrictive action (reject-both, reject-receiver or reject-sender, drop, none in this order). If a packet matches a rule for reject-receiver and it also matches a rule for reject-sender, then the Zyxel Device will reject-both.
Add / Edit Custom Signatures
A packet must match all items you configure in this screen before it matches the signature. The more specific your signature (including packet contents), then the fewer false positives the signature will trigger.
Try to write signatures that target a vulnerability, for example a certain type of traffic on certain operating systems, instead of a specific exploit.
Configuration > Security Service > IPS > Custom Signatures > Add/Edit
LABEL
Description
Name
Type the name of this custom signature. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive.
Duplicate names can exist but it is advisable to use unique signature names that give some hint as to intent of the signature and the type of attack it is supposed to prevent. Refer to (but do not copy) the packet inspection signature names for hints on creating a naming convention.
Signature ID
A signature ID is automatically created when you click the Add icon to create a new signature. You can edit the ID to create a new one (in the 9000000 to 9999999 range), but you cannot use one that already exists. You may want to do that if you want to order custom signatures by SID.
Information
Use the following fields to set general information about the signature as denoted below.
Severity
The severity level denotes how serious the intrusion is. Categorize the seriousness of the intrusion here.
Platform
Some intrusions target specific operating systems only. Select the operating systems that the intrusion targets, that is, the operating systems you want to protect from this intrusion. SGI refers to Silicon Graphics Incorporated, who manufactures multi-user Unix workstations that run the IRIX operating system (SGI's version of UNIX). A router is an example of a network device.
Classification Type
Categorize the attack type here.
Frequency
Recurring packets of the same type may indicate an attack. Use the following field to indicate how many packets per how many seconds constitute an intrusion
Threshold
Select Threshold and then type how many packets (that meet the criteria in this signature) per how many seconds constitute an intrusion.
Header Options
Network Protocol
Configure signatures for IP version 4.
Type Of Service
Type of service in an IP header is used to specify levels of speed and/or reliability. Some intrusions use an invalid Type Of Service number. Select the checkbox, then select Equal or Not-Equal and then type in a number.
Identification
The identification field in a datagram uniquely identifies the datagram. If a datagram is fragmented, it contains a value that identifies the datagram to which the fragment belongs. Some intrusions use an invalid Identification number. Select the checkbox and then type in the invalid number that the intrusion uses.
Fragmentation
A fragmentation flag identifies whether the IP datagram should be fragmented, not fragmented or is a reserved bit. Some intrusions can be identified by this flag. Select the checkbox and then select the flag that the intrusion uses.
Fragment Offset
When an IP datagram is fragmented, it is reassembled at the final destination. The fragmentation offset identifies where the fragment belongs in a set of fragments. Some intrusions use an invalid Fragment Offset number. Select the checkbox, select Equal, Smaller or Greater and then type in a number
Time to Live
Time to Live is a counter that decrements every time it passes through a router. When it reaches zero, the datagram is discarded. Usually it’s used to set an upper limit on the number of routers a datagram can pass through. Some intrusions can be identified by the number in this field. Select the checkbox, select Equal, Smaller or Greater and then type in a number.
IP Options
IP options is a variable-length list of IP options for a datagram that define IP Security Option, IP Stream Identifier, (security and handling restrictions for the military), Record Route (have each router record its IP address), Loose Source Routing (specifies a list of IP addresses that must be traversed by the datagram), Strict Source Routing (specifies a list of IP addresses that must ONLY be traversed by the datagram), Timestamp (have each router record its IP address and time), End of IP List and No IP Options. IP Options can help identify some intrusions. Select the checkbox, then select an item from the list box that the intrusion uses
Same IP
Select the checkbox for the signature to check for packets that have the same source and destination IP addresses.
Transport Protocol
The following fields vary depending on whether you choose TCP, UDP or ICMP.
Transport Protocol: TCP
Port
Select the checkbox and then enter the source and destination TCP port numbers that will trigger this signature.
Flow
The selected keyword sets the criteria as to which traffic is matched. You can match traffic based on direction or whether the connection is established or not. You can also specify whether you want to match signatures per packet or in a stream of packets.
Established: Match established connections.
Stateless: Match packets that are not part of an established connection.
To Client: Match packets that flow from server to client.
To Server: Match packets that flow from client to server.
From Client: Match packets that flow from client to server.
From Servers: Match packets that flow from server to client.
No Stream: Match packets that have not been reassembled by the stream engine. It will not match packets that have been reassembled.
Only Stream: Match packets that have been reassembled.
Flags
Select what TCP flag bits the signature should check.
Sequence Number
Use this field to check for a specific TCP sequence number.
Ack Number
Use this field to check for a specific TCP acknowledgment number.
Window Size
Use this field to check for a specific TCP window size.
Transport Protocol: UDP
Port
Select the checkbox and then enter the source and destination UDP port numbers that will trigger this signature.
Transport Protocol: ICMP
Type
Use this field to check for a specific ICMP type value.
Code
Use this field to check for a specific ICMP code value.
ID
Use this field to check for a specific ICMP ID value. This is useful for covert channel programs that use static ICMP fields when they communicate.
Sequence Number
Use this field to check for a specific ICMP sequence number. This is useful for covert channel programs that use static ICMP fields when they communicate.
Payload Options
The longer a payload option is, the more exact the match, the faster the signature processing. Therefore, if possible, it is recommended to have at least one payload option in your signature.
Payload Size
This field may be used to check for abnormally sized packets or for detecting buffer overflows.
Select the checkbox, then select Equal, Smaller or Greater and then type the payload size.
Stream rebuilt packets are not checked regardless of the size of the payload.
Add
Edit
Remove
Offset
This field specifies where to start searching for a pattern within a packet. For example, an offset of 5 would start looking for the specified pattern after the first five bytes of the payload.
Content
Type the content that the signature should search for in the packet payload. Hexadecimal code entered between pipes is converted to ASCII. For example, you could represent the ampersand as either & or |26| (26 is the hexadecimal code for the ampersand).
Use 1 to 63 single-byte characters, including 0-9a-zA-Z!#$%&’()*+,-./<=>?@[]^_{|}
“:;\‘are not allowed.
Case-insensitive
Select Yes if content casing does NoT matter.
Decode as URI
A Uniform Resource Identifier (URI) is a string of characters for identifying an abstract or physical resource (RFC 2396). A resource can be anything that has identity, for example, an electronic document, an image, a service (“today's weather report for Taiwan”), a collection of other resources. An identifier is an object that can act as a reference to something that has identity. Example URLs are:
ftp://ftp.is.co.za/rfc/rfc1808.txt; ftp scheme for File Transfer Protocol services
http://www.math.uio.no/faq/compression-faq/part1.html; http scheme for Hypertext Transfer Protocol services
mailto:mduerst@ifi.unizh.ch; mailto scheme for electronic mail addresses
telnet://melvyl.ucop.edu/; telnet scheme for interactive services through the TELNET Protocol
Select Yes for the signature to search for normalized URI fields. This means that if you are writing signatures that includes normalized content, such as %2 for directory traversals, these signatures will not be triggered because the content is normalized out of the URI buffer.
For example, the URI:
/scripts/..%c0%af../winnt/system32/cmd.exe?/c+ver
will get normalized into:
OK
Click this button to save your changes to the Zyxel Device and return to the summary screen.
Cancel
Click this button to return to the summary screen without saving any changes.
Applying Custom Signatures
After you create your custom signature, it becomes available in an IPS profile (Configuration > Security Service > IPS > Profile > Edit screen). Custom signatures have an SID from 9000000 to 9999999.
Search for, then activate the signature, configure what action to take when a packet matches it and if it should generate a log or alert in a profile. Then bind the profile to a zone.
Verifying Custom Signatures
Configure the signature to create a log when traffic matches the signature. (You may also want to configure an alert if it is for a serious attack and needs immediate attention.) After you apply the signature to a zone, you can see if it works by checking the logs (Monitor > Log).
The Priority column shows warn for signatures that are configured to generate a log only. It shows critical for signatures that are configured to generate a log and alert. All IPS signatures come under the IPS category. The Note column displays ACCESS FORWARD when no action is configured for the signature. It displays ACCESS DENIED if you configure the signature action to drop the packet. The destination port is the service port (53 for DNS in this case) that the attack tries to exploit.
Use this screen to list signatures that will be exempted from IPS inspection. The Zyxel Device will exclude incoming packets with the listed signature(s) from being intercepted and inspected.
Use Add to put a new item in the list or Edit to change an existing one or Remove to delete an existing entry.
Configuration > Security Service > IPS > Allow List
LABEL
Description
Rule Summary
Add
Edit
Remove
Signature ID
This field displays the signature ID of this entry.
Signature Name
This field displays the signature name of this entry.
Apply
Reset
IPS Profile
To use multiple profiles for this feature, run the following commands in the Zyxel Device Command Line Interface (CLI).
Router# configure terminal
Router(config)# secure-policy-style advance
Router(config)# show secure-policy-style status
secure-policy-style: advance
After you run these command, go to the feature screen again in the web configurator. You will be prompted to log out and then log in again.
After you log in again, you will see the new profile screen for this feature.
Label
Description
Add
Click this to create a new entry. Select an entry and click Add to create a new entry after the selected entry.
Edit
Double-click an entry or select it and click Edit to open a screen where you can modify the entry’s settings.
Remove
Select an entry and click Remove to delete the selected entry.
This field is a sequential value showing the number of the profile. The profile order is not important.
Name
This displays the name of the profile created.
Description
This displays the description of the profile.
Add or Edit an IPS Profile
Click Add to create a new entry or select an existing entry and click Edit to open the following screen where you can create or modify the entry’s settings.
label
Description
Configuration
Profile Name
Type the name of the profile. You may use 1-31 alphanumeric characters, underscores(_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. These are valid, unique profile names:
MyProfile
mYProfile
Mymy12_3-4
These are invalid profile names:
1mYProfile
My Profile
MyProfile?
Whatalongprofilename123456789012
Description
Type a description for the profile rule to help identify the purpose of rule. You may use 1-31 alphanumeric characters, underscores (_), or dashes (-), but the first character cannot be a number. This value is case-sensitive. This field is optional.
Query Signatures
Name
Signature ID
Severity
Classification Type
Platform
Service
Action
Activation
Log
Query Result
OK
Click OK to save your changes back to the Zyxel Device.
Cancel
Click Cancel to exit this screen without saving.
Link a Profile
To link a profile to a policy, go to the Configuration > Security Policy > Policy Control screen, select a policy, and then click Edit. In the Edit Policy screen under Profile, select which profile you want to use for each security service.
The IPS Advance Screen
The Configuration > Security Service > IPS screen changes when using profiles.
Configuration > Security Service > IPS Advance
label
Description
General Settings
Enable
Inspect all traffic, setting:
Select this to have all traffic inspected by the default_profile or default_detect_only.
Use the default_profile profile to set the Zyxel Device to IPS prevention mode. Use the default_detect_only profile to set the Zyxel Device to IPS detection mode. For more information on IPS prevention and detection mode, see Configuration > Security Service > IPS.
You cannot rename or delete the default_profile or default_detect_only profile, but you can edit it by clicking on the profile name.
Inspect by policy
If you configured a specific profile in the Profile tab for this service, select this to have specific traffic inspected by that profile. You must bind the profile to a policy in Security Policy > Policy Control.
Add
Edit
Remove
Export
SID
Name
File Path
Current Version
Signature Number
Released Date
Update Signatures
Apply
Reset
Remove Profiles
To remove profiles and revert to the default general security policy style, you must first make sure to change Inspect by policy to Inspect all traffic in the following security services: Anti-Malware, DNS Threat Filter, IPS, Email Security.
*All profiles that you created will be removed from Security Policy > Policy Control.
Run the following commands in the Zyxel Device Command Line Interface (CLI).
Router(config)# secure-policy-style general
secure-policy-style: general
Wait a minute and then go to the feature screen again in the web configurator. You will be prompted to log out and then log in again.
After you log in again, you will not see the profile screen for this feature.
