Label | Description |
Add New Interface Group | Click this button to create a new interface group. |
Group Name | This shows the descriptive name of the group. |
WAN Interface | This shows the WAN interfaces in the group. |
LAN Interfaces | This shows the LAN interfaces in the group. |
Criteria | This shows the filtering criteria for the group. |
Modify | Click the Edit icon to modify an existing Interface group setting or click the Delete icon to remove the Interface group. |
Group Name | Enter a descriptive name for this interface group. You can use up to 32 printable characters except [ " ], [ ` ], [ ' ], [ < ], [ > ], [ ^ ], [ $ ], [ | ], [ & ], or [ ; ]. Spaces are allowed. |
WAN Interfaces used in the grouping | Select the WAN interface this group uses. The group can have up to one PTM interface, up to one ATM interface, up to one ETH interface, and up to one WWAN interface. Select None to not add a WAN interface to this group. |
Available LAN Interfaces Selected LAN Interfaces | Select one or more interfaces (Ethernet LAN, wireless LAN) in the Available LAN Interfaces list and use the right arrow to move them to the Selected LAN Interfaces list to add the interfaces to this group. To remove a LAN or wireless LAN interface from the Selected LAN Interfaces, use the left arrow. |
Automatically Add Clients With the following DHCP Vendor IDs | Click Add to identify LAN hosts to add to the interface group by criteria such as the type of the hardware or firmware. See Interface Grouping Criteria for more information. |
# | This shows the index number of the rule. |
Filter Criteria | This shows the filtering criteria. The LAN interface on which the matched traffic is received will belong to this group automatically. |
WildCard Support | This shows if wildcard on DHCP option 60 is enabled. |
Modify | Click the Edit icon to change the group setting. Click the Delete icon to delete this group from the Zyxel Device. |
Cancel | Click Cancel to exit this screen without saving. |
OK | Click OK to save your changes. |
Source MAC Address | Enter the source MAC address of the packet. |
DHCP Option 60 | Select this option and enter the Vendor Class Identifier (VCID) of the matched traffic, such as the type of the hardware or firmware. |
Enable wildcard | Select this option to be able to use wildcards in the Vendor Class Identifier configured for DHCP option 60. |
DHCP Option 61 | Select this and enter the device identity of the matched traffic. |
Enter the Identity Association Identifier (IAID) of the device, for example, the WAN connection index number. | |
DHCP Option 125 | Select this and enter vendor specific information of the matched traffic. |
Enterprise Number | Enter the vendor’s 32-bit enterprise number registered with the IANA (Internet Assigned Numbers Authority). |
Manufacturer OUI | Specify the vendor’s OUI (Organization Unique Identifier). It is usually the first 3 bytes of the MAC address. |
Serial Number | Enter the serial number of the device. |
Product Class | Enter the product class of the device. |
VLAN Group | Select this and the VLAN group of the matched traffic from the drop-down list box. A VLAN group can be configured in Network Setting > VLAN Group. |
