Tutorials
Overview
This chapter shows you how to use the NCC’s various features.
Add a Nebula Device
Activate and Assign a License for a Nebula Device, Site, or Organization
Monitor a Site
Know What License Tier My Organization Belongs To
Know What Licenses are Set to Expire in My Site or Organization
Renew an Expired License
Transfer Licenses
Transfer Nebula Devices to Another Organization
Change an Organization and/or Site Name
Change the Nebula Device Name
Reset the Nebula Password
Maintain Firmware
Backup Current Configurations in Nebula
Assign an Administrator to Manage a Nebula Device
Transfer the Ownership of the Organization
Manage a Configuration Template
Activate an MSP License
License Migration for Nebula USG FLEX H Series
Configure CNP/CNP Plus Security Services
Delete an Organization
Remote Access VPN Setup
Route L2TP VPN Traffic
Configure Guest Isolation on your WiFi Network
Configure Content Filter to Block Access to Certain Websites
Configure Schedule to Allow WiFi Access Only at Certain Times
How to Position Multiple Nebula APs
Change the Default SSID and Password
Change the WiFi Band Mode
Check What Clients are Connected to Nebula Devices in your Network
Configure a Unique SSID Name for Each AP (for Nebula Access Points only)
Find the SSID of the WiFi Client (for Nebula Access Points only)
Use Tags to Assign SSIDs for Nebula APs
Resolve WiFi Connection Problems (for Nebula APs only)
Configure WiFi Security with WPA2 Personal (for Nebula APs only)
Configure WiFi Security with WPA2 Enterprise (for Nebula Access Points only)
Using DPPSK to Access the Guest WiFi Network
Create a DPPSK Key Using the DPPSK API
Disable MAC Randomization on WiFi Clients
Monitor and Improve the Health of WiFi Networks for APs and Connected WiFi Clients
Set Up WiFi Network Load Balancing
Configure a Captive Portal
Create a Custom Captive Portal Page
View Applications Usage
Limit Applications Usage or Block Applications
Find the LAN Port Used by Connected Wired Client Devices (for Nebula Switches only)
Configure Voice VLAN (for Nebula Switches only)
Manage IPTV (for Nebula Switches only)
Enable IP Source Guard (for Nebula Switches only)
Set Up MAC Authentication With NCAS (for Nebula Switches only)
Set Up Dynamic VLAN With RADIUS (for Nebula Switches only)
Monitor Dynamic VLAN Using Event Logs (for Nebula Switches only)
Register a Nebula Broadband Router in Nebula
Using Collaborative Detection and Response (CDR)
Deploy With Nebula Native Mode (for Nebula Firewalls in NCC only)
Configure DHCP Domain Name (for Nebula Firewalls in NCC only)
Monitor Client Bandwidth Usage (for Nebula Firewalls in NCC only)
Configure a Primary and Backup WAN (for Nebula Firewalls in NCC only)
Set Up Nebula Monitor Mode (for Nebula Firewalls in on-premise only)
Enable Smart Mesh on a Nebula Security Router
Configure Nebula Identify Federation Service (NID FS)
This site works best with JavaScript enabled
